Question about Bernina Sewing Machines
I have bernina 150, with main circuit board requiring repalcement help ? any idea please sue
    New Friend:
  • 42 Answers
Is the power coming on, screen lighting up etc? If not, it will be the L-Print(power board) not the S-Print(main board). The L-print is much cheaper but newer boards will require a dealer I'm afraid.
Posted on Dec 05, 2016
Is a Bernina 430 worth fixing if the circuit board goes bad
Ooooh, that's a tough question. Circuit boards (computer boards, in general) could be costly to replace. However, a computerized machine will most likely, at some point in its life, require board replacement. It just depends how much you like the machine and what you are willing to spend. This model series was discontinued some years ago and replaced with bigger/better?/costlier machines. Some people are less attracted to the 400 series because it has to be connected to a computer to do embroidery. Of course, there is always the possibility that when you replace one board, another may go bad. Such is life with most things computer. If a donor machine could be found with a good board, the cost may not be as much as trying to find a new board or going through Bernina. You can check what it would cost to have a Bernina dealer fix it for you. On the other hand, if you or someone you know is very computer-savvy, well, you know. Just remember, even if you replace it with another computerized machine, you could be facing the same decision in the future.
Jul 22, 2017 | Bernina Sewing Machines
Where ot buy bernina main circuit board pleaseSue
Depending on the model you can try :
http://www.sewingpartsonline.com/lookup.html?keywords=bernina+board#
http://drdanessmh.com/berninahelectronbds.html
otherwise you'll have to get it through a dealer, which should offer a warranty if they install it. Often times the S-Print(main board on a bernina) can be $500-$700 though. Older boards for 930s etc may not be available anymore.
Dec 05, 2016 | Bernina Sewing Machines
Bernina 150 circuit board - according to local shop my bernina 150 main circuit board has desceasesd. Please help me get find replacement
Bernina would probably be the best place to check. Next might be finding a donor machine with a good board.
Screen goes blank and then stops sewing. I have a Bernina Aura 440QE 8years old.
You should probably take it to Bernina for repair. Sounds like possibly a board or component.
Nov 08, 2015 | Bernina Sewing Machines
I have a bernina virtuosa 150. how do you change stitches with the cps system?
try contacting bernina customer service and ask them how to
change the stitches
Feb 06, 2013 | Bernina Virtuosa 150
When I tried to turn my Virtuosa 150 on, a light colored smoke came out of the top left hand side of the machine. What happened?
sounds like a capacitor, circuit board or something electrical has gone inside it; I'd suggest taking it to a Bernina service centre for deeper diagnosis as this is an electronic machine and more complex that a standard mechanical machine.
Jan 04, 2012 | Bernina Virtuosa 150
Is it worth replacing a blown main circuit board on bernina virtuosa 150 QE or cheaper to buy a new one?
it would be cheaper to buy a new machine the broads can cost upwards of 300.00 and that doesn't include the labor
Aug 27, 2010 | Bernina Virtuosa 150
I had a Bernina Aurora 440 given to me to repair the machine runs for about 20-30 mins then the screen goes off. When you take the front cover off you can see 3 leds a 30v 12v and a 5v. The 5v led goes...
This is a problem with the particular model. Bernina has a servi ce bulletin out on that issue and it should be under warranty. It needs a new power supply, or L-Print as Bernina calls it.
Apr 21, 2010 | Bernina Sewing Machines
During our last storm my Bernina 170 just died. I had it on a surge protector, but it just doesn't turn on. While I love this machine, I also have a B 165, so I thought I would try my hand at fixing it...
If this is an older model, the power supply module is a little sensitive to mains spikes - I've had three that have suffered a similar fate and all have required replacement power-supplies - the switching transistor gets blown and this is a job only for the qualified service engineer. My suggestion, I'm afraid, is to have it checked-over by a service engineer. There is a glass fuse on the circuit board, but if blown, it's usually for a reason and 9 times out of 10, just replacing it results in a second blown fuse !!!
Jan 18, 2010 | Bernina Artista 170
Bernina Virtuosa 153 QE Won't turn on
If you've got bad luck like I do, you probably blew out the circuit board! It took my Bernina dealer 4 months to get another from Sweden; thank goodness they gave me a loaner.
Unfortunately, it happened again right after I picked it up from the dealer, and they have to find another circuit board for it! It's not a problem with my electrical wiring because the loaner ran just fine.
It's very, very frustrating because I'm a small business and need my machine running!
May 13, 2008 | Bernina Virtuosa 150
Sewing Machines Logo
71 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
