Question about Contec Medical
Hi, On a Contec 300G ECG machine we get a "ECG time out" error message when the unit is switched on. Any advice?
  • 71 Answers
SOURCE: What does the Power line
It means there is electronic noise coming from your electrical outlet. You can test to be sure by trying the unit unplugged from the wall. If it does not give the same error then it is definitely you power outlet.
Posted on Jun 03, 2009
  • 16 Answers
SOURCE: the schiller at 2 plus ecg machine not printing ecg
Does it work in auto mode ? are you putting paper correctly means , there is a black mark on paper which is sensed by paper sensor .If you put paper up side down then paper sensor won't be able to sense any paper & gives you error for rifilling paper .If this doesn't help you then You need to replace battrey . Thanks
Posted on Jul 22, 2009
AJIN G
  • 6694 Answers
SOURCE: How does ECG machine find
hi,
When the at2 is in auto mode, first of all it check the leads are properly connected or not.Then it will acquire the ECG and store the same in its memory then only it starts printing. that's why it takes that much time to give a printout. When its starts printing you can remove the connections from the patient because it have already memorized the ECG.
If interpretation is in on position it will compare the acquired ecg with the standards in its memory (allready programed by the manufacturer). and will give a detailed report with ecg.
ok
Posted on Feb 06, 2011
mark24354
  • 776 Answers
SOURCE: MY CONTEC ECG MACHINE CMS80
The power supply (That converts wall (mains) AC power to DC ) is not making "clean" dc power. The most likely problem is the large filter capacitors are " leaking" currect or dry. The small AC component (ripple) that is not filtered from the transformed dc can look like a heartbeat so there is some protection circuitry in these devices. It may be something else, but the large can filter capacitors are most likely. I always recommend that medical equipment be repaired by trained, insured factory technicians. Too many problems are likely to occur and you don't want to misdiagnose someone or electrocute someone because you are too cheap to get it repaired professionally. On the other hand, if you are in central Africa and using it for an elephant research project, get your soldering iron and replace the parts. -Mark
Posted on Sep 17, 2011
SOURCE: We have following errors on
we have a burdick e 350 ekg machine i can put the patient info with no problem
but when it comes to doing the ekg i get an error across the screen that says u1 or uI please help thanks
Posted on Aug 22, 2012
Our brand new Contec ECG 1200 is tracing way to lightly. Can barely read. The unit is registering full charge. Also is not printing patient data. Help!
I copied this from an old question similar to yours:
Ekg machines print on thermal paper, This means that the impression is made by the print head heating the paper. If the print head is not making contact with the paper, you will get a faint tracing or no tracing at all. This needs to be adjust by a technician. Contec is located in China and we are a dealer. If you need their info or want us to look at it for you (for free) simply give us a call
Discount Cardiology
805-484-9985
Jan 16, 2017 | Contec Medical
How to load paper
How to load paper - Fixya
www.fixya.com > Forum > EKG/ECG Machines
39 mins ago - How to load paper - EKG/ECG Machines question. ... Machines. Open Question ... Aug 30, 2012 ' Schiller Cardiovit At 2 Light Ecg Machine.
Loading paper into the MAC 1200 ecg machine - Fixya
www.fixya.com/.../t4590309-loading_paper_into_mac_1200_ecg_mach...
Apr 19, 2010 - loading paper into the MAC 1200 ecg machine how to load the paperinto the machine? ... Ge Medical Systems Ge Marquette Mac 1200 question.
Contec ECG Monitor & pulse oximeter Ekg printed sheet ...
www.hcuck.com/search/p1207318-contec_ecg.../ekg_printed_sheet
Question about Ge Medical Systems EKG/ECG Machines ... Open the . ... ...ekg-manual The paper is is backwards, there are 4 ways to load paper BUT only 1 ...
Electrocardiograph (EKG / ECG) Questions and Answers
Dec 21, 2015 | Medical
Cardiocare 2000 (Bionet) machine won't print full page!
hi, if i want to start running unit. after that always on display data error, plz turn off. why? what can i do for that? thax
Jan 22, 2013 | Life Science Bionet Cardiocare 2000 12...
New Contec ECG 300EG model no tracings appear on the EKG paper.
Discount Cardiology
805-484-9985
Aug 18, 2012 | Contec Medical
User's manual for a Contec Pulse Oximeter CMS50
Here is a link where you should be able to download the appropriate manual for your product.
http://www.contec-oximeter.com/sdp/499627/4/home-2955239/0/Brochure_Download.html
You did not mention which version of the cms-50 that you own and apparently there are several. But the link includes different versions so you should be able to download what you need.
Hope it helps. Please let me know
Thanks
Apr 22, 2010 | Contec ECG Monitor & pulse oximeter
Low battery
When your dealing with a low battery message you can do many things like the following:
1- Replace the battery.
2- Check the voltage of the battery with a multimeter.
3- Disconnect the unit from the AC source and check if the unit continue functioning without the AC source.
May 05, 2009 | Life Science Medical
What does the Power line data interference error message on the GE MAC 5000 ECG machine mean? We do not have a troubleshooting manual to review.
Apr 15, 2009 | Medical
GE MAC 5000 with a printer problem
You are probally using the wrong paper. Look at the part number for the paper you are using and cross refrence that with the correct number.
Mar 24, 2009 | Ge Medical Systems Medical
Medical Logo
647 people viewed this question
Top Contec Medical Experts
Electro Med Services...
Rhonda Webster
Rhonda Webster
masud
masud
Are you a Contec Medical Expert? Answer questions, earn points and help others
