Question about Pool & Spa
I have an index hot tub it's not heating up ,read your answer about the temp thing,mine ran all day and the temp got 66degrees,
    Top Expert:
  • Pool & Spa Master
  • 8,688 Answers
Check heater fuse and heater element
Posted on Nov 12, 2017
dogcatstiger
  • 5 Answers
SOURCE: Goodman compressor cuts off when temp too high
When the condenser coil is dirty come high pressure and cut out the compressor, you can wash with the garden hose around the condenser coil before disconect the unit for prevent any electrocution or the sistem is overcharged
Posted on Aug 07, 2008
gary1121
  • 332 Answers
SOURCE: infiniti hot tub reads HL
the pump just pumps, do you have a heater it would be about 2inch in diameter adn in line with a cord comming off of it that plugs in seperate from the pump that is the heater,
Posted on May 29, 2009
  • 323 Answers
SOURCE: Water not heating
It sounds like your inline heater has stopped working. The only way to test it is to drain the water back out, remove the inline heater, and hook power to it to see if it heats up.
If it doesn't you can get one at a discount supply house (like Home Depot or Lowes) for less than $150.
Posted on Jun 04, 2009
  • 366 Answers
SOURCE: I have a 2004 great lakes hot tub with a balboa
check to see that the flow switch is working properly, it may not have enough flow on low speed to allow the heater to turn on. Make sure your filter/s is/are clean. If you have a pressure switch instead of a flow switch, it may need to be adjusted or replaced.
Posted on Feb 09, 2010
Coastsider
  • 331 Answers
SOURCE: mystic hot tub doesn't stay hot enough
Is your spa wired for 110Volt or 220V?
Posted on Apr 14, 2010
Woke up one morning last week hot tub was reading 212 and water is cold. turn off and on unpluged it still reads 212 3 days later
temp sensor is bad most likely. Control registers 212 degrees so there is no need to turn on the heat. Either that or the controller itself is reading the sensor improperly.
Oct 01, 2017 | Washing Machines
My cars temp suddenly ran in the red (hot) so i turned the heater on to cool it down and the heater would only blow cold air what could this be?
"ran hot and the heater only blows cold air"
First thing that came to my head reading this is check the coolant level.
Aug 31, 2014 | Cars & Trucks
Jacuzzi hot tub will not reach temp pumps do run?
If your hot tub is running but NOT heating then you need to look at a couple of things.
First, on the topside, is the heat indicator light on?
If it is on and the tub is not heating then the temp sensor or the high limit sensor is not working and need to be replaced.
US Parts Center
Oct 22, 2013 | Jacuzzi Home
Random multiple misfire code. Cat gets glowing red hot. Sluggish lack of power/acceleration
Combining the hot cat converter and the missfire code, I would lean toward a fuel problem. Too lean or pressure too low.
If it was an ignition problem the cat would usually not be hot.
If the exhaust was stopped up, you would not usually get the multiple missfire issue. Just lack of power.
It could be a leaking EGR or other vac problem, and a dirty fuel filter too.
Jan 23, 2013 | 2003 Chevrolet Cavalier
I got in the tub one night after the filter had been cleaned out by the roomate who kept the tub running. That night the temp read 94 but was set to 99. Then the OH light came on with Balboa topside...
at pump housing is an upper/lower bleeder ( about 1/2 inch bolt ) unscrew the bolt letting air out until water runs out than tighten turn on unit and loosen bleeder again bleed out any leftover air tighten
Oct 25, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Water not heating
May 28, 2009 | Home
QCA Opal hot tub display reading OH.
The tub experienced an overheat situation. This may be due to leaving the t stat turned all the way up and not monitoring or the hi-limit sensor is defective. The hi-limit sensor will shut down the heating cicuit if temp gets above 105 D optimally.the fact that the heater light is on is a good sign that things are working at this point.Whether or not a suitable temp(100-103 D) will be arrived at is to be seen. If spa heat kicks off before set temp is reached then replace hi-limit sensor.
Apr 10, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
2001 Kia Optima over heating
I figured this out and fixed it on my 2001 Optima. Mine was an electrical problem, not an overheating problem. The problem shows up when there is a heavier than normal load on the electrical system. For most of us, this is when the air conditioner is running full-blast on a hot summer day. However, it was also occuring when I ran the heater full blast. The heater running full-blast should have lowered the temperature, not raise it. So I tested the coolant temp while the gauge was showing it overheating. The coolant temp was not increasing, but the gauge showed that it was. It is caused by a bad ground connection. Another test you can do to see if your problem is the same as mine is this. As soon as the engine is showing overheating, pull over, park the car and turn off the engine. Immediately start the engine again and see what the temp gauge shows. If it still shows hot, you'll know you've really got overheating coolant. If it goes back to normal range, you'll know it's just a bad ground connection. Turning off the engine eliminates the resistance in the electrical system that has beeen building up and causing an erroneous high temp reading.
To fix: Either find and clean ground connections throughout the vehicle until it fixes it, or do what I did. A mechanic at the Kia dealer showed me this. I ran a new wire from an empty bolt-hole on the top of the engine to a bolt into the frame behind the engine. I only added a 6 inch wire and a new bolt into the top of the engine. The bolt into the frame was already there, so I just removed it, put the wire under it, and replaced the bolt. It created a redundant ground that prevented the build-up of resistance that caused the erroneous temp reading. It was a 5 minute fix and it has never done it again. Kia knows about this problem and they put out a post to their shops on how to fix it.
Jul 18, 2008 | 2001 Kia Optima
Pool & Spa Logo
130 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
