Question about Hardware & Accessories
Instructions for cm2030r how to program settings
Understand the instructions for TS EE8
Following link has product manual that might match your timer:
Use + button at top of manual to enlarge print.
http://waterheatertimer.org/pdf/Argos-7day-Electronic-Timer-Manual-TS-EE8.pdf
Please add a comment and say if this manual matches your timer...fixya will send me email... and I will answer.
Include where you get confused.
You set current time first... that's the time that shows on your wristwatch right now.
You set day of the week... same day it is right now.
You set hour and minute.
The timer allows you to set up to 8 programs... you can set just 1 program or 2 or 3 etc.
Each program must have ON time
You set program 1 ON
Each program must have OFF time.
You set program 1 OFF
Each program must have a day or days of operation
So you might select monday ON at 10:10 am and OFF at 3:36 pm.
And other program for Tuesday ON at 10:45 and OFF at 4:00 pm.
When programming is finished, you set mode to auto for programs to run on the schedule you set.
Gene
Water Heater Timers Save Money
Feb 28, 2015 | Hardware & Accessories
How do I get the programming codes pan sonic. Tv one for all remote urc 2060
( URC-2060, URC-2062)
Set Up
Your remote will set up in one of the following ways:
Set Up #1
Press the button for the device you want to program, then release.
Press and hold the Magic button until the red LED gives a delayed blink.
Continue holding the Magic button while you enter your 3 digit code.
You should receive 2 quick flashes after entering your code.
Look on the back of your remote for the instructions. If they match these, press here for more instructions for his remote.
Set Up #2
Press the button for the device you want to program, the release.
Press and hold the Magic button. You will see two blinks on the remote. Release.
Press the three digit code for the device you want to program.
You will see two blinks. Your remote is now programmed for that device.
Look on the back of your remote for the instructions. If they match these, press here for more instructions on this remote.
Feb 03, 2015 | One For All Televison & Video
Cannot program 70cm into Baofeng uv-5r plus after programming 2 meter frequencies
Search for programming instructions on Google. That radio is confounding to program - and the instructions that come with it are incomprehensible. There are several sets of instructions available via Google that are more understandable.
Sep 06, 2013 | Radio Communications
What is a computer code ?
Computer Code (computer science) the symbolic arrangement of data or instructions in a computer program, or the set of such instructions:
1) Used in Programming. The writing of the program/s.
2) Used in the set/s of instructions in the Processor.
Nov 26, 2011 | IBM ThinkPad T20 2647 Notebook
What is the difference between a software and a program? Describe.
A program is a set of instructions written in a programming language to perform a particular function. Many programs combine together to form software. While software refers to a collection of several programs and other procedures and documentation.
Software is also used to perform a task. The most common programming language used for making software is C and C++. Software is of two types that is system software which is the operating system and application software.
So a program is a set of instructions for performing a task whereas a software is made up of several computer programs.
Feb 06, 2011 | Computers & Internet
Hi i lost the instructions and don't know how to set the clock. please give me step by step once i reset the unit.
You posed under Aube T-1032 7-day programmable.
Aube makes a list of timers and each timer has different instructions.
For your convenience, I posted the Aube timers and manuals :
http://waterheatertimer.org/Aube-timers.html
I answer questions for free.
I am more than happy to write out the long list of instructions from the manual.
But the instructions apply only to the T1032.
They don't apply to the T-1034, T-1035, T-1052, T-1054, T-1070, T-1073.
If you would like me to write out instructions for one of the other timers, add a comment and tell me which timer.
T-1032 Manual
Set current time on T-1032:
Press and hold reset button
Display should be visible
Press Hour button to set current hour with AM or PM
Press MIN button to set current minutes
Press DAY button until current day shows (for example TU for Tuesday)
Close cover and press cover to confirm times
Programming overview:
Make a chart of your programs before starting to avoid conflicts in programming.
