Question about Whirlpool LER4634J Electric Dryer
We got an Crosley CDE8000W electric dryer and the electrical plug was removed. How do you install a new one? Don't know what wires go where! Thanks, Mike
    President:
  • 1,714 Answers
Here's the 3 wire and 4 wire hook-upWe got an Crosley CDE8000W electric dryer and the - af09179.jpg436ab78.jpg
Posted on Jul 20, 2009
I have a roper electric dryer model number is RGL4632DWO and I have purchased the coils for it, my question is where are they located at? I don't want to tear it a part without knowing about where they...
Remove plug from wall socket.
Remove back from dryer.
On the right side you should see a sheet-metal duct/tube.
Label and disconnect wires to parts going into this duct.
Remove duct.
Heating element (coils) should be in lower portion of the duct.
Jul 08, 2011 | Roper REX4634KQ Electric Dryer
I want to put a new 4-wire/prong dryer cord, and I don't know how to conect
Hi sacra4487...
Go to this webpage and see a picture of how to hook up your dryer cord
Free Answer...Please take time to rate me
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Jun 12, 2011 | Crosley CDE6000 Electric Dryer
Dryer stopped working without any previous problems. Interior light also does'nt work. I have checked 220 outlet and door switch with meter. It is a Crosley Model # CDE8000W. It was as if it was unpluged....
could be a burnt wire in the unit, check the connection where the cord goes in to the dryer. You may have to take a couple of screws out to do so. Also check for 220volts where the cord connects to the dryer. Be careful with high voltage.
Apr 10, 2011 | Dryers
Electric Dryer, heating el works, exh not blocked, clothes no dry
double check your element temp t-stat and recheck continuity on element. I have known them to work but have shorts in them
Apr 09, 2009 | Crosley CDE6000 Electric Dryer
Need a wiring diagram for cde6000
There should be one iside the machine or hidden somewhere. Look under the control panel. Usually they are there. Let me know if you need any other help
Mar 29, 2009 | Crosley CDE6000 Electric Dryer
Crosley CDE8000W Dryer has electric burning smell and shut down
it is most likely the belt. the squealing noise is because the motor is turning, but the belt is not. a replacement belt is not too expensive and it is fairly easy to replace. if you need directions how to replace it, let me know
Oct 27, 2008 | Dryers
Dryer doing nothing
The fuse mounts on side of the heater. Its little clip is held to the side of the heater chamber by the same screw which holds the heater element down. It has 2 white wires going to it. Clean out the dryer and check for blocked vent and loose blower wheel. good luck Kimosabe.To access the heater pop the top:
eaf511e.jpgthe heater is on the rear bulkhead, remove the front and inspect the filter area and blower assembly.
Sep 26, 2008 | Crosley CDE6000 Electric Dryer
Installed new timer forget to mark one wire on timer
I was just looking at the site and thought I could help. I know it has been a long time since your post but here it is. If you only have one wire left, put it in the last position remaining to tie/clip into. If there are more than one remaining, investigate for wear on the connections. There should be some scarring where you removed the old one. Match up the old with the new. Hope this helps.
Feb 21, 2008 | Crosley CDE6000 Electric Dryer
Crosley dryer
Let the machine sit for about an hour and try again. Let me know what happens. Would like to know the reason the motor was replaced.
Jan 26, 2008 | Crosley CDE6000 Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
287 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
