Question about Coffee Makers & Espresso Machines
My 800ESXL switch is not working when i turn it to brew coffee unless i turn the machine on and off several times to make my espresso, it works for the steam and hot water when turn to the left.
SOURCE: frothing tube
Sheryl,
It sounds like the tube is clogged.  Remove the silver tip on the bottom of the tube.  Hold it up to the light and see if you can see through it.  If you can not, take a tooth pick and clean the tip out.  This seems to have worked for mine.
Adam
Posted on Oct 24, 2007
SOURCE: espresso won't brew
same prob
Posted on Apr 23, 2008
SOURCE: Problem with espresso - no water to the brew head
We just bought the unit today before researching the product online. Same problem! Will try to return tomorrow.
Posted on Jun 26, 2008
SOURCE: Froth control problems
Your vinegar did the job: it as removed the deposits, now these deposits are clogging the four holes porcelain valve.....if the froth lever is not broken.
Remove all the screw you can see on the top and under the top of it, remove the cover, unscrew the frothing device down to the porcelain valve consisting of two 4 holes discs, clean them, and voila!
Posted on Sep 22, 2008
z34aga
  • 137 Answers
SOURCE: Water not coming through espresso side although steam wand works fine
you both can have same problem, solution is:
  1. low pressure of pump (or too fone grinded coffee)
  2. security valve of boiler openes to early and dont let the pump to rise pressure enough for good brewing( if it is this you can see water returning back to container if you have 2nd pipe in your machines reservoir)
Posted on Apr 02, 2009
Coffee side beeps 3 times and does not brew. Espresso side and frother are fine
KRUPS XP2280 Espresso Machine and Coffee Maker ...
www.amazon.com/KRUPS-Espresso-Combination.../B...
Amazon.com, Inc.KRUPS XP2280 Espresso Machine and Coffee Maker Combination with ... Theespresso side is literally idxxt proof with the built in tamper system and ... Theespresso does not brew after waiting for the light to turn solid and simply pushing 1 or two cup selection. I often have to push 3 or more times and it still doesn't work.Missing: beeps
KRUPS XP2280 Espresso Machine and Coffee ... - Amazon
uedata.amazon.com > ... > Espresso Machine & Coffeemaker Combos
Krups is pleased to present our new XP2280 Combi Espresso and Coffee ... Theespresso side is literally idxxt proof with the built in tamper system and ... Theespresso does not brew after waiting for the light to turn solid and simply pushing 1 or two cup selection. I often have to push 3 or more times and it still doesn't work.Missing: beeps
Troubleshooting Semi Automatic Espresso Machines
www.espressoplanet.com > Articles > Support > Troubleshooting
Oct 24, 2010 - We do not encourage anyone to open up the machines and try to repair them and if you ... (The water will be moving through the holes between the coffeegrounds ... The portafilter doesn't stay in place in the group head while brewing. ....Jura, Solis, Saeco, Krups, Capresso, Gaggia, Rancillio, Nespresso.Missing: xp2280 ‎side ‎times
Jan 28, 2016 | Krups XP2280 Combi Espresso & Coffee...
Cannot remove stainless steel brew head
Hi Roberto, thanks for your message.
I am quite sure that the brew head removal will be described in the service manual. I found that here:
http://tradebit.com/visit.php/84445/product/-/150234770
Dec 08, 2011 | Breville Die Cast 800ESXL Espresso Machine
My steamer on my Breville Die Cast Expresso machine no longer works, I have cleaned it, soaked it in vinegar. Any ideas?
Pleas do not soak this in vinager, try this process with vinager and most cost efficient way to fix this issue with HEAD SPRAYER HOLE clogging is to run vinager through the system several times. The compounds in the vinager serve as a cleaning agent to clean the heads naturally and allow the coffee to travel once again in the same holes it did when you first purchased the unit!!! Just fill up the pop with straight vinager and allow it to run through the system just as if it was coffee! This WILL NOT have any harmful affects to you or the coffee system unless you are allergic to vinager.
Jan 21, 2011 | Breville Die Cast 800ESXL Espresso Machine
I've A Breville 800 esxl espresso machine.when making an espressothe machine starts leaking from the external slots outside coffee filter holder.what is the cause of it?
Breville brew head seals are rather difficult to locate, but I personally stock them for ESP8XL & 800ESXL machines and sell them at a reasonable cost. I sell lots of new and used parts for various coffee machines, but specialize in Krups and some Breville. If interested in purchasing a Breville brew head seal, contact me at cowboy_romeo@yahoo.com and I'll make arrangements. I accept Paypal to make the transaction safe and secure for us both.
May 21, 2010 | Breville Die Cast 800ESXL Espresso Machine
Cleanded brew unit as instructed - brew unit miss error
check small switch behind brew unit in machine maybe your brew unit dont touch switch.
Aug 30, 2009 | Saeco Royal Digital Plus Coffee...
In standby mode water tank continued to completely
Try backwashing the machine with espresso machine soap. There might be something keeping the brew solenoid discharge open.
May 17, 2009 | Breville Die Cast 800ESXL Espresso Machine
Need to know the correct tamper size for a Breville 800ESXL ??
I found this one on ebay:
http://cgi.ebay.com/TERRYS-ESPRESSO-COFFEE-TAMPER-50-55mm-DUAL-SIDES_W0QQitemZ330319118719QQihZ014QQcategoryZ20671QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
the 50mm side works perfect for the Breville 800ESXL and the material matches the machine. It takes up less space than the original spoon/tamper combination and sits nicely on the warming surface when not in use.
Mar 29, 2009 | Breville Die Cast 800ESXL Espresso Machine
BrevilleUSA.com has a silicon seal (steam ring) to replace faulty or worn ones. There is no shipping charge, and they are $4 each. To replace the steam ring you'll need to remove the stainless spray disk on the brew head with a phillips screwdriver (one screw) and pull off the old ring (pay attention to the direction and placement of the stainless disk).  Takes about 2 minutes to do.
Part # .800ESXL/192
Also, on mine I noticed that the filter holder was ground down at the factory a bit too much on one side, which causes a slight leak down one side (coffee, not water).  You might check the holder (with the filter removed) for imperfections that could lead to your leak. Good luck.
Feb 17, 2008 | Breville Die Cast 800ESXL Espresso Machine
Breville 800esxl
A card included in the operating manual indicates that this is normal. The Breville "Dual Wall Crema System" will do this. Visit www.breville.com for more information.
Nov 22, 2007 | Breville Die Cast 800ESXL Espresso Machine
Coffee Makers & Espresso Machines Logo
26 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
