How to remove the fs-522 finisher to replace the lsu
Kyocera FS-1128MFP C4000
lsu (laser scanner unit) failure or main board
Jun 30, 2014 | Kyocera FS-1128MFP FS-1128MFP...
What can i do with error 2250:0110409?
There is a problem with the lsu/charger cleaning motor. Maybe one of the four main charger or LSU has stuck. Check the main chargers and the LSUs if their gears rotate properly or they are stuck somewhere. Otherwise, the motor that drives the cleaners is defective. You can isolate the automatic LSU/Charger cleaning by remove the connector from the engine pwb. First you have to check if the lsu/charger cleaners are at home position or not.
Jun 10, 2014 | Kyocera FS-C5300DN Laser Printer
Call service Code 4600 KYOCERA FS 8520 MFP
LSU cleaning motor error
When the LSU cleaning motor
is driven, an error signal is
detected continuously for 1 s.
Defective connector
cable or poor
contact in the connector.
Reinsert the connector. Also check for continuity
of the connector cable. If none, replace
the cable.
May 17, 2014 | Kyocera FS-C5030N Led Printer
Wood finish replacement part
If you call 714-522-9000, you can ask them for this part on order or for a distrubator in your area.
Feb 24, 2014 | Yamaha P-155 Electronic Piano
Remove paper from finisher tray
if the paper is removed then check the sensor if you do not see it then have a tech come out, might need to be replaced
Jan 24, 2014 | Konica Minolta Fs-527 Finisher -
could be the fuser, drum, dv unit, mc corona, or lsu glass
Sep 13, 2013 | Kyocera Fs-3920dn Laser Printer
Error c1183 on konica minolta
Output trays hit something!!!!!! someone leave a trash can or boxes under the output trays? Will have to remove the rear access to the finisher and reseat the drive motor assy. DO NOT LEAVE ANYTHING UNDER TE TRAYS
Jul 16, 2012 | Konica Minolta Gear 4349163301 for FS-530,...
I have a fs c2126 kyocera printer it gives me c4600 error code
Good afternoon,
Please can someone tell me what is the error C4600 printer kyocera TASKalfa 2551ci?
How can I solve it?
Jul 20, 2011 | Kyocera FS-1118MFP Laser Printer
29 people viewed this question
