Question about World Heating & Cooling
I have a kozy world wall mount heater . That doesn't shut off?
  • 118 Answers
SOURCE: The pilot light on my kozy world ventless wall
weak pilot flame: should wrap around therocouple.
blue flame with yellow tip not yellow and lazy.
if flame good replace thermocouple
Posted on Oct 26, 2009
  • 221 Answers
SOURCE: Kozy World propane wall heater
The ceramic "bricks" need to be heated evenly. Since 3 are good, I would have to assume the other two have a restriction. Maybe a spider in the orifices, If  you can access the "jet" where gas comes out, try using a paper clip or something similar to clear any blockage. If that wont do it, pull the burner, remove each orifice and clear. Good Luck
Posted on Dec 30, 2009
Testimonial: "Thank you very much for the info. There was some trash around the opening of the 2 jets. I cleaned them out with a tip cleaner and now it works fine."
  • 8404 Answers
SOURCE: Is there a way to convert a kozy world KWN313
Your model is not listed at http://www.kozyheat.com/.
If this is currently a natural gas fitted device, there is a better than not chance it can be converted.
Please check with the manufacturer or dealer where you purchased the device. You can also contact your local propane supplier who would do the actual converting of the orifices.
A note: If this device is presently set up for natural gas and is hooked up, and you still have natural gas available, this is normally the cheaper of the two fuels to use.
Thanks for your quesiton at FixYa.com
Posted on Jan 02, 2010
  • 4736 Answers
SOURCE: My pilot light on my
From what you have described there appears to be dust, dirt or pet hair in the pilot or the pilot tubing, as well as the Oxygen Depletion Sensor (ODS). OR your heater may be the wrong gas type. In other words, you have Propane Gas and the heater is a Natural Gas heater (or vise versa). Look for the manufacturers tag on the side or back of the heater. It will tell you the model number, serial number and gas type. Even with this, on rare occasions, the manufacturer's plate may be incorrect. The only way to be sure is to remove the front cover of the heater and look at the control valve. It should be marked LPG or NG.
Posted on Jan 28, 2011
  • 4736 Answers
SOURCE: I have three Kozy World wall heaters. Two work
Yes, it sounds like the third heater has a Control Valve problem. It's allowing more gas into the system than what it's supposed too. Have you tried turning the flames down to a lower setting? If so, did it lower the flame height? How old is this heater and is cleaned and serviced at least annually? Are you using Natural Gas or Propane?
Please get back to me with the answers to the above questions and I may can help you.
Thanks,
Rich
Posted on Feb 07, 2011
After installing my kozy world heater and lit the pilot the heater came on. all three plaques. this happened while the knob was still in the pilot position. the heater wont shut off.
I actually have three of these and what I found was the gas valve was stuck in the open position you may need to replace it or possibly remove it and try to clean it of any residue but be very careful if you don't know exactly what your doing then you need to get a pro. Remember that your dealing with propane and it could ignite and cause serious damage to you and your home. Please be very careful and you might want to call the manufacturer and talk to them about it. Because it is a gas appliance they have a responsibility to you if anything should happen then they may be liable.
Nov 25, 2014 | World Marketing Kozy World KWP196 3-Plaque...
I have three Kozy World wall heaters. Two work just fine - the bricks turn red after the heater has been on for a while. The third one always burns blue and the flames 'lick' the top of the inside of the...
Thanks,
Rich
Feb 07, 2011 | The Companion Group Kozy World Portable...
I have a Kozyworld wall mounted ventless propane heater. Whenever it automatically turns ON or OFF you get a strong odor of propane. While it is ON you don't smell propane. What is wrong with it. I...
You need to clean it out. Take the wall heater down and use a air compressor to clean out the gas system. Also clean the orifice out. Make sure that the chamber is clean and clear of spider webs and dust.
Jan 26, 2011 | The Companion Group Kozy World Portable...
Dec 30, 2009 | Heating & Cooling
The kozy wold heating stove flame has irruglar
kozy world KW112, 1 burner is dim flame 2nd flame is bright red. What is the problem?
Dec 09, 2009 | The Companion Group Kozy World Portable...
The pilot light on my kozy world ventless wall heater goes out after it burns for a while. Even quicker when the blower kicks on.
Oct 26, 2009 | The Companion Group Kozy World Portable...
I was wondering where i could buy a replacement pressure regulator for a procom model ml250tpa
Try Procom Customer Service at 877-886-5989. Or call Kozy World at 800-776-9425 and tell them you have a KWP324 (same as ML250TPA).
Dec 27, 2008 | Ace Hardware ML250TPA Infra-Red Wall...
Heating & Cooling Logo
27 people viewed this question
Top World Heating & Cooling Experts
MightyMikeJr
Andrew Taylor
Andrew Taylor
Are you a World Heating and Cooling Expert? Answer questions, earn points and help others
