I installed new catridges but it is failing to initialize.
How do I insert the ink cartridge
power on the printer, open the catridge door. after printer initializes the catridge carriage assembly comes to right side of the printer and settles then insert the catridges and close the door.
Oct 17, 2014 | HP Office Equipment & Supplies
I keep getting the message Alignment Failed.
hello deer1626, if a printer gives you a message alignment failed that means your catridges are not properly installed try removing the catridges and fixing them back you will get a notification of aligning just follow the onscreen instructions and thats all
Jan 03, 2011 | HP Officejet Pro L7680 All-In-One Printer
In my printer though i install new catridges but the catridge attention lights are blinking. how to stop that blinking???
iphone.jpg In my printer though i Problem with the PDAs in my printer though i install new catridges but the catridge attention lights are blinking. how to stop that blinking??? - By himadripal05 2 hours ago
Oct 26, 2010 | Computers & Internet
Canon mp460 printer. refilled cartridge not recognised
Dear Sir,
This is deffinately due to catridge circuit problem.Canon suggest that we have to replace emptied catridges with new genuine canon catridge they dont suggest refilling and also not give any support for refilling catridges. So you can replace catridge with new one.
This Happens due to weakining of catridge circuit portion or may long period printer not in use.
If you not want to replace catridges i will give you the possible hints it may fix refilled catridges.
1.Clean the catridge circuit portion with soft cloth,care must be taken that there is no smudge or ink traces on catridge circuit.
2.Clean the ciruit of printer catridge placing box present inside the printer .wipe out the any sumdge or ink traces.
Then re install the catridges. give the print if it shows error press resume button continuosly. I think it will fix your problem.
If it is not solution is replace the catridge with new one.
good luck
Aug 26, 2009 | Office Equipment & Supplies
My HP 6500 on install will recognize Cyan ink
1. Try to determine whether the catridge is at fault. How so? Switch the Magenta with the Cyan catridge. Press OK.
2. If system indicates that the Magenta is not installed, you will know that the Cyan that you put there is at fault.
3. Touch the 9 mm. hole where you can see the sponge. Does the Cyan color transfer to your finger? If not, the catridge is empty or dried up. Replace or refill.
4. If the ink is normal, then use some toilet tissue to wipe the gold contact points clean. If this fails to solve your problem, take it to your dealer and ask for a replacement (if it fails to work in their machine).
5. If this fails, then the problem is within your HP 6500. You need a technician.
Aug 08, 2009 | HP Officejet 6500 Wireless All-in-One...
Conon ip1800 series
Because in refill catridges some connecting link is problem, remove the refill catridge and install the new catridge
Jan 16, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
How to remove catridge from printer J4580
Pull open the front door.
instructions for installing are in the box with the new cartridge
Dec 26, 2008 | HP LaserJet 4650 Color Printer Manual...
