Question about Sony Televison & Video
Stanby light flashes 5 times breif pause then flashes 5 times again
  • 20 Answers
AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Posted on Jul 20, 2009
How to retrieve problem codes on a 1995 dodge dakota
Without a scanner insert the key in to the ignition turn the ignition to on then off then on again then if again and then on do not crank the engine do this within seconds and then look for the check engine light to flash. 1 pause follow by two flashes is code 12 when there aren't any more codes to display the light will flash 5 times pause and flash 5 more times this is 55 indicating that the process is complete.
Mar 11, 2012 | 1995 Dodge Dakota
I have a 1994 plymouth voyage se and it will not strat. It tell me to check gauge light comes on. what should i do or what does that mean?
Turn key to on ( not start) then off, then on, then off, then on and leave on, and have a pen and paper ready to record flashes of "check engine light". It will flash then pause between second number of 2 digit code. Then a short pause and flash again, pause, then flash. For example: if it flashes 2 times, then pause, then flashes 2 more times, that would be code 22. If it flashes 3 times, pause, then flashes 5 more times, that would be code 35. As I said, there will be a short pause between 2 digits, as well as after number. Write them down as they come up and get back to us with those codes for advice. When you get code 55 ( 5 flashes, pause 5 more ) that means end of message. Those codes should point everyone in right direction of trouble spot.
Jul 31, 2011 | 1991 Plymouth Grand Voyager
Stanby light flashes green and looses the signal tv turns to stanby then comes back on this happens about every 10 minutes
For the KDSR60XBR1, 5 blinks, pause, 5 blinks, etc. means "Lamp driver error" and the probable cause listed is "Lamp driver is faulty".
You may purchase the lamp driver (power supply block), part number 146893612, for $161.86 at http://servicesales.sel.sony.com/web/productSearch.do. Use the Part or Accessory Number to look it up."
Jan 25, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
TV popped and shut off red light flashes 5 times then pauses
this specific type of TVs flash their standby light if the onboard testing system sniffed out a problem
so, as if your TV is trying to tell you "i have a problem and i need to be serviced"
i hope it goes well for you
:D
Aug 30, 2009 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Check engine light on
Cycle your key, on (not start) off, on, off, on. Leave it on 3rd time, and count check engine flashes. It will be a 2 digit number each time. For example: flash,flash, pause, flash, flash. Is code 22.
Flash,flash,flash,pause,flash,flash,flash, is code 33. There will be a little longer pause after each set of 2 digits. When you get flash,5 times, then flash 5 times again, that's code 55 which means end of trouble code message. have a piece of paper ready, write them down, and get back to us with results.
Feb 20, 2009 | 1989 Plymouth Reliant
CAR LOOSES BOGS OUT AT HWY SPEEDS AND IDOLOS ROUGH .
Cycle your key on (not start, just on) off, on , off ,on, and leave it on. have paper & pen ready. Watch flashes from check engine light. It will flash quick, pause flash quick. It will be a 2 digit number each time. For example: flash, flash, short pause, flash, flash. is # 22. Flash, flash, flash, pause, flash ,flash,flash. is # 33. There will be a slightly longer pause between codes,(after every 2 digits) then next code starts. 2 numbers again. When you get 5 flashes, pause, 5 flashes = code # 55 means end of message. Check it out and let me/us know what you get.
Dec 31, 2008 | 1991 Plymouth Acclaim
Kf60xbr800 internal lamp component, what is the replacement costs for such parts
Go look at your set up timer in menu see what it says some sets will tell you to replace lamp, while other types of DLPs just start turning off and on ,their may also be something wrong with area around lamp too.Read your service manneul or get one on www.free service manneuls.com . ThankYou for using FixYa.Have a Nice Day.
Feb 07, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
1999 Sony Trinitron TV. We have sound but no picture. Stanby light is flashing?
How many times does the light blink. It should blink a code 1-8 blinks pause a second then blink the code again. Count the blinks then let me know. If it just blinks constantly without pausing. let me know that as well.
Jan 19, 2008 | Televison & Video
Televison & Video Logo
290 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
