Question about Microwave Ovens
Breville microwave model MW3 50Hz keeps getting extreemly hot, on the top right rear side after 5mins of use, then cuts out. Presumably due to overheating. What makes it do this and is it repairable.
Dissolu
  • 221 Answers
SOURCE: my Breville BRE799GMSSE microwave will not heat anything
If you want to fix it yourself you'll need some understanding about what you're going to do.
If absolutely everything is working and food stays cold, there's only one problem MAGNETHRON. You'll need to dissassemble the microvave itself, remove the magnethron an to replace it with the same type.
Be advised Tthat this might be expensive. In some cases magnethron costs more than new microwave oven (in Europe).
Posted on Jun 22, 2009
SOURCE: Metal plate on inside of microwave has hole & is arcing.
The Arcing is a real bad sign, and you see the "Brain" has detected a fault condition, most likely the Power Supply and or magnetron, or High Power Diode, has "Faulted" and it shuts down for Safety reasons. Due to the danger existing inside MW, I recommend that you have it serviced by a qualified person. Always get a firm "Quote" before proceeding with any work. Be careful, as often a repair may cost as much as a new one.
Posted on Mar 13, 2010
Testimonial: "Thanks for the insight. We will definitely look into the items listed and have it looked at by a qualified repair tech."
  • 1833 Answers
SOURCE: Microwave had burnt electrical smell a few minutes
The electrical burning smell will be the Hi-Voltagetransformer inside the microwave. Along with the transformer you will also needto replace the capacitor. It couldbe a leaking high voltage cable (electric arching) bad insulator, if it's moreof an electronic component burning smell, it could be an overheating component,in both cases you should have it checked by a professional technician.Hope this will help you. Good Luck.
Posted on Sep 06, 2011
  • 6771 Answers
SOURCE: Maytag microwave overheated and shut off - Model #MMV5165BA
That is not good, the magnetron has gone, or the thermal fuse has failed, "protects the magnetron from overheating" There is a possibility the keypad control board was a affected.
Posted on Apr 08, 2012
  • 147 Answers
SOURCE: Panasonic Microwave NNA883 cuts out after 20 seconds.
You need to replace the diode. Scratch that. The voltage let alone the radiation could kill you. Call a technician. If it is a table top unit, buy a new one. It will be cheaper,
Posted on Aug 28, 2012
I need a replacement turntable for my brevile combination microwave model brcm2516 where can I get one
First4Spares Glass Turntable Plate For Breville Microwave Ovens ...
https://www.amazon.com/First4Spares-Glass-Turntable-Breville-Microwave/.../B007B...
Shop First4spares at the Amazon Small Appliance Parts & Accessories store. Free Shipping on eligible ... BREVILLE MICROWAVE TURNTABLE Glass Plate 245mm 9.5". $29.99. Next ... Container for Microwave Oven · Add to Cart · Add to ...
Amazon.com: BREVILLE MICROWAVE TURNTABLE Glass Plate ...
https://www.amazon.com/BREVILLE-MICROWAVE-TURNTABLE-Glass.../B00COP... Quality replacement glass turntable for your Breville microwave. ... Small Appliance Parts & Accessories > Microwave Oven Parts & Accessories > Turntables
Breville Shop ' Partmaster
www.partmaster.co.uk/breville/microwave/catalogue.pl?shop=breville&path... Find your Breville products and repair your appliance yourself for less. ... Connects the microwave motor to the glass turntable Suitable for select microwave ...
Breville Canada
https://breville.ca/ Breville designs and engineers small kitchen countertop appliances to deliver commercial quality performance that look great and are easy to use.
Breville Microwave Parts & Accessories ' eBay
https://www.ebay.co.uk > ... > Breville Microwave Parts & Accessories BREVILLE Microwave Glass Turntable Plate Roller Ring Support Stand 3 Wheel ... Turntable Turn Table
Plate MOTOR for BREVILLE Microwave Oven ...
Breville Parts -Google Search
Jul 03, 2017 | Microwave Ovens
Fan keeps running
never seen or heard a microwave that the fan is suposed to keep ruinning on after timer gives up , im in the suspicion that there is an failure inside the appliance to cause this , due to extreemly !!!! high voltage (ten times whats in your house) inside a microwave i dont suggest a consumer open the case for a look tooo dangerous!!! refer this to a repair center
Feb 10, 2015 | GE Microwave Ovens
MICROWAVE RHM1709B-G keeps cutting out when cooking
You're going to need to replace the oven
Jan 05, 2018 | Microwave Ovens
Aug 27, 2012 | Misc - MFG Microwave Ovens
Where is the high voltage fuse on a microwave
The thermal fuse monitors the magnetron temperature and cuts power, if it gets to hot and resets in no more than 20 to 30 minutes. Unplug microwave oven, remove top, "several screws" look over to the right, thermal fuse is mounted on top on the inner chassis, "round and thick with 2 wires clipped on"
Apr 16, 2012 | Jenn-Air JMC8127DD Microwave Oven
Need to know where fuse is in microwave oven from 1994 model number 56-5472-1004
remove the top cover and iys at the right rear side on the top of unit part# AP2140275 and the fuse is a 20Amp chemical fuse part # AP2136296
Sep 23, 2009 | Microwave Ovens
My Breville BRE799GMSSE microwave will not heat anything
Jun 21, 2009 | Microwave Ovens
Hello. i have a sharp carousel microwave i bought one year ago and now it is making a louder noise when it's cooking plus the outside of the microwave unit is getting very hot. what do you think is the...
this is the magnetron going bad and it is heating the outside and the inside(probably not so much on the inside right?) Well this is DANGEROUS now and i would no longer use it , as it is sending waves out and thats why it is getting hot , it will need professional service as microwaves are extreemly dangerous
Dec 01, 2008 | Sharp Microwave Ovens
I would like to buy a breville cappuccino maker but hear the dial at side gets stuck and breaks easily,even when cleaned well after use. Has this been rectified. Doreen
Hi, apparently Brita, that owns Breville, did not fix the problem yet.
I can see that complains keep coming.
The problem is apparently on CM8 and CM9, the more expensive Cappuccino Maker BES200XL
does not have the problem.
One suggestion, Breville are nice budget coffe maker, if you want to spend some mor money on a better product buy a Gaggia or something similar. Italian coffee makers are usually the best for espresso/capuccino. If you want a Breville buy the ESP8XL Espresso Machine.
Here is another good brand.
Sep 13, 2008 | Microwave Ovens
Microwave Ovens Logo
29 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
