Question about GE Ovens
Top oven on GE double wall unit over heats and flashes locked. Replace door lock and circut board but did not help. Do not hear cool down fan running. Could that cause this problem?
SOURCE: Kenmore double oven flashing locked door, door not locked, oven wont respond
hey  i have the same problem, i moved into this house so i have no manuel. this is crazy, i hate this oven. i would personally never buy this oven. if you guys have figured out this problem i would really appreciate a response.  thanks Justine  Canada
Posted on Feb 18, 2008
Krazytech
  • 725 Answers
SOURCE: Ge oven problem
door lock is not work check wires motor and switchs.. you may have to replace the door lock
Posted on Jun 04, 2008
  • 116 Answers
SOURCE: ge monogram single convection wall oven
There is usually a micro switch that is activated when the lock lever is in place - very likely this switch is still activated or has failed closed (defective) .
Posted on Aug 31, 2008
  • 86 Answers
SOURCE: GE Double Oven doors locked and circuit not responding
Hi, well this is a brain tester!! I think you need really to look at this in a simple way. Check to see where the door lock wires come from first? Find where the mains power comes into? then if it goes directly to the main control board then check to see if there is any power getting through the board to the otherside where the wires disapear into the cooker. I would consider checking the control board for any signs of burn damage and then look at the clock unit to as these are normally the main components in the cooker that will stop it from working.
Good luck,,,,,,,,,,,,,,,
Posted on Jan 02, 2009
localwonder
  • 6784 Answers
SOURCE: Flashing locking door light
This is a failed logic chip on the control board. replacing the control board will fix this issue.
Posted on May 27, 2009
GE monogram double oven . Self cleaning top oven and F9 in red showing and beeping noise
F9 is a problem with the oven door lock circuit. If the door is locked, it's probably a bad switch that tells the oven it's locked. If the door isn't locked, it's probably a problem with the lock mechanism.
A common problem on many built-in GE ovens (you don't say if yours is built-in or free standing...) is air circulation in the control panel. The fan that keeps the panel cool either stops working or gets clogged with dirt/dust and can't move any air. This causes the panel to overheat and can cause all kinds of odd problems and error codes. If you have a built-in, check to make sure the fan is working and the mesh screen behind it is clean.
Jul 17, 2016 | GE Monogram ZET3058SHSS Stainless Steel...
GE Built In Wall oven JTP25SOH6SS wont completely shut off
The cooling fan will stay on for a long time after using the oven. It should shut off after a while. If it is running all night for instance there is a great possibility that a relay is stuck on the control board.
Apr 13, 2014 | GE Ovens
Locked after self clean cycle
you may have a bad door lock . in this case replace. but first reinstall the door and run a new clean cycle and see if it unlocks .. mm
Jul 14, 2010 | GE JKP45 Electric Double Oven
GE Oven door won't unlock after cleaning cycle (and cool down).
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 24, 2010 | GE JKP45 Electric Double Oven
Maytag double oven is locked and won't open
Hi. Has a fault code been displayed and a continuous beeps? press and hold the cancel & cook & hold buttons together for about 3seconds then door should open.
Hope this helps.
David
Sep 13, 2017 | Maytag MEW6630D Stainless Steel Electric...
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
Jan 02, 2009 | GE Profile JTP56 Electric Double Oven
GE JKP45 double wall oven shuts off
This sounds like a loose connection (solder joint) on the main control board. I had one that had a similar problem. checked the price of a control board $350. I took the control panel off, took the board apart and found a loose connection on one of the relays. resoldered the bad connection. oven works fine now.
Nov 07, 2008 | GE JKP45 Electric Double Oven
GE: JTP56 F2 Door Locked displayed
I have the the same problem as discribed above. Does you oven fan go on for a long time after you use your oven during regular baking. Mine seems to stay on for 45 minutes after I bake anything. Can this be all tied together with the f2 problem? I am wondering if it is not just a fan circulation problem?
Dec 15, 2007 | GE Profile JTP56 Electric Double Oven
Ge wall oven blinking door locked for days
The switch inside the door lock mechanism is stuck down making the unit think it is still locked.  the switched is located next to the hook that locks your door.
Oct 29, 2007 | GE Profile JTP56 Electric Double Oven
Ovens Logo
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
