Is this a digital antenna? TV 4714 - Televison & Video
    Master:
  • 708 Answers
  • 2,559 Answers
It doesn't matter. Antennas are neither digital nor analog. This is a marketing ploy. What matters is if it is vhf and uhf or only one or the other. Look up what ever channel you are trying to receive by go ogling the call letters of the station followed by wiki. There you should see what frequency they broadcast on. Unlike the old days the new digital channel numbers are merely placeholders and do not indicate what band the channel is in.
Posted on Dec 05, 2016
No picture or sound
You need a antenna HD for air signals. I hope this helps. leave feedback and thank you
Jul 11, 2016 | Televison & Video
How do ihook up a digital antenna to my tv
Dominic, you do not state whether you want large outdoor antenna or simple indoor.
If you bought your HDTV anytime during the past 8 years or so, it should have a built-in tuner for receiving digital over-the-air broadcasts. If you have an older "HDTV-ready" TV that only receives analog signals, you'll need to connect it to a separate HDTV tuner.
link below tells how to install outdoor digital TV antenna.
press the helpful button.
How to Install Digital TV Antenna Digital TV Help
Jan 19, 2016 | Televison & Video
How to install indoor digital tv antenna to a lcd tv & pickup digi channels
First, the LCD TV has to have a digital tuner in it. Older ones may not. If it does, then you attach the antenna connector to the TV connection that is marked TV IN or CABLE. Then, in the TV's menu, you would need to ensure that the digital tuner is selected. Once that is done, then, still in the menu, perform an "ON AIR" channel scan to find and lock in whatever digital channels that the antenna can detect.
Aug 05, 2015 | Electronics - Others
I have an older Sharp Aquos TV - model # LC-32G4U. I am trying to connect a digital antenna but it doesn't work. Anyone know if I need a separate digital tuner for this TV? Or what else might be t
There is no difference between a "digital" and analog antenna. Either antenna will capture the signal. What you need is a digital converter box to convert the over air digital signal to the older analog type signal your TV needs. You connect the antenna to the digital converter box, and the digital converter box to the TV.
Several years ago, the US government forced peopel to buy digital converter boxes or newer TVs that could pick up the digital signal. Either get a digital converter box or a new TV.
Oct 29, 2012 | Televison & Video
I'm trying to hook up an indoor antenna to my polaroid flm-3232 do I need a digital converter box or does the tv have the necessary components?
You have an analog TV, meaning that the tuner in your TV is analog only. You must buy a digital converter to see broadcast Digital TV via your external antenna and it will be attached to the antenna input jack or other jack depending on how it comes out of the converter.
One bit of advice, there is no such thing as a "digital" antenna, they are all analog. Even a 50 year old, outside antenna aerial that you see out in the countryside will pick up the new Digital Broadcasts to be converted by a Digital Converter and displayed on a 50 year old TV.
Oct 21, 2012 | Polaroid FLM-3232 Television
Can I use an antenna on my sharp tv catv? If so, what kind works for this tv
Hook up your rabbit ears and auto tune the TV and see what happens.
Jul 24, 2012 | Sharp Televison & Video
Need to know how to go cable free. Have TERK digital antenna
Shouldn't do, just connect the antennas into the Belling-Lee TV antenna socket at rear of set, tune channels. If you antenna won't fit, you may need an "F" connector to "Belling-Lee" converter plug. You will need an "Ordinary" Yagi VHF/UHF antenna installed though. Is that what that digital one is?
Feb 14, 2010 | Hitachi 51G500 51" Rear Projection...
Can I use a regular antenna
Yes. You can use a regular antenna for any flat panel HD TV. You're only limitation the type of antenna and whether or not your flat panel TV has a built in digital tuner. If it does, you'll be able to scan for digital channels without any additional components, including the High Def ones,  though you may not get every channel available with a set of rabbit ears. A roof top antenna will give you a stronger signal and more channels. If your TV does NOT have a built in digital tuner, you'll have to purchase a digital converter box and attach your antenna to it to receive the digital and HD channels. Good luck.
Jun 30, 2009 | Panasonic Televison & Video
Televison & Video Logo
Top Televison & Video Experts
