Question about Whirlpool Kitchen Ranges
Whirlpool electric range model gy398lxps00
The start button on the touchpad stopped working. All other buttons work
    Top Expert:
  • Whirlpool Master
  • 24,773 Answers
Check the timer setting.
Posted on Dec 05, 2016
I have a Whirlpool model GW395LEPQ00 gas range that suddely start button is not beeping and not working.
Do the other buttons beep going by model number your unit is white if other buttons beep you probably have a bad keypad it isn't sold seperately have to get the whole panel assembly part number W10122291 depending where you purchase about 165.00
Feb 17, 2015 | Whirlpool Kitchen Ranges
Lg electric range oven touchpad buttons not working
Did they stop working after running the self-cleaning cycle? That is what happened to mine. I moved the oven and unplugged it. Left it unplugged for a few days waiting for repairman. He plugged it in when he got there, and everything worked. He advised against using the self-cleaning cycle because the heat can cause problems with the touchpad buttons.
Jul 04, 2014 | LG LRE30451 Electric Kitchen Range
Ge profile electric range f0
You need to replace the control panel.
Jul 09, 2017 | GE Profile JS968 Electric Kitchen Range
Hlmy whirlpool is electric and we were trying to set it to clean the oven but it comes up with a f1 and then startes to beep but win't start cleaning process what does that mean?
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced
Aug 24, 2011 | Whirlpool 30" Free Standing Electric Range...
Whirlpool electric range ygy398lxpq00. The start button on the front keypad will not work. I can set temperature etc. but when I press the start button nothing happens. Shut off power for considerable...
sounds like the touch pad is bad from what you're discribing,i looked up your model on the sears site and it looks like the whole front panel comes all together,part number W10122300 and it's around 230.00 can call your parts store and see if you can just get the touch pad and hopefully you can.i've seen this happen before,the start button is pushed alot of times and it can damage the touch pad by pressing it to hard or just from using it alot of times. copy and paste this,this is the repair clinic,if you buy a part from them and it doesn't fix your problem they will take it back no matter what part it is and i think it's free's a good thing to know when the parts are so expensive,also here's the sears site so you can look up your machine.good luck with it.
Aug 15, 2011 | Whirlpool RBS275PD Electric Single Oven
Kitchen-Aid Electric control panel buttons stopped working
This may sound facetious, so don't get offended.
Did you set your clock to the correct time?
Did you clear any and all preset timers?
If none of that helps you can usually find roaches in the strangest places. If you have no roaches, then moisture and heat are the likely culprits which means that your blister pads are simply worn out. Unfortunately these are coated with graphite and don't last forever, so a timer replacement would be your only option unless your touchpad is separate from your timer.
Mar 05, 2010 | KitchenAid KERC507 Electric Kitchen Range
GY396LXPS00 - touchpad issue
You could try unplugging unit for about five minutes to clear board, this usually does not work but it gives you time for a coffee......
It sounds like you have to replace the main control board, you can try unplugging and plugging back in the molex connectors of wires to the board to make sure your connections are good to the board, good lluck.....
Jan 09, 2010 | Whirlpool GY396 Electric Kitchen Range
Start button not working all other are
make sure proper electrical voltage and connections to machine.
Oct 10, 2009 | Whirlpool GY396 Electric Kitchen Range
Ge microwave HVM1540DN1BB button control pad stopped working
I am not familiar with the Whirlpool microwaves; however, I just had the same problem with an LG over the range microwave. Several of the positions on the touchpad quit responding to touch. In our case, it was the touchpad itself that was the problem.
The touchpad on our microwave was held in place with adhesive. We pulled it off and replaced it with a new touchpad. Everything works now. The only complication is getting to the connector which carries the signals from the touchpad to the microwave controls. We had to remove and dissassemble the door to get to that connector.
The touchpad cost about $26.00.
Oct 09, 2009 | Whirlpool MH7140XF Microwave Oven
Start Button Failed on Whirlpool Electric Range Model GY396LXPQ02
It sounds like you have an oven problem rather than a start button problem. Is there an error code? If so list your model and error code on a search engine and you will find error codes. Or you can just list make model number and error codes and you can find a chart of Whirlpool error codes. I have done this with no problem. That should tell you the exact problem and things to try.
It may be neither issue you mentioned. It could be a bad element or a short.
May 29, 2009 | Whirlpool GY396 Electric Kitchen Range
Kitchen Ranges Logo
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
