Question about Acer N300 Pocket PC
Acer N311 Joystick
How can I get a replacement joystick online? Mine is broken.
  • Acer Master
  • 13,433 Answers
Re: Acer N311 Joystick
Hey, If your warranty doesn't cover this you can order a spare part from
The company is trustworthy I have ordered laptop parts from there. I got my moneyback when a part didnt work.
You can contact them via email to discuss the price if your country doesnt use euro.
Posted on Feb 11, 2008
0 characters
3 Points
Joystick problem
Friend, i guess the connection of your joystick going upward is broken or disconnected. the connection terminal needed to be resolder. if still does'nt work, you need to replace the whole joy stick.good luck
Jun 05, 2009 | Nokia E50
Joy stick can be changed but is best done by an engineer as you will need to take phone apart. You would also need joystick part and correct screw drivers as star shape screws. Have you checked with Sony Ericsson as most handsets have 24 month warranty?
Apr 24, 2009 | Sony Ericsson K810i Blue Smartphone
3230 joystick
Well you'll have to take the whole thing apart so that you can gain access to remove them both and the next thing is that the availability of new chipset.I don't think it is easy to find one for your model.
Jun 02, 2008 | Nokia 3230
Joystick., T_T
It should be..but it all depends on whether or not the service shop has the required parts, and if they actually do the replacements :)
You will have to enquire around locally to find out more details.
3230 joystick
piles sir i am request my mobile 3230 joystick up down no waking piles help emijate
My psp speakers dont work the head phone jack came loose and only plays out of one head phone and the up joystick doest go up all the way in a game so i walk slow, can i fix these problems and how ???
You have either what is called a dry joint on the headphone socket or the headphone socket is broken.
When you plug the headphones in it switches off the speakers, so if the socket gets damaged or becomes disconnected from the board the speakers will also not work.
you need someone with VERY good soldering skills and a spare headphone socket to repair or replace the socket
Couldnt say whats happening with the joystick, maybe a bit of the headphone socket has got jammed in it, you probably wont find out untill the psp is opened up
May 25, 2008 | RIM BlackBerry Pearl 8100
Can not open
You need to replace the joystick component; it is not caused by dirt. After some time it gets bad.
You need to go to the nearest authorized service center; that joystick is not a standard component, only the authorized service centers got them; taking it from another phone is not a good idea, doing it, the component will loose operability.
Jan 03, 2008 | BenQ P50
Acer n311
hi. the question is, which ROM version do you use. just go to settings and choose about... there you can find info about the current ROM. look for the last two numbers (they should be between 16 and 24 which is the latest and stable version) here is the short guide how to proceed with the update an here you can download mentioned ROM. I advise you not to restore your device afterwards, it won't work!
Dec 13, 2007 | Acer n311 Pocket PC
3230 joystick problem
trow ur cellphone in d river! den cry! dats d best solution!
Dec 14, 2006 | Nokia 3230
Acer N300 Pocket PC Logo
351 people viewed this question
Top Acer PDAs Experts
Are you an Acer PDA Expert? Answer questions, earn points and help others
