Question about Maxent Televison & Video
Codes for a 44 inch maxent plasma tv - Maxent Televison & Video
  • Maxent Master
  • 6,694 Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Posted on Dec 05, 2016
  • 36 Answers
SOURCE: blinking plasma tv
Hi alan,well any tv can be fixed but at what price,your fault sounds like a capacitor proberbly on the inverter board needs replacing,i have come across this problem quite a few times and it will take me 10-15 mins to diagnose and repair this type of problem and it is very inexpensive for the part.
Is the fault worse when the tv is first switched on from cold or does it get worse if the tv has been on for a while???
Hope this helps.
Posted on Feb 02, 2008
SOURCE: Need assistance on how to repair a plasma tv with no picture but sound
This site is BOGUS.
Invites you to post problems and "Ask an Expert" then wants you to pay a fee or you are SOL. Won't recommend and Won't be back
Posted on Jul 15, 2008
pilot210
  • 39 Answers
SOURCE: maxent plasma tv is showing only vertical lines.
Common problem on these sets are many many bad caps on the digital board. Repair kits are available for these containing the necessary parts if you're savvy with a soldering iron. Otherwise, replacement of the digital board is necessary and you'll have to contact either Maxent or a local repair shop. Tracking down which caps are bad can be difficult even with the right equipment as some tend to check good while in circuit when they are actually bad.
Posted on May 19, 2009
Fix-4U
  • 293 Answers
SOURCE: Parts for Maxent 42" Plasma TV
Hi..there! Try this site it's might have what you looking for...
@ www.3rd-rocks.com
Posted on Oct 01, 2009
  • 11800 Answers
SOURCE: maxent 42 inch plasma tv,
That means that either the video processor or the power to the plasma panel or the video final is gone. The only way to know it for sure is to take the cover off and testing the parts. Start by checking that both Vs (around 200v) and Va (around 70v) are present at the source, then check that the video final powered and is getting the signal from the processor and finally check everything in between. If you don't know how to do that (or what to do next if one of the voltages isn't there) then call a repairman, there's nothing more you can do to it.
Posted on Aug 20, 2010
Maxent 60 in lcd tv flickers
I had the same problem with my 50 inch Maxent, found a solution on the internet that seemed too good to be true, but I replaced a part that cost me $1.38 at Radio Shack and my tv is as good as new. Go to this link for details and even includes pictures. All you need is a scredriver (to remove back cover) and a soldering iron - repair is actually very easy. Good Luck!
http://www.avsforum.com/t/595430/maxent-50-plasma-mx-50x3-official-thread-do-not-post-prices/2130
Oct 18, 2012 | Maxent MX42X3 42 in. HD-Ready Plasma...
I have a 42 inch Maxent and it blinks like its going out??
Hello
Chec this power supply regulator baord to your tV for any defective components, or for loose solder points.2_20_2012_2_15_32_pm.jpg
Feb 20, 2012 | Maxent MX-42V1 42 in. Plasma Television
Hi i have MAXENT TV 50" plasma im loking for dish network remonte code to program on it please help
We show no codes listed for Maxent televisions. The best method for programming this remote is called a Power Scan, the steps are below:
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network
Customer Service
May 08, 2011 | Maxent MX-50X1 50 in. Plasma Television
Maxent plasma tv no picture or sound
Check and replace that board. Just visit the site linked here. Y Sustain board faults and symptoms of plasma display is given in details. http://electronicshelponline.blogspot.com/
Apr 07, 2017 | Maxent MX-42XM11 Television
Maxent tv has a line about 2 inchs wide and half way down the tv
Vertical scan board needs servicing and ground needs to be re-established through solder re-flow........
Nov 03, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
Need code for my maxent tv
Maxent is sometimes the same as SAMPO. Try 746...
Mar 30, 2009 | Maxent MX-42V1 42 in. Plasma Television
Tv remote
I was looking for codes for you but cant find any compatible ones!
You can order the orginal remote for your TV at www.remotes.com
Have make and model ready!
Hope this is a fix ya solution for ya!
Jan 12, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
Blinking plasma tv
Hope this helps.
Jan 22, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
Maxent MX-42XM11 Plasma HDTV
finding correct tv code for mexent 42 inch plasma tv for direct tv receiver
Dec 31, 2007 | Maxent MX-42XM11 Television
Televison & Video Logo
Top Maxent Televison & Video Experts
Michael Harrier
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