You can set 7 different programs
Program1 program2 program3 through program7
Each program has ON and OFF
First you set program1 ON with times and days of operation
And then you set program1 OFF with times and days of operation
Programming:
a) program1 ON
Press PGM button until the display appears as below:
P1 ON means you are ready to set program1 ON
Press the Day button to select days of operation for program1 ON
Press Hour to set hour am or pm for program1 ON
Press MIN to set minute for program1 ON
b) program1 OFF
Press PGM button until display shows: P1 OFF
The display will also show the the same Days you selected for program1 ON
Press Hour to set hour am or pm for program1 OFF
Press MIN to set minute for program1 OFF
c) To set program2, press PGM button until P2 ON displays
Repeat steps above to set all 7 programs.
d) To finish programming, close cover and push in cover
e) Select operating Mode.
Press and hold the cover until AUTO displays.
f) Press in cover for manual override.
Nov 10, 2010 | Honeywell Aube by TI0323W5U 7Day...
I have digital programmable timers (Model DT121 and Model DT11) that will accept programs, but won't turn the attached lamps on and off at the programed times. The batterys are new and I've had them...
DT121 Manual
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt121c%20-%20english.ashx
All Intermatic manuals
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
Intermatic does not show DT11
Intermatic shows the DT121 is no longer available
If the display shows and you can set programs, then the battery is good.
Does the manual override work? This indicates whether the timer on-off switch operates.
If manual override does not work, then I discovered that timers are no longer any good
Programming:
Set present time
Then set ON time for program 1
Set OFF time for program 1
Then set ON time for program 2
Set OFF time for program 2
Most timers will not function if there is a conflict in programming > for example Program 1 says ON at 6 and OFF at 7 and Program 2 says opposite or has overlapping times
When events are set, press SET once > this will put timer in RUN mode
If manual override works, and you set programming correctly, but timer does not carry out instructions, I guess the timer is no good.
Intermatic has 24 hour timers with 2 on-off per day
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/lamp%20%20appliance%20timers.aspx
Intermatic has 7-day digital timers (all digital timers today are 7 day where you select the day that each program works)
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/digital%20timers.aspx
Oct 12, 2010 | Intermatic Hardware & Accessories
Have a globe electric power bar with7on/7off timer- instructions appear pretty confusing, can not get it to function
I cannot find manual for that product. I think it's actually an Intermatic product DT8003, but I can't find that manual either.
1) If you post the exact wording from the manual where it gets confusing, it would be easier to help ... and typing out the instructions on your part might help you solve the problem
2) If I had to guess about the confusing part of timer programming:
-Timer offers DST option, and Dusk-to-dawn capability +> you have to decide whether to use these options or choose 'manual' option where DST is ignored. Read where you programmed this step and make sure you chose manual or auto.
-You can set 7 programs per week, Program1, Program2, etc
-Start with Program1: first, select days of operation for that specific program ... for example MO (for monday) or WKD (for weekend)
-After setting days of operation, Program1 has to have an ON time.
-After setting ON time. Program 1 has to have OFF time.
-After setting OFF time, you press a button to save Program1 (sometimes this step requires you to push the on-off button or manual override)
-Next, you repeat the same steps for Program2
-The timer ignores conflicting programs > for example Program1 says ON at 7 and OFF at 8 and Program2 say the opposite, timer will ignore both programs.
3) Post photo of instructions on Flickr or Imgur
-Flatten instructions between pages of a book for a few days, and then scan instruction in file format (same format as you scan a photograph or have Office Depot scan instructions for you)
You can post the photo of your instructions on Flickr or Imgur
... and then we can go look at instructions and help sort out the confusion.
Oct 03, 2010 | Globe Electric Globe Indoor/Outdoor Lights...
Can't find instructions
email me at rlehman123@comcast.net for a copy of the instructions
Feb 10, 2009 | Solar Ingraham 20 Program Electronic Timer...
I purchased a Panasonic DMR-EZ48VK and connected it per instructions. I was able to do the Intitial Setup,and program the Remote to recognize the TV, but now I can NOT get the Remote Programed! I follow...
The remote lost connection with DVD set. Push OK and hold while you Push #1. This will reset the remote. Connection instructions with set are wrong! After re-wiring, everything works great! I had to call Panasonic and sit on hold, but they were very nice.
Sep 30, 2008 | Panasonic Televison & Video
Hardware & Accessories Logo
29 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
