Question about Video Cameras
Setting for x-valve on mod.430-12 - Video Cameras
  • Video Cameras Master
  • 5,412 Answers
To what make and model of camcorder does this query refer, please?
Posted on Dec 05, 2016
Adjusting valve on a briggs 446677 _e1.__24hp.harde starting
valve clearance should be .010 " inlet hot and .012 exhaust hot
that is .254mm and .304 mm
valve clearance has nothing to do with hard turning over of the engine
if it turns by hand then fix the starter motor , battery leads or battery
the biggest problem with B&S motors is the valve stems which from new tend to stretch reducing the valve clearance when hot thereby making hot starts difficult if not impossible until the motor cooled down
Oct 26, 2017 | Briggs Measuring Tools & Sensors
Need valve clearance on Briggs eng. Mod. 407777
Set No. 1 cylinder at 1/4" past TDC (Top Dead Center) on compression stroke. Gap both valves at .005". Gap is set with the engine being cold. Do the same for the other cylinder. Be sure to lock the adjusters back in place.
2. .S
Aug 07, 2013 | Briggs & Stratton Garden
I have a 19.5 briggs and stratton engine on a craftsman model #917.270910. The starter turns engine then the engine hangs up not turning completely. briggs ans stratton mod#461707 type#0145 E1 code #
The decompressor is a valve lifter usually on the exhaust valve, the only adjustment is to correctly set the the valve clearances, if they are too slack the lifter will not activate.
Apr 21, 2013 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Will overfilling the transmission on a 1993 Explorer make the modulator stop working
you should not have fluid in vaccum hose .mod.valve diaphragm is probablyruptured. replace mod, valve.
Sep 11, 2012 | 1993 Ford Explorer Limited
76 351 mod 400 has a noise that sounds like the rocker arms are loose .Are they adjustable?
Yes the are adjustable, if they are the original camshaft lifters and rockers they should be hydraulic and the adjustment is 0 valve lash.
1976 is getting back there and some wear along the line someone might have changed them, remove a valve cover and see if there is a set screw on the rocker arm if there is they have been changed to a solid set and you will have to adjust them try .006 intake and .008 exhaust.
Nov 17, 2010 | 1981 Ford F 150
I have a ramco hydraulic press. mod#rp55. same as
Screw it back in, It's a simple needle and seat valve.
Nov 01, 2009 | Plumbing
Carburettor float level setting
Usually if the float is adjustable you will set it so if there is a flat surface on top or side of the float it will be parallel with the bottom surface of the carb body when the needle valve just closes (before depressing the spring in the needle)
Oct 03, 2009 | 1982 Honda VF 750 S
I have a raypak heater with robertshaw 7000 gas
Remove the wires from the gas valve and call for it to light. While it is trying to light, take a voltage reading on the wires that go to the valve. If it is sending voltage to the valve and it won't energize the valve then the valve is defective. Just make sure that the valve is being told to come on. It could just be a limit switch. Double check the manual reset limits also before doing the vavle check. Hope this helps.
Mar 21, 2009 | Water Heaters
Video Cameras Logo
53 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
