Question about Windchaser Dehumidifiers
I have a WindChaser WHRP Home Comfort Station someone gave me, i dont have the instruction manual. Wondering if i have to fill the top reservoir with water if i have it on the dehumidifier setting
It keeps switching from dehumidifierto defrost in the middle of the night, which i dont want it to do.
Humidity sensor
Go to Http://www.Haier.com/us/products/home-comfort/dehumidifiers . Select the model number and proceed to the Manual. Download the manual and look at the E-Codes to solve your problem.
Dec 19, 2013 | Haier 65-Pint Dehumidifier
My WHD928 won't start. Plugged in, tank is in correctly- but no go. The lights don't even come on. Is it terminal??
I hope it's not terminal, as Windchaser is no longer in business. Remove and check the top of the water collection bucket for a float valve. It may be stuck in the "UP" position. If it is, jiggle the arm to make it return to the "Down". While you have the bucket out, look inside the bucket holder. On the rear wall of the holder you should see the bucket removal safety switch. It should look like a plastic trigger switch. With the unit ON, activate the switch with your finger. If the unit does not turn ON, then the switch is at fault. If it turns ON, then the bucket was not making contact with it, when it was last reinstalled. Reinstall the bucket "squarely" from top to bottom into it's holder. Making sure that it does not tilt down at the bottom when installed and makes contact with the switch.
If the unit did not turn On when you tried to activate the Bucket Removal Safety Switch, it's time to start shopping for a new dehumidifier. As there are no parts available for Windchaser units.
I hope this helped you to troubleshoot and solve the problem. Thanks for choosing FixYa.
Aug 08, 2011 | Windchaser WDH928 Dehumidifier
Hi my comfort aire dehumidifier is brand new. It was working fine controlling the humidity and the reservoir was filing with water. All at once, it acts like it is contolling the humidity, but there is...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Apr 10, 2011 | Comfort-Aire BHD-501 Dehumidifier
Looking for the manual
Sorry to hear that your dehumidifier is not working! Here is a link for the manual, its a pdf so make sure your computer can read these types of files.
Hope this helps James
Apr 04, 2011 | Windchaser MDH-W Dehumidifier
Change my dehumidifier from draining by hose, to reservoir
I don't have the exact dehumidifier as yours, but on mine it's as simple as removing the hose, then the water fills the reservoir. Does it look like yours will do the same? If so, the hose fitting is also a sensor that will shut the unit off when it is full to avoid leaking onto the floor.
Sep 11, 2009 | Maytag M3DH30B2A Dehumidifier
Water goes in reservoir, not thru hose to sump pump, leaking
blow some air thru the discharge line,, thats all it is the line is clogged, if the pan is filling with water, it is working but they do get clogged with dust and lint in the air,,
Jun 11, 2009 | Maytag M3DH30B2A Dehumidifier
Changing from air conditioner to warm air dont have a manual
you will need to open the flap of the remote and press the button on the bottom left hand corner with a triangle, snowflake, raindrop and sun. Note on the top part of the LCD screen will be a sun. This indicates heating. Then set temp and fanspeed.
I take the time to help and answer your question so please rate me
Thankyou
Mat
May 13, 2009 | Comfort-Aire BHD-301 Dehumidifier
Bucket full
Allergy Buyers Club gave me a replacement item.
May 25, 2008 | Comfort-Aire BHD-501 Dehumidifier
Iced up coils and will not dehumidify
I did a little digging around on the internet and found out that if the basement (or where ever you have your unit) is in an area where the room temp might dip below 65 degrees the coils may start to become "too efficient" in pulling the moisture/humidity out of the air and it begins to freeze on the coils before it can drip off into the reservoir. The site said to turn off the unit and let it thaw out, then restart it and see if everything works ok after that. If the temperature gets too low you might need to warm up the air in the room/basement before it will operate correctly again/not continue to freeze up. Hope this helps. Mine just did the same thing but we've had some pretty cold weather recently and the basement is fairly cold as well.
Jan 20, 2008 | Comfort-Aire BHD-501 Dehumidifier
Dehumidifiers Logo
159 people viewed this question
Top Windchaser Dehumidifiers Experts
Steve
jasbo
jasbo
john h
Are you a Windchaser Dehumidifier Expert? Answer questions, earn points and help others
