Question about Garden
Troybilt TB90BC starts but wont run. - Garden
  • 130 Answers
Take a compresstion test at lease 50 psi to run good. if thats ok rebuild carb and replace spark plug and gap at 030.
Posted on Jul 21, 2009
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy bilt troubleshooting
what are you trying to troubleshoot? heres the troybilt link to get you started
http://www.troybilt.com/equipment/troybilt/lawn-mowers/lawn-mowers?facet=cas_f9_ntk_cs%253A%2522Zero%2bTurn%2bTractor%2522&sortBy=3?cm_mmc=Google-_-Mowers-_-Zero%20Turn-_-Sponsored&gclid=CjwKEAjwi6OeBRCCrZqp-qaQhhISJACrfbtAq_Hepy9R8IgJYw_E9HkmY0pum-PDxyoqjOrFfOWq-hoCAknw_wcB
Jul 17, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
Troy bilt weed eater
I have a troy built 2 cycle pro-line tb90bc spring assist trimer.
its getting fuel and it wouldn't start I took out the spark plug and it was wet with fuel. pls fwd any info to ss.beepat@hotmail.com
May 06, 2013 | Troy-Bilt Tb90bc 17-inch 31cc 2-cycle Gas...
TB90BC WON'T START
hello sir, my machine will only start when pumping primmer bulb or squirting fluid in the carburetor than stops. the fuel line has broken off, in most small carburetors this is a ongoing problem.old fuel will crystallize when left in tank for a long time.plugging up ports, fuel lines, small screen in carburetor.fuel lines will dissolve clogging carb.this is why it will run when the choke is on creating a vaccum to where there is fuel forced in the carb to rum,also the gas will evoporate leaving the oil behind clogging up carb.the thing to do is remove carb. and clean out,replaceing gaskets or fuel line if necessory.use carb cleaner to clean out carb.make sure to make note where fuel line go.the fuel filter broke off of fuel line letting debris get in carb plugging it up.the muffler is known to clog up a lot on these machines where thay want run. the compression should be 60 to 120 lbs any thing below 60 is junk. when adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow untail machine runs also you need to check for spark by removing plug and grounding aginst engine to chech spark, ok.a new spark plug would be a good ideal too , if you are going to make these repairs use new fuel line and filter,hope this helps,any comments welcome,thank you, ``
Feb 06, 2012 | Troy Garden
I need troy-bilt trimmer TB90BC engine schematic or manual for model# 41BDT90C711
you should be able to find the manual for the trimmer from their web site... you need both the model number and serial number to get the manual. i'll put the address you need below
Canada
http://www.troybilt.ca/troybilt/troybilt_manual_search.asp
US
Hope that helps
Aug 27, 2011 | Troy Garden
Troybilt tb4bp blower was running then just stopped and wont restart as if no spark
May be out of gas..or the gas line has broken inside the tank Check spark plug, clean or replace Start with new gas
Oct 05, 2010 | Garden
Troybilt TB90BC fuel line schematic? I have replaced fuel lines that degraded with age and am uncerttain about the correct hook to tank, carburetor and primer. A diagram would help
easiest way to tell you is that the primer is there to pull the fuel through the carb. so fuel filter line goes from tank to carb, then from carb to primer and then back to tank as a return. if you forget which is the in line for the carb just hook with gas in a jar and try sucking it out of the jar. put filte rin a jar. and run line to carb , then line out of carb to primer and line back to jar as a return. if it pulls freely and fills the primer bulb your ready to go. if it pulls hard or not at all something is wrong.
Aug 15, 2010 | Troy-Bilt Garden
I have a Troy-Bilt TB90BC string trimmer. The engine starts & runs fine but the trimmer head runs slowly and stops under light loads. I removed the lower shaft & confirmed the cable connection is...
it sounds like the clutch may have oil on the shoes or oil in the clutch drum if it has a clutch or the clutch is binding and not fully locking up.
May 02, 2010 | Garden
Troybilt weedwacker won't stay running. It starts
you may need to rebuild the carburetor.Check all the gas lines for cracks or leaks.Check the primer bulb if it has one.Then try and readjust the carburetor.If that still don't work,then try to rebuild the carburetor.
Sep 02, 2009 | Garden
Troybilt 6.5 wont start without some help
Check to see of where the canles connect to the linkage, there are usually thumb nuts you can adjust similiar to that of the brakes on a bicycle handle bar.
May 30, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
789 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
