Will not start. Panel says LOC - Washing Machines
    Top Expert:
  • Washing Mach... Master
  • 41,697 Answers
The door is not latched or the latch is defective.
Posted on Dec 05, 2016
Whirlpool loc
From a google search the following is copied:
LOC is a control panel lock not a door lock, see below.
The Control Lock shuts down the control panel pads to prevent
unintended use of the ovens.
When the control is locked, only the CLOCK, TIMER SET and
TIMER OFF pads will function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Before locking, make sure the ovens,
Timer and Timed Cooking are off. Press and hold START/ENTER
until a single tone sounds and "Loc," a picture of a lock and
"START?" will appear on the oven display, about 5 seconds.
Repeat to unlock and remove "Loc" from display.
If the above does not work have you tried removing power from the uit for a few minutes to see if it will reset.
________________
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/499415-whirlpool-double-oven-shows-loc-display.html
Jan 26, 2018 | Ovens
Ican't turn the oven on. When I press "Bake" it goes to LOC and then turns itself off. I should be able to adust the temperature (+ or -), then press start.
Hi
If it is a GE oven then you can try and reset the LOC error by pressing 9 and the 0 simultaneously for 5 seconds or until the LOC disappears. Alternatively you can try pressing the "Oven Lockout" or "Range Lockout" button on the control panel and then the "Start" button. Hope this helps... Please post back with make and model# of your Oven if you need more information.
Daniel
Nov 10, 2010 | Ovens
I have error code loc the machine won't
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 27, 2009 | Kenmore Elite 45986 Front Load Washer
"loc code"
Found the operating manual on the internet. We thought it was the child lock button but we couldn't release it. We found out that you have to hold both the "select" and the"option" button for 10 seconds to release the loc.
Hopes this helps someone else.
Sep 14, 2009 | Frigidaire ATF6000ES Front Load Washer
MY WASHING MACHINE THEY DONT START WHEN I PUSH START IT SHOW UP THE WORDS ERR AND LOC
Jul 02, 2009 | Kenmore Washing Machines
Washer will not start, keep saying "loc"
it means the control panel is locked. hold down the options and select button for several seconds and it should correct the problem. this worked for me.
May 18, 2009 | Frigidaire ATF6000ES Front Load Washer
I am geeting The LOC 50 on the washer when we press start
your "control lock" is on, look cllsely at the control panel there should be a button {or 2 butttons} that need to be pressed and held for 3 secs to unlock the control.
Oct 25, 2008 | Frigidaire Affinity ATF7000E Front Load...
Loc error
Greetings necie64,
The control panel may be in *LOCKED* mode.
Press the *OPTIONS* and *SELECT* buttons at the same time and hold for about three seconds to unlock the control panel.
Make sure the detergent tray is fully closed too.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jun 23, 2008 | Frigidaire GLTF2940ES Front Load Washer
"loc" display
This just happened to me. I have whirlpool double oven accubake. The display went blank and i had to turn the breaker off. I left it off for several hours. When I turned the breaker back on my oven display read "Loc" in big letters to the right of the time. I held the start button down for 5 secs. The display went away and the oven started to work as if nothing had happened. I hope that is stays that way.
Dec 08, 2007 | Whirlpool Ovens
Washing Machines Logo
Top Washing Machines Experts
