Question about The Watches
My second hand on my UL 1069 stopped functioning so the min hand and the hour hand don't work either. It is an Unlisted 1069
Does this watch use a battery and that is why the second hand stopped working? Please advise
SOURCE: tissot t touch
there are sync instruction on the manual page on the web.
1. Activate the Crystal.
2. Select the "units Mode".
3. Press and hold the "T" until it switched to "syncro" mode.
4. Now using the + and - move the hands to the 12 o'clock position.
5. Press "T" again to set.
Posted on Jan 14, 2008
  • 18 Answers
SOURCE: Stop Watch not resetting
pulling the crown out to position 2 and pressing button to zero it out one increment at a time is the way to do it do touch the watch hands. Works on fossil watches as well as tag watches
Posted on Jul 09, 2009
SOURCE: The second hand of my Tissot watch T870/970 starts and stops.
Absolutely astonished by this "solution" from escapement.
This watch is working perfectly - it is simply giving its "end of battery life warning".
Posted on Dec 11, 2009
SOURCE: how do u operate unlisted ul 1095
Download the manual here
Posted on Nov 08, 2010
  • 1961 Answers
SOURCE: I own UL 1168,
This is the closes instruction guide that I found on the internet. Hope this helps! You must have adobe acrobat reader installed in your system to view this manual cause its pdf format.
you can search for other possible user guide compatible for your model from the link below.
select customer service..scroll down below for Instruction Manual..
Posted on May 19, 2011
How to make the analog time work on the unlisted UK 1069
Nov 10, 2016 | The Watches
Unlisted Kenneth cole ul 1069 all other functions work except hands they stopped when trying to set date. what do I do to get hands working again?
your watch has two battery.
one battery for Digital
other one for Analogue
perhaps battery for analogue died
you need to change one battery
Sep 24, 2014 | Kenneth Cole Unlisted Ana-Digi watch
Why does the hands on the ul 1173 watch does not work?
UL1173 watch has two battery, one for digital other one for analogue.
analogue ( Hands parts) battery died, you need to change battery.
Aug 28, 2014 | Kenneth Cole Unlisted Ana-Digi watch
How to use the subdials on a wrist watch
One of them is the seconds hand of your watch, this sub dial will keep on moving even if the watch is not used as a stop watch. the other 2 sub dials are for the stop watch function. one is for tracking the minutes and the other is for hours. the big seconds hand will only work if you use the stop watch function. you can reset your stop watch to zero by pressing the pusher located at the 4 o,clock location of your watch.
Oct 20, 2012 | Rolex SS/18kt Daytona
I just bought a Kenneth Cole Unlisted mens watch. There is no instructions on how to set the day and date. Is it broken out of the box or are those dials just fakes? Jens
The Mode button on the bottom left hand side will set your "SET" buttons to work.
The first push of your Mode button will activate your Stop Watch. Press the top right button to time your subject. Press it again to stop timing your subject.
Pressing the bottom right button will reset your Stop Watch to zero.
Press the Mode button to release your Stop Watch function and return to the Telling Time function.
Press the Mode button twice and you'll be able to set your Alarm function. Your Hour number will be flashing. Press the top right button to set your Alarm Hour. If you Alarm Hour is for the afternoon or evening continue pushing until a "P" appears by your hour number . This will be your afternoon/evening hour. If there is no "P" that, of course, will be your morning hour.
Press the bottom right button to adjust the minute number of your Alarm function. Your minute number will be flashing. Again, using the top right button, you'll be able to adjust your minute number.
(If you hold any number changing button for a long time, the numbers will flash through rapidly.)
Press the mode button to release your Alarm setting function.
Press the Mode button three times to set the Time of Day on your watch. At this point you'll also need to push the bottom left button to activate your Time of Day function. after pressing the bottom right button your minute number will start flashing. Press the top right button again to adjust your minute number. Once that's done, press the mode button to release your time of day function.
Hope this helps!
Oct 18, 2010 | Kenneth Cole Watches
How do u operate unlisted ul 1095 no instructions came with watch
Mar 30, 2010 | Kenneth Cole 1213 Wrist Watch
How to set kenneth cole unlisted digital watch with 4 buttons
OK I'll do my best to describe the procedure...
Part 1:
Press mode button till the seconds window blinks
Press Lap/Reset button once to make minutes blink
Cycle through minutes using Start/Stop Button
Part 2:
Press Lap/Reset button once again to make hours blink
Cycle through hours using Start/Stop Button
(for this part, it's a bit tricky. Hours can be displayed in AM, PM, or 24 hour duration. AM is represented by "A", PM is shown with "P" and 24 hour mode is shown with "H", so keep an eye in the seconds window when setting your hour so you know for sure if you have the right hour)
When your done setting minutes and hours, press mode button again till you get to main screen
A helpful hint is to remember when setting up anything in this watch, mode will cycle through the different screens, lap/reset will change the value of whatever your modifying (AKA minutes/hours) and start/stop scrolls through the different fields.
Hope this helps. Sorry if it's confusing, best I could do.
Sep 28, 2008 | Watches
Aug 27, 2008 | Tag Heuer Kirium Ti5 CL1181.FT6000 Wrist...
Watches Logo
24 people viewed this question
Top The Watches Experts
D. E. Hev
John mullen
Are you a The Watch Expert? Answer questions, earn points and help others
