Question about Crate Music
I have a Crate pa-4+ amp and need to remove it from wooden box to repair it, how do I get it out of the case?
2 Suggested Answers
  • 1138 Answers
SOURCE: looking for manual for crate PA-6 FX pa system
Here is the link:
Posted on May 19, 2010
Crate gtx212 mute circuit (Q24 across IC4A pins 1 and 2) should go positive on the gate when a plug is inserted.
Looks like Q24 changes the gain at IC4-A from low with no input jack to normal gain with a jack inserted. Since this appears to be a guitar amp that expects a floating input plug any connection at the input to say, a mixer etc may cause a re-grounding via that equipment's circuits, thus negating the auto mute...... eggs & suck :-) If using a moving coil meter it could upset things.... an interesting fault! Sorry I can't be more help - Good luck!
Feb 11, 2017 | Crate Music
Effects don't work
On some amps there needs to be a footswitch inserted in the control jack to activate the effects circuit. Contact Crate to see if that's the case with your amp.
Jan 28, 2014 | Crate CA30DG Taos Acoustic Guitar Amp, 30...
I have a Crate PA-8 4 ohm 150 watt PA head that I run to four Peavy 10" PA speakers (two per side in series). It was very good, clean sound, but the speakers were cheap and may have been pushed too hard -...
150 watts should be easily handled by four Peavey speakers in the connection you described.. If the Peavey's are 8 ohms, then your total load was 8 ohms for the series/parallel arrangement which is well within the 2 ohm drive capability of the Crate according to specs.
I question if you really mean the speakers were in series? This requires a special cable to do this. Now if you mean they were "daisy chained" like the amp went to one speaker and another cable connected that speaker to another, then you REALLY had ALL speakers in parallel electrically which would be at the 2 ohm low limit of the amp... In either case, with only 1/4 of the 150 Watts to each, the speakers should NOT have been damaged. The amp MAY have been damaged. Try each speaker individually at a REASONABLE level to test.
If you plug into the effects loop out jack,OFTEN the connection to the internal power amp is broken so you might have to arrange a special cable as a wye to go back into the power amp as well as your external amp. In any case pwere ALL interconnected amps, etc from the same power source/receptacle for system safety.
Jul 15, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Looking for manual for crate PA-6 FX pa system
Here is the link:
Apr 29, 2010 | Music
Buzzes and feedback
Make sure the "ground lift" option is used on the direct box.
DO NOT UNDER ANY CIRCUMSTANCES use a headphone output jack as the output of this unit. The headphone jack is for HEADPHONES that have no return to ground. Use of this as drive to a sound board is sure to cause problems and in some cases can fry these amps due to the circuitry.
The cable used to go to the direct box should be very short and high quality.
You should source the power for this unit from the SAME source and receptacle as your sound board if at all possible.
Nov 08, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
I have a crate PA 8 and it makes a crackling noise when I play through it. I hooked the speakers to my other amp and they sound good, I hooked the PA to my marshall cab and it still has the noise, so I...
The problem is with the amplifier itself. Crackling is usually capacitor related and you will need to have the amp checked over to properly identify the cause.
Some amps are also prone to pick up static from other electrical items which can also cause these problems. I had a crackling issue with an old Crate amp of mine which turned out it was due to being too near a computer/monitor so it is worth eliminating these things as a possible cause before having the amp checked.
Hope this helps. Thanks for using FixYa.
Oct 28, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
I have a Crate PA-8 that hasn't been used in a long time. I destress and sing. Anyoo it has a power issue. Light is flashing on then goes off. I can't find a manual. Can anyone assist me please?
you have either a failing fuse or a failing power transformer. take out the screws on the top of the amp, leave the handle in tact and pull out the chasis. look at your fuse to see if it is in its holder correctly, and see if the fuse is burnt. the correct fuse values will be printed on the circuit board. if the fuse looks good then, it may be the power tranny going south.
May 08, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Amps broken need to fix it
Their may be a schematic on the inside of the amp.I don't remember if Crate puts one or not. And I have had several Crate amps. never needed repair except for tube replacement. If there is not one in side , go here and find what you need . Good luck DFD please rate me TK U
Apr 18, 2009 | Crate Music
Plugging line level into my crate TX15. all inputs sound distort
guitar amps are all set to a low Z resistance configuration. wich are made for guitar only. make sure you are using the right cables.
you need sheilded guitar cable not unshielded speaker cable in many cases these cables look exactly the same. look at your cable look for the words speaker or instrument. you need the instrument cable. if you still have that problem. then you may just not be satisfied with the quality of the amp it self.
Feb 26, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Music Logo
Top Crate Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Crate Music Expert? Answer questions, earn points and help others
