Question about HP PSC 1510 All-In-One InkJet Printer
Paper feeds into printer 1/2way, stops, check paper light flashes
I am having a similar problem to several previous posts. The paper feeds about halfway and then it stops and the check paper light flashes. I have gone through all the troubleshooting steps possible (cleaned the rollers inside, tried different paper, tried one sheet at a time, turned off and on, etc.) but it is still doing it. It randomly printed one page of a 2-page Word file a minute ago but that's all I've gotten all morning. Has anyone had this same problem and fixed it? Help!
  • ashleycampos Jul 20, 2009
    Thanks for your post. But, what does the sensor look like? Is it the small black arm with the roller on the bottom that points down?
    President:
  • 2,306 Answers
Yes, there is a sensor on the right side of the carriage that points down at the paper, you use a Q-tip moist with water and wipe the underside of this sensor, you may need a couple since quite a bit of ink sprays onto this sensor.
Posted on Jul 20, 2009
Epson Printer Problem
HI,
Press the fonts.gif load/ejectbutton. The printer ejects the jammed paper and then resumes printing.If the error is not cleared, open the printer cover and remove thejammed paper. Then reload paper in the sheet feeder and press the fonts.gif load/eject button. The printer resumes printing.
Jul 24, 2008 | Epson Office Equipment & Supplies
Red "Paper" light stays on; printer will not print.
Paper light flashing could mean several things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. You can also check in between the drum and toner by removing the toner from the drum. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Apr 11, 2010 | Brother HL-2040 Laser Printer
Both paper feed and power lights flash after printing several pag
lean head-eject ink ruler & clean point of contact betwin cartridges and head-ink unit.
Aug 07, 2009 | HP DeskJet 970cxi InkJet Printer
K5400dtn - paper feed and on buttons flashing - won't print
This usually the indicator for a paper jam or similar.
You need to check over the printer for any scraps, jams, etc.. that are stopping the paper or printhead from moving normally.
You also need to check for any lids or doors open and make sure that the duplexer in the back is locked into position properly.
I had to search hard but the flashing lights troubleshooting guide is available here on the HP website.
Feb 21, 2009 | HP Officejet Pro K5400dtn Printer
Mis-feeds paper and thinks it has paper jam
the gears of the printer r worn out and they have hanve lost their allignment settings so this problem.either replace the gears.or the other solution.do not insert the paper in the tray ,keep it little bit outside and hold the end of the paper in hand when you will give a printout the printer will make a noise of picking the paper at that time just push the paper inside and then it will print properly.
Dec 10, 2008 | HP Deskjet 2330 InkJet Photo Printer
Not printing
There is probably a paper jam in the tray feed path. The other situation is that the tray paper pick up roller has become hardened/polished, or the paper tray paper is greasy. First step, take the paper from the tray, and fan it out, so each sheet is separated from the next. try it with jut a dozen or so sheets, change the paper.
Thoroughly check the paper feed path.
If not working, then check/clean the rollers.
Jan 20, 2008 | Kyocera FS-720 Laser Printer
HP PSC 1510 All-In-One InkJet Printer Logo
209 people viewed this question
Seeker5211
Seeker5211
