Question about Coffee Makers & Espresso Machines
The DCC 1200 is Boiling the water away before the coffee is completed HELP...machine is less than one year old
  • 5 Answers
SOURCE: Setting the Time
First, turn the Function Knob (bottom-left of the Control Panel) to “Clock”.
Hours: Press and hold the “HR” button to go through the numbers quickly. When the number displayed approaches the desired setting, release and press(pulse) the button to advance one digit at a time.
Note: When the number passes 12, the PM light will be displayed on the LCD.
Minutes: Press and hold the “MIN” button to go through the numbers quickly. When the number displayed approaches the desired setting, release and press (pulse) the button to advance one digit at a time.
To finish setting time, turn the Function to any setting other than "Clock", or simply wait until the numbers stop blinking.
Posted on Aug 05, 2008
  • 19 Answers
SOURCE: slow water drip
First of all it depends on the hardness of the water. Vinegar doesn't really work in the heavy lime belt area of the midwest. It is better if you use lime away. It is an ecolab product that is great at lime removal. Use one cup per pot. Then rinse two pots worth if this is the kind of machine that uses the same water that is put in during each brew cycle. Some brewers have a reservoir. Bunnomatic is an example of that kind of brewer. If you use lime away in that kind of brewer you need to run about thirty pots to remove all the lime scale remover from the brewer. Slow brewing can also be caused by over softened water. I drove from Indy to Iowa after installing a brewer and then a day later the store put in a softener and over softened the water causing the coffee filter to clog up with sodium. Also check the sprayer disc or head where the water comes out. Over time coffee "paste" will build up around the outlet and if you don't wipe it clean or "smear" the coffee grounds around the outlet that will slow down the brewing cycle. I have thirty years as a brewer technician and it is usually one of the things I have covered, providing that the heat element isn't defective.
Posted on Aug 20, 2008
SOURCE: One year old coffee maker won't brew
This is my second dcc-2000 with the same problem. I tossed the first one and in less than a year the second one exhibits the same issue. I called the Customer Service (1-800-726-0190). The rep told me to unplug the unit for at least 2 hours adding that this would let the system "reset itself". He then instructed me to run vinegar and water through it to clean the pumping system. I am doubtful about this solution but the rep assured me it would be replaced if I still have problems. It's worth calling CS to get it replaced, however, it seems that this model is flawed by design.
Posted on Aug 21, 2008
SOURCE: Cuisinart DCC-1200 BW Model leaks
Order 1 foot of 5236K73 "High-Temperature Silicone Rubber Tubing" from McMaster-Carr. Put the old check valve in the new tubing in the same location and direction as originally installed.
Posted on Feb 01, 2009
  • 61 Answers
SOURCE: DCC-1200 coffeemaker cleaning button flashes
Make sure that when you do the vinegar solution, you do at least 4 cups of white vinegar, and fill it up the rest of the way (max fill line) with water. The manual says to "fill to capacity with a mixture of 1/3 vinegar and 2/3 water," which lots of people misunderstand, and think it means "1/3 CUP vinegar and 2/3 CUP water," which is not the case. It means 1/3 of your 12 cups (and 1/3 times 12 is 4 cups) of vinegar, and 2/3 of your 12 cups (aka, fill it up the rest of the way) of water.
You might have to let it soak for an hour before you try to brew it--this lets the vinegar work at the calcium buildup a LOT better (kind of like soaking your pots and pans before you try to clean them), but it should definitely work for you. If not, call Cuisinart's tech support (1 800 726 0190) and they might be able to get you a replacement :)
Posted on Aug 21, 2009
The red brew light comes on but will not brew about 3 years old
Amazing! My dcc-1200 developed the identical problem on the identical day. Sounds like planned obsolescence. I will watch this space for solutions. Sorry I can't help; I'm frantically looking for my receipt.
Dec 03, 2012 | Cuisinart DCC-1200 Coffee Maker
We've had a Cuisinart DCC-2000 coffee maker for less than a year: 1) it stops brewing about halfway through the brewing cycle (with plenty of water still in the reservoir, and 2) the "Clean" light
This problem is caused by a clogged water filter in the unit.
Unplug the coffee maker.
Open the top panel where you normally pour in the water and set the coffee filter.
Gently pull up on the tap that sticks up in the back left corner of the open top. This will free a long plastic part that has a compartment at the bottom that contains a filter filled with charcoal.
Unsnap the small compartment that holds the filter and clean it gently under running water with light brushing.
If there is a lot of coffee build-up, the water chamber where you normally pour in fresh water needs to be cleaned out. Pour in a cup of water and invert the unit over a large sink pouring out the water through the opening you normally use to fill the unit.
Repeat this until you remove the coffee grounds.
Let the unit dry fully before plugging in to run again.
Sep 30, 2012 | Cuisinart DCC-1200 Coffee Maker
I have a DCC-1200 brew central 12 cup.. i put water in the pot, checked to see if the filter was in place, set it to brew, and turned the switch to "on" position.. but I don't hear any noises and no water...
Sounds like a short. Call cuisinart they are very helpful for troubleshooting. If your machine is under 3 years old they will replace it for $10. Their number is 1-800-726-0190
Jun 30, 2010 | Cuisinart Brew Central 12-cup Coffee Maker
Our Model DCC-2200 started boiling and then smoking from the plate.The unit is approximately 2 years old.
The thermostat that controls plate temperature has stuck closed. Stop running the machine until this problem is repaired. A thermal safety fuse should have blown (stopping any further heating).
Feb 02, 2010 | Cuisinart DCC-2200 14-Cup Coffee Maker
I have lost by cleaning manual for my dcc-1200 coffee maker. I need to clean it the light won't shut off. Thanks, Dawn Miller
Fill water reservoir with 1/3 carafe distilled white vinegar, 2/3 carafe water and hit the self-clean button - it will take about 35 mins to complete. When it is done, it will beep like it normally does when brewing regular coffee. Self-clean light should go off after this. If it doesn't, simply unplug the machine for 20 minutes or longer. The manual is available for your inspection on the Cuisinart website.
Sep 07, 2009 | Cuisinart DCC-1200 Coffee Maker
Coffee maker will not let water go into coffee grounds basket. It is a DCC-1200
run pure white vinegar through instead of water--at least 3-4 cycles just reuse same vinegar then discard run one pot just water--if machine is just plugged that should solve..
Aug 05, 2009 | Cuisinart DCC-1200 Coffee Maker
Won't brew
Run vinegar/water solution - 1/3 caraffe distilled white vinegar and 2/3 caraffe water. Let the vinegar/water solution sit in the water reservoir for up to 20 mins before you start brewing the first batch of vinegar/water solution. Run it up to 3 times - just like you would normal coffee. Then, run a caraffe of plain water and see if all is well.
If that fails, then you have a busted or damaged hose inside.
Call Cuisinart, because that one is still in warranty - you will not need a receipt or a box for that one.
-Tha Mp3 Doctor
Apr 05, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Coffee Maker stopped working
you can take the coffee maker apart, from the buttom. there 3 to 4 screws holding the inside guts together. take a look the themo fuse. it should have anumbe rstempted on it. go to local appliance repiar shop and get a themo fuse.
replacement make be difficult. the themo fuse is cramped, not soldered. (because of high temperture.)
at side from that, you can the the repair shop do the job or get a new one.
Nov 06, 2008 | Cuisinart DCC-1200 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
