Question about Fuji Xerox® DocuPrint C3055DX Laser Printer
My fuji xerox printer c3055 is failing to initialize even after installation of new cartridges. the error code is 093-310.
  • 2072 Answers
SOURCE: xerox printer error code (04,025.46)
This is a print head position issue.
TRY FIRST (Solutions without parts):
1. Check that the wipe mechanism has homed. 2. Check the printhead position and verify that it has initialized properly / manually home the printhead and power cycle the printers power and check for the error to return. If not then the error was most likely due to non-process function (something out of sequence).
Part likely to be the cause:
GEARBOX AND MOTOR,PROCESS DRIVE - PL 4.0, Item 14.
Posted on Jan 21, 2008
SOURCE: Canon Pixma IP600D - error code 6502
Sometimes the Canon printers which use PG-5BK/CL-8 colour cartridges with chips will give error massages like 6502 or other types of error message to do with the cartridges, which has the orange light flashing and the printer will not work. Follow this procedure which quite often resets the printer and allows it to resume printing.
When error is indicated, turn power switch off so green light is extinguished.
First hold down resume button and then hold down power button so both are held down at same time
When green light comes on, continue holding down power button and let resume button go, then press resume button twice. Then let power button go.
Then press resume button four times, power button should be released before doing this.
Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on. This normally solves the error problem - if not go through same procedure again.
Incidentally, you may find that if the chips had previously been disabled, the low ink warnings are showing again and they will have to be disabled once more. This would indicate that the above procedure clears the firmware memory of the disabling of the chips, this may be useful if you need some warranty work done on your
printer after the chips had been disabled.
Posted on Jun 10, 2009
SOURCE: Fuji Xerox DocuPrint 3055
no you can't
Posted on Jun 22, 2009
shockwave727
  • 262 Answers
SOURCE: Scanner motor move failed error code 6202
6202 error code means that the scanner motor failed
to solve this
-Open the printer access door of your printer
-Unplug power cable
-then after 30secs plug the power able back
-If the printer is already power-up the message printer access door will appear
-Close th printer access door
-try to scan or print
If this issue not solve call tech support of kodak Toll free 1 800 421 6699
Posted on Nov 08, 2009
  • 406 Answers
SOURCE: fuser temperature error for xerox 3100mfp
kindly check externally the fuser is heating or not. i SUSPECT THE FUSER MIGHT BE FAILED.
Posted on Nov 16, 2009
Xerox 550 fault code 045-315 how to solve this error code please give some technics
Error Codes and Support
Web page above states:
Error Description: Drive Logic Fail Solution: 1.Recycle your printer 2.Check all connections to the Engine Control Board 3.Make sure the correct firmware is installed. 4.If the error continues replace, the Engine Control Board (MCU PWB)
Manual for free download at link below:
Fuji Xerox Color 550 Administrator Manual Page 205
Feb 08, 2018 | Xerox Office Equipment & Supplies
Hi sir i have a xerox dc 12 giving error code 10-500 after replacing a new web cartridge
This code means that printer is not detecting the cartridge. you can try to to remove it and re seat it or it could be faulty, her is a list of all of the codes.
http://www.metrouk.co.uk/pdf/xeroxdc12faultcodes.pdf
Hope this helps.
Sep 16, 2014 | Xerox DocuColor 12 Printer
I'm getting a line that isn't printing through my printing from a Fuji Xerox DocuPrint C3055 DX
Possible reasons are: 1.empty toner cartridge, 2.dirt under one of the toner cartridge's developing roller, 3. dirt on the primary charge roller in the drum cartridge, 4. obstacle on the laser path.
Replace the empty toners first and try printing again. Follow the next steps if it didn't solve the problem.
Print a test page with 4 stripes across the page - black, cyan, yellow and magenta. See if all have the missing toner line or only one of them. If the white stripe is going trough only one color, inspect the cartridge with that color. It has to have the same stripe on the developing roller. See if there is some dust beneath it that makes the stripe and clean it with a brush. If the stripe is across all colors, then inspect the drum unit. The drum itself has to be evenly shining on the light. If there are uneven matte tracks on it, consider replacing. There should be a gap somewhere for the laser beam to pass and the drum is visible trough it. Look trough it for obstacles like piece of paper or hair. The primary charge roller has to be close to that gap inside, touching the drum. Look for dirt on it. Clean if possible.
Toner cartridges last approx. 6500 pages. The drum cartridge lasts between 14 000 and 28 000 pages depending on the color use.
Jul 02, 2014 | Digital Products Office Equipment &...
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
I have problem cartridge detached 093-972...fuji xerox docuprint cm 205 b
I'm having a problem with my Fuji Xerox printer model CM115w. The screen is showing cartridge detached 093-973 printer
Insert
Black Cartridge
Please help.
Apr 14, 2013 | HP LaserJet Office Equipment & Supplies
Saya Xerox C3055DX menunjukkan kesalahan: (091-321) dan (010-397), apa artinya ini?
Saya punya sedikit masalh dgn Printer Docuprint c3055 d layar muncul tulisan "Reboot Printer (091-321) bagaimana solusinya agar bs normal kembali.... terima kasih sebelumnya....
(Amang)
Mar 18, 2013 | Xerox DocuPrint C3055DX Laser Printer
How to refill fuji xerox docuprint p205b toner cartridge
Need to know how to refill the cartridge for xerox p205b , please email to me : myprinterwork@gmail.com . toner and chip also i got
Sep 05, 2012 | Fuji Office Equipment & Supplies
Instead of changing black toner printer (samsung clp-510)is giving error INVALID TONER BLACK
This can happen if you install a CLP-500 cartridge OR a Xerox Phaser 6100 cartridge.
Physically they are the same, but the 'chip' is different.
In the case of the Xerox, it is the programing of the chip that 'tells' the printer its a Xerox cartridge, and the printer won't accept this as valid.
If it's a CLP-500, the three contacts on the side of the cartridge have a resistor (for the capacity of the cartridge) and a falmeproof fusible resistor which resets tha page counter (for that cartridge) when a new cartridge is installed.
Oct 15, 2009 | Samsung CLP-510 Laser Printer
I require a service manual for a xerox 3030 wide format photocopier so I can learn to install a new toner
Fuji-Xerox XP-11 (Xerox 3030) Toner / OPC
6R281/13R32, 20k Under switched off printer press and keep the button of the unset, residing near by cord of the feeding; include the printer.
Procedure alike for both cartridges
Sep 02, 2009 | Xerox Office Equipment & Supplies
Fuji Xerox® DocuPrint C3055DX Laser Printer Logo
111 people viewed this question
Top Fuji Office Equipment & Supplies Experts
billconfused
mukhtar21 shaikh
mukhtar21 shaikh
Dave Busselle
Level 1 Expert
Are you a Fuji Office Equipment and Supply Expert? Answer questions, earn points and help others
