Question about Bosch Refrigerators
Our Bosch Fridge freezer KGV28V00GB it is situated in our utiliy room which is not heated. it is giving off an awful smell which I think is a gassey smell- any ideas as to what is wrong please
    Top Expert:
  • Bosch Master
  • 40,357 Answers
Refrigerant leak. Time to retire it.
Posted on Dec 05, 2016
To changedoors from one side to the other. KGV28V00GB/01FD
all you should have to do it unscew the doors and on the opposite side there should be caps, take caps off and move the hindges to the opposite side.
Jan 25, 2012 | Bosch Classixx KSR32623 Refrigerator
Bosch Exxel KGV28323 fridge freezer. When door is shut the light goes dim but not completely off. Thinking a dodgy contact might be the cause. Have replaced the switch but no change. Have rcd fitted and...
I thought the same with mine, but its supposed to, there is a switch near the thermostat, if you turn it off the light will go off when the door is shut, you are supposed to leave it on if the room the fridge is in is under 18 degrees, the heat off the dim bulb stabelises the temperature and keeps the freezer working
Jul 02, 2011 | Bosch Exxcel KGV35421 Bottom Freezer...
I have a Kenmore Elite refrigerator model number 59673503201 and there is a terrible fish smell coming from the bottom portion of the appliance where the freezer is. It is not coming from trash, or food...
Please note when you keep fish in freezer once, the smell will be longer even you remove it. O.K. Now solution for your problem- Please unplug power.Keep fridge door open. Take wet cloth dipped in soap water and clean all compartment including freezer . Keep freezer door also opened.Then clean with dry cloth. Spray room spray in your room not into the fridge. And allow 5 hrs to circulate fresh air to pass thr' your fridge and then close fridge and freezer doors. Plug fridge and run for one hour on empty. After one hour store items in fridge and/or freezer.
Keep all food items in closed style which will avoid odor spreading and also be a hygienic. Thanks.
Jan 30, 2011 | Refrigerators
Oder in freezer and refrigerator
the smell is bacteria caused by the buildup of moss from condensation.switch off unit do a complete defrost,( leave the doors open).wipe out the interior with chlorine bleach(the smell will go in about an hour or so)syringe the drain with bleach and then dry thoroughly.after drying switch on and leave to settle for 24 hours to regain operating temp(fridge +2/5c...freezer -18c)then refill with food,covering any open dishes.try to fill all drawers in freezer with food and any spare space fill with screwed up newspaper.
use a toothbrush to get into door seals/corners DO NOT USE HEAT/SHARP OBJECTS TO DEFROST.use towels in bottom to soak up all the water....
Jul 30, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
There is a horrid smell coming from the back off my candy fridge freezer its a sicky cheesey smell what is it??
little green men from the planet DRAIN PIPE , awful smelly these people.. have lost the ability to flush out drainpipe with clorine beach (only drainpipe NOT INTERIOR OF UNIT)
Sometimes called streptococus..............
Feb 08, 2010 | Candy CPCA240FFK Bottom Freezer...
Hot plastic smell
For now I think it would be a good time for the ice maker to be unplugged from the inside wall of freezer. Sounds like the heating element under the ice maker is remaining on. Let me know if its hot under ice maker. Even so this is something we need to find now. Sea Breeze
May 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Bosch classixx fridge freezer - smell coming from fridge. Can only smell when door opened.
bad eggs smell coming from behind Bosch fridge freezer. There is no bad food in fridge. Any comments appreciated. Linda
May 02, 2009 | Refrigerators
Open Questions:
Bosch Fridge Freezer Model kan60a45g - Water Dispenser is not working, only a tiny dribble!! I've proven water flow to the egress / exit of the water tank... I have a Bosch American Style Fridge Freezer Model kan60a45g. The water flow out of the built in dispenser has gone from perfectly fine to a tiny dribble, it was gradual and I assumed it was the filter needing to be replaced. However replacing the filter seemed to make it worse, so I replaced filter with the plug in order to remove it from the equation. It still didn't work, so I went to the beginning of the flow and confirmed the pressure / flow into the "in pipe" was fine. I then checked flow to and from the filter unit, again fine. Down now to the inlet valve (I think it is called) and I checked all the valves worked here when required - they do. Next I checked the flow at the point of entering the water tank which sits in the fridge. It seems fine. I removed and flushed the tank and confirmed there are no problems with its flow when refitted. So sadly it seems the problem is somewhere between the exit of the water tank and the outlet in the freezer door itself. Everything else is checked out. I cannot see how the pipework runs from the fridge side into the freezer section and then up through the hinge of the freezer door. Does anyone have any suggestions? Ideally I suppose I would remove and replace the pipe - it has to be blocked somewhere I guess? Could I blast with compressed air? If anyone has experience of this issue, or knowledge of how to remove this last bit of pipe work then I would be very grateful. Thanks in advance!
Mar 01, 2018 | Bosch Refrigerators
Refrigerators Logo
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
