Question about Taylor Ice Cream Makers
Setting for x-valve on mod.430-12 taylor machine
TAYLOR ICE CREAM MACHINE DISPLAYS HPCO COMPRESSOR.WHAT DOES IT MEAN AND HOW DO YOU REMOVE THIS CODE
HP co is a high pressure issue on the compressor. It could be a restriction in the orifice or the expansion valve. You need a valve and gage set.
Jul 16, 2017 | Taylor Ice Cream Makers
Compressor hpco code comes up on panel of Taylor soft serve ice cream machine? Does that mean lack of water to machine?
There is a very good chance. Often the water has been shut off, or a wheel is pinching the hose.
HPCO stands for High Pressure Cut Out. The high side pressure is regulated by the water valve on water cooled equipment.
These are links to parts in the water cooling system.
046686 Water Regulating Valve 3 8
048287 Condenser for Taylor Water Cooled machines Taylor 035174 Scraper BladeReplacement 17
May 28, 2017 | Taylor Ice Cream Makers
What is process to winterize a Taylor ice cream machine?
To winterize a Taylor 794, or almost any water-cooled Taylor machine, we need to get all of the water out of it. Follow the steps outlined here.
1. Remove the supply water hose from the water source.
2. Remove the rear panel of the machine.
3. Locate the water valves. Pictured below.
4. Have one person open 1 water valve. (You can scissor two screw drivers to take pressure off of the spring.)
5. Blow out all of the water with an air compressor until only air comes out of the drain hose.
Repeat step 4 and 5 for the other side.
Sep 15, 2015 | Taylor 794-27 Soft Serve Twin Twist Water...
Taylor ice cream machine tripping on auto
sounds like you have a bad motor or compressor short
Feb 23, 2015 | Taylor Soft Serve C706-27 Machine
I AM TRYING TO FIND A PART FOR A TAYLOR ICE CREAM MACHINE, SHE GAVE MOD # 8054248. I CANNOT FIND A MANUAL FOR THIS # THANKS
that looks like it might be a serial number that is missing the letter in front on it, you need to have the proper model to look it up
Jul 21, 2011 | Taylor 632-27 Ice Cream Maker
Ice Cream Makers Logo
195 people viewed this question
Top Taylor Ice Cream Makers Experts
Dennis Boxerman
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Taylor Ice Cream Maker Expert? Answer questions, earn points and help others
