Question about Sony Audio Players & Recorders
Repair to tc 705 cassette deck from engineer in glasgow scotland area the unit is SONY
  • Sony Master
  • 1,267 Answers
What is it that does not work? You can download the service manual from Hi Fi Engine. The get working on it.
If I get more tails of the malfunction I could give more information.
I have worked on decks for over 40 years so far.
petraman7
  • 1175 Answers
SOURCE: Door won't open
It might be a model that has a special IC that allows the door to open and close.
You'll need to take the case off.
try hifiengine.com...that site may have the service manual.
Kirk out
Posted on May 05, 2008
  • 4234 Answers
SOURCE: Cassette Tape stuck
The problem here is that the unit is stuck in a partial position. The "reset" by unplugging and plugging back in usually causes the unit to reset to a known position. If there is no activity (no motor sound), it will need to be opened up and reset manually. If you hear the motor running for a short period, it is attempting to reset, but the belt is most likely worn or broken. These units are relatively simple, but a bit tricky to dis-assemble. This repair should not require anything other than a belt or 2. Figure on $3-$10 for parts plus the local labor rate for the repair.
Dan
Posted on Oct 07, 2008
dunnbiker
  • 8546 Answers
SOURCE: sony cassette deck tc fx 210
Define 'skip' in the context of your CASSETTE deck.
Poor audio is usually due to damaged media or dirty transport (heads, pinch rollers and capstan).
You can see the tape inside the cutouts of the cassette shell. It should be perfecly smooth and the edges straight. Use reflected light to evaluate it. Edge damage will affect the Left Channel most.
Dirty heads will cause loss of high frequencies first.
The transport, well, if we need to explain it to you then we KNOW it's never been cleaned.
See this helpful link.
http://www.fixitclub.com/Electronics/Cassette_Deck.shtml
Posted on Mar 05, 2010
kerguney
  • 577 Answers
SOURCE: I have a TC-WE835S Sony
I have the same unit...when it is "ON" ,plug the power cord off and than try to open the cassette door..
the head mechanism keeps the cassette in,power off will release it..
let me know if it does not work out..
Take care and please Remember to rate/vote for us to
continue f
or Helping out the Community :)
Posted on Jul 08, 2011
  • 396 Answers
SOURCE: Sony TC-138SD cassette deck starts
It sounds like the belt is slipping or broken which monitors the speed of the tape movement. When you play or rewind the tape, it thinks the tape has reached the end of play and shuts off. You can try a different tape to make sure the tape does not have too much tension on it. If the second tape has the same result you will need to remove the top cover of the deck to inspect the tape drive mechanism. Make sure the belts and pulleys are clean and replace any belts which have glazing or cracks. If the belt is broken you will need to replace it with a compatible belt of the same length and width.
Posted on Aug 15, 2011
User manual sony tc-ka2es
It is probably found at Hi Fi Engine or owners-manuals web site.
Jul 10, 2014 | Sony TC KA2ES Stereo Cassette Deck Dual...
Model TC-W233 when I push the power button nothing comes on???
There is either a burned out transformer or more likely a broken solder joint or defective power supply part in the unit- it needs professional work.
Sep 10, 2013 | Sony TC WE435 Stereo Dual Cassette Deck...
Need circuit diagram Sony TC-K511S cassette deck
You can download it for free from here:
http://elektrotanya.com/sony_tc-k411_k511s_sm.pdf/download.html
When you use the link you get to a page where you have to wait some minutes to be possible the downloading so please be patient.
Thanks.
gylacz
Aug 29, 2011 | Sony TC-WE675 Single Cassette Deck
Where can I have my 15 year old Sony Model TC-WR465 Stereo Tape Deck Repaired? The problem appears to be mechanical. The tapes will not advance on either side of the unit.
Depend on your location and willingness to ship the unit. The cost of the repair must also be weighed in. If you don't want to put $100 into it I don't think most shops these days will want to open it up. Dual cassette deck are notorious for failure due to cheap design. Look around at all the problems. I have been fixing units for 40 years and even at Sony and Sony authorized.
I can look at it at Skywave Tape Deck Repair in Chicago area if you want. Google it.
Aug 09, 2011 | Sony TC WE435 Stereo Dual Cassette Deck...
NEED THE PART NUMBER FOR SONY TC-WE435 DUEL CASSETTE PLAYER BELTS
Flat belt part number is..
301657001.. BELT (CAPSTAN)
and square belt part number is...
302440501.. BELT (FR2)
Above said info are taken from TC-WE435 cassette player s/m.
Thanks.
Dec 25, 2009 | Sony TC WE435 Stereo Dual Cassette Deck...
Replacing bands
Since the belts control the timing of the mechanism, I would not recommend this as a home repair. While relatively simple compared to some, this still is a delicate repair that can easily go wrong. Please bring this unit to an audio repair shop. Expect a parts cost in the $15-$20 range. There are 3 belts inside.
Dan
Sep 02, 2009 | Sony TC-WR565RM Single Cassette Deck
Cassette Tape stuck
Dan
Sep 30, 2008 | Audio Players & Recorders
Cassette Tape Deck Problem
Unit may have worn belts that are slipping. All cassette player belts are subject to deterioration even if recently installed. You may try ordering the belts yourself and have a service tech install them. The tech that installed belts 9 months ago may have used used belts. Although dishonest, it is common.
Jul 17, 2008 | Sony TC WE435 Stereo Dual Cassette Deck...
Cassette Tape stuck
Try pushing the eject button while pusshing the power button. Mine was doing the same and that is how I was able to eject the tape.
Good luck
sam
Jan 01, 2008 | Sony TC WE435 Stereo Dual Cassette Deck...
119 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
