I have an old WP-9916PT, how can i get it to drain?
Where do I find the filter on a Whirlpool top loader - our clothes regularly need re-washing as are covered in fluff?
have you check the outlet drain hose for blockage? go online check your wp model for built-in filter if any. if there is one you need the washmachine schematic show the location of the filter. most of the old machine may have a panel on the backside to access. this way you can get to the filter.
Mar 03, 2015 | Whirlpool 358276 Topload Washer Water
How do I get my Brother T/W./W.P. model AX 430 to type in normal mode from switch on as it's 5 years old ?
Go to brother.com poke around you will find typewriter manuals it may help and it's free.
DickyO
Jan 26, 2015 | Brother Office Equipment & Supplies
How do I replace pull starter rope?
remove the pulley housing cover.Remove the remaining rope pay attention as how its' threaded.Loop the new rope exactly as the old one.That's it
Oct 21, 2012 | Mi T M Mi-T-M WP-2403-3MHB NA 2400 PSI 5.5...
This unit is 15 years old and the drain tube was never hooked up believe it or not and it leaked terribly with now a rusted out bottom. The unit works however and I was wanting to fix it. Can a new...
IF YOUR UIT IS IN FACT 15 YEARS OLD IT CAN NOT BE A WKL MODEL, WKL ARE DIGITAL UNITS, WHAT YOU HAVE IS A WK4000 WITH A SCREW TEMPERATURE ADJUSTMENT IN BETWEEN THE GRILLS.
A 15 YEAR OLD WK 4000 IS AN R-22 SYSTEM AND NOT WORTH REPAIRING AND IF THE METAL IS RUSTED YOU CAN NOT BUY MORE METAL BASES FOR THAT UNIT FROM THE MANUFACTURER, BREEZAIRE HAS DROPPED ALMOST ALL THE COMPONENTS FOR THE UNIT ONLY THINGS AVAILABLE ARE FANS,COILS AND THERMOSTAT.
BUY THE REPLACEMENT WKL4000 DIGITAL SAME DIMENSIONS AND COOLING CAPACITY.
http://www.breezaire.com/wp-content/uploads/2011/04/WKL-Insrructions-3-11.pdf.pdf
CHECK THE LINK FOR THE INSTRUCTIONS ON THE NEW WKL UNITS
Sep 19, 2011 | Breezaire WKL 4000 Wine Cooler
Water gets drain cannot remain in the tub for wash ...type of my washing machine is LG WP 9031 top loading semi automatic..
The drain is pull the knob which will pull up the drain valve. So if this is not working then the connecting bowden is broken and is not connecting the link to the bottom drain valve.
Look at the bottom and connect. Clean the drain valve, if choked.
Sep 14, 2010 | Washing Machines
WP Dishwasher leaks when washing but not when draining.
This type dishwasher has a gasket/seal beneath the lower rack (sump gasket)
You would be able to see it if you pulled out the lower rack and removed the lower arm and filter (please only do this if you are mechanically inclined. Also, replacing a sump gasket is a MAJOR repair and pretty tough to do. You don't say how old this dishwasher is but if it is more than 4 years old, unless you have an extended warranty, it is probably best to replace rather than call for repair service.
Mar 28, 2009 | Whirlpool 24 in. DU948PWPQ Built-in...
WP ADG450, will just recycle the water and not use fresh water
I have had same problem and i cured it by refilling dishwasher salt which hadnt been done in a long time. hope it helps. S
Feb 08, 2009 | Whirlpool ADG450 Slim-Line Built-in...
Old brother word processor/electric typwriter WP-3550, any idea how to get it to type? is there a command? any place i could find a manual?
Hit the TW/WP key on the top row of the keyboard. TW/WP stands for typewriter/wordprocessor. This toggles between using the word processor manually (like a typewriter) and using the monitor to enter text and then automatically print it out (like a word processor on a computer). My guess is, you do not have the monitor that came with the word processor. I believe it will still work once you press the TW/WP button. Hope this helps.
Apr 16, 2008 | Computers & Internet
Washing Machines Logo
Top Washing Machines Experts
