Question about Whirlpool Washing Machines
Want go into spin cycle ive change motor speed contol
    Sergeant:
  • 175 Answers
Hi..It sounds like the timer assembly might have got
into trouble.
check it out..
thank you..
kindly rate my response..
Posted on Jul 20, 2009
THE MACHINE RUNS VERY WELL QUIET UNTIL THE FINAL SPIN CYCLE THEN FROM THE BACK OF THE MACHINE THERE IS A SQUEAL THAT GETS LOADER AS THE SPEED PICKS UP
This may well be the drum drive belt in the back of the washing machine. This belt transfers drive from the motor to the drum for both wash cycles and spinning. If the belt is slipping slightly on the pulley then a squeal may well be heard on the spin cycle and will change in pitch as the speed of the drum increases. At lower speeds (wash cycles) the belt probably won't slip. I don't personally know of this model but there is usually a tension adjustment nut/bolt near the motor to tighten the belt and stop it slipping.
Dec 26, 2013 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Clothes are still wet after full spin cycle
Possible that the SPIN Speed is too low, check the drive, the RPM of the motor. Check for friction of the spindle , check for free movement of the drum. If you notice a change then you will need to reset the mechanism. If the motor speed is low check the capacitor.
Jan 24, 2013 | Hotpoint WMA64 Front Load Washer
Soaking wet clothes after spin cycle
Check and choose a longer spin cycle and see if the fault changes. If so the SPIN cycle is too less or there is less action or speed in the cycle, check the motor speed, check the capacitor to the motor, the spindle friction - if so reset the spindle and drive.
Jan 17, 2013 | Washing Machines
Spin not working
hello it may be down to the module board this controls the spin speeds i hope it helps
regards
shaun
Mar 02, 2010 | Washing Machines
Maytag Washer LA712 spin cycle question
Remove the front panel (2 screws bottom front) and then put the machine into the spin cycle. Be VERY carefful as the transmission also spins and can really injure you if you get to close. Observe the speed in the spin cycle. Then grab the plastic motor cover and gently pull the motor toward the outside corner. If the spin speed increases then you have a problem with either the 2 springs or 4 rollers inside the floating motor mount. See this link http://www.appliancepartspros.com/partsearch/model.aspxmodel_id=28967 The Matag part number that would be the ideal fix is 2-5000. To change the rollers you must remove the pulley and motor mount.
The springs are Item 18. You may have to explain to any parts center what rollers you want.
Jan 12, 2010 | Indesit W 123 Front Load Washer
Front Load Maytag Neptune won't spin.
check the board
is the resister thats burning r-11
if it is you need to change the wax motor lock as well
its the door lock found where the door latch goes in
ive included the part number 22002119
they should have told you
Oct 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/ http://www.davesrepair.com/DIYhelp/DIY285753.htm
Sep 01, 2009 | Kenmore Washing Machines
Alll the water does not spin out , clothes still wet
Your clutch is wearing out and needs to be replaced. It will only get worse. Ive included a schematic , part # is 285785. #5 on the schematic. Let me know if you need more help, thanks dave www.washermd.com
Dec 17, 2008 | Kenmore 22422 Top Load Washer
Intermittent spin cycle on Kenmore 90 Series washer
You may try the speed selection switch.....Ive had problems with these.
Jan 23, 2008 | Washing Machines
Hotpoint Aquarius WMA46 front loader
I 've had this problem a few times with these machines.
Some solutions that have worked for me are.
1 change the motor.
2 change the wiring loom
3 change the board.
The most common one is the motor even when the it has decent brushes the motor just will not pick up speed on the spin cycle.
hope this helps.
Dec 14, 2007 | Hotpoint WMA46 Front Load Washer
Washing Machines Logo
19 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
