Question about Lands Phones
My gigaset die only after 10 t 30 minuites of use?
The phone does not hold charge... dies after a few minutes of talk time
Quite probably it's the battery. Open it, get the specification for battery and buy a new one. Be careful, there are many very similar batteries but connection to phone is different.
Oct 22, 2015 | Siemens S67H GIGASET Handset With Charger...
How to lock handset
You should look up function in your user's manual. If you can't find it, you can't lock handset:
Manuals Gigaset
Manuals Gigaset
Manuals Gigaset
Siemens Gigaset A490 White Cordless Phone Unboxing
Aug 28, 2015 | Siemens Gigaset A490 Twin Cordless Phone
89 chevy 3/4 ton. 2wd. 454. AT. truck runs good
check your timing, check that your ignition pick up coil is good. also check your fuel pressure. and check for any vacuum leaks. double check your coolant temp sensor to the ecm it tells the ecm what temp it is and the ecm adjusts the fuel amount accordingly.
Oct 14, 2013 | 1989 Chevrolet C1500
My touch pro will not turn on. I plug it in and all it does is turn on to the screen that sais touch pro and it vibrates then off again and it keeps repeating that step! i dont wanna do a hard reset cuz i...
if the battery completely died, you have to leave it charging for more than a few minuites. try anywhere from 10 to 30 minuites and it should be charged enough to turn on
Mar 24, 2009 | HTC Touch P3450 Smartphone
Problem Siemens Gigaset 4000 and 4200
You did get spiked from the power company, and your system needs repair. Go to www.cordlessrepair.com for help.
Jun 23, 2008 | Siemens Gigaset 4000 Phone
Phone holds charge from 12-55 min. and then goes dead
Your handset or charger has gone bad (provided you installed rechargable batteries), or both. The previous user may have installed alkaline batteries (is their a white powdery residue in the the charge compartment?), and that can ruin the charge circuit. Either way, you probably need to contact repair. You can go to www.cordlessrepair.com
May 23, 2008 | Siemens Gigaset 4000 Phone
My siemens gigaset 4215 and 4000 don't work and need some kind of code whats the code?
Hello, Almost never is it the handset that is bad when those symptoms occur. It sounds as if your base has gotten hit by a power surge and won't boot (the handset now can't "talk to" the base and its always searching for it). Most people report this after a storm has passed through their area. You can try re-registering the handset to the base, but unfortunately it probably won't work, sorry. You can order the base only and register your handset to the replacement base when you get it. To order a replacement base using google, search for Siemens Cordless Repair and click the first non sponsored link. Good Luck
Dec 08, 2007 | Siemens Gigaset 4000 Phone
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
