Question about Sewing Machines
My machine has stopped feeding the fabric trough.I have cleaned and oiled it but it seems the pressure foot is too tight
  • Sewing Machines Master
  • 12,273 Answers
Most sewing machines have a pressure adjustment on the presser foot. Depending on your make/model machine, it could be a dial around the top left of the machine, a push button on the top (push down on the outer ring to release it), or even a screw at the top of the presser foot bar (may be under the top cover).
Posted on Dec 05, 2016
Singer touch tronic 2000 feed dog will not advance fabric
Confirm the feed dogs are raised. Make sure the feed dog teeth, area under the needle plate and the bobbin area are clean of any debris, thread, or buildup. Some machines also have a presser foot pressure adjustment that increases the pressure the presser foot applies to the feed dogs. The feed dogs could be worn (never run the sewing machine without fabric between the presser foot & feed dogs).
https://www.manualslib.com/manual/508740/Singer-Athena-2000.html
Or, the machine has not had a thorough cleaning and oiling recently and the feed dogs are sticking from old oil.
Wheel on right side that controls the needle up and down is very tight...
Jul 30, 2017 | Singer Sewing Machines
The pressure foot pressure is not feeding the fabric. I have adjusted the tension but still not feeding the fabric. What else can I do?
Tension does not affect the ability of the machine to feed fabric, except in extreme cases perhaps when tension is too tight.
You probably need to adjust the presser foot pressure of your machine. Lighter weight fabric is more difficult to feed, therefore the pressure needs to be increased. (Heavy weight fabric will sometimes push the upper layer of fabric in front of the presser foot, therefore less pressure is required.) Even so, very fine slick fabric (silk, satin, chiffon) sometimes still needs additional help. In such cases, a roller foot, teflon foot, or walking foot may be beneficial. There is also the possibility that the feed dog teeth have been worn so they do not grip the fabric like they should. (Avoid running the machine without fabric between the presser foot and feed dogs to protect the feed dogs from unnecessary wear.) If they are worn, usually they can be replaced.
Another possibility is that the feed dogs do not raise as high as they should. This would most likely require a technician's assistance.
Um, as an additional thought, make sure the presser foot surface is smooth. Any rough surface (nicks, rust, etc) will restrict the fabric's ability to move.
Jan 30, 2017 | Sewing Machines
Singer model 518....the material won't feed through.It wants to sew but won't feed cloth through. Thks
Be sure you have the stitch length set high enough that the fabric will actually move instead of sewing mostly in one spot.
One other thing to check is the presser foot applying enough pressure to the fabric so that the feed dogs can grab the fabric? On the top left side of the machine, there is probably either a dial or a push-type button. That would most likely be the pressure adjustment. The tighter that is set, the harder the pressure the presser foot will apply and the more the feed dogs will grab the fabric.
Check that the feed dogs are in the "up" position so they will pull the fabric through the machine. Are the feed dogs actually moving forward, raising above the needle plate, pulling toward the back of the machine, and then dropping below the needleplate before moving forward again? If not, then the problem could be with the feed dogs.
Your machine appears to be a mechanical model. If so, it could be the machine needs a good over-all cleaning and oiling--a couple drops of fresh, good quality sewing machine oil every place that metal rubs on metal (no plastic parts, belts...). Feed dogs are frequently affected when the sewing machine does not receive regular maintenance.
Jun 04, 2016 | Singer Sewing Machines
The feed on my Singer 538 will not pull my fabric thru. Help appreciated.
Without fabric in your machine and with the presser foot raised, do the feed dogs move front->back? Are the feed dogs in the raised position? Is the stitch length at a 10-12 stitch per inch setting so that the fabric actually moves (try increasing the stitch length to see if it makes a difference)?
Does your machine have a presser foot pressure adjustment? If you are sewing light weight fabric, the pressure may need to increased so there is more pressure applied by the presser foot to the feed dogs. You can also try adding a strip of tear-away or wash-away stabilizer to the underside of the fabric as you stitch so the feed dogs have something to grip.
Are the tips of the feed dogs rounded? Could be worn and need replacement.
If the feed dogs are not moving, how long has it been since the machine was cleaned and oiled?
It was working now it seems to be frozen the needle part wont move
If the feed dogs remain below the needle plate, and the feed dog lever does not activate them, then perhaps something is disconnected in the feed dog mechanism. The feed dogs should rise when stitching begins.
Feb 07, 2016 | Singer Sewing Machines
Not feeding material.
Tension generally does not affect the feed unless it is way too tight. Most reasons for fabric not advancing under the presser foot is that the feed dogs have been dropped for darning. If the feed dogs are operating properly, as the handwheel turns the feed dogs should rise above the plate, move toward the back of the machine pulling the fabric, drop down, come forward and rise again.
The other possibility is that the presser foot pressure has been released so the presser foot is not holding the fabric down on the feed dogs. Some machines have a spring-loaded knob on the top of the machine, a dial, or something to adjust the amount of pressure the foot applies. Consult your owner's manual.
Aug 10, 2015 | Sewing Machines
The feed is not pushing the fabric through right. It gets stopped at the very least thickness
-Need more tension. (More pressure) Any adjustment on the foot?
If so. tight it more.
Good Luck
Mai Lor
Jul 08, 2015 | Sewing Machines
Janome Jem Silver 662 will only sew backwards. How do I adjust it so it will feed fabric correctly?
1) Check the feed dog pressure adjustment. 2) Check the feeding mechanism at the bottom. It may be too low to feed your cloth.
Feb 03, 2015 | Janome Jem Silver 662 Mechanical Sewing...
Pressure foot or feeding foot?
Increase the pressure on the presser foot.
Jul 18, 2012 | Juki DDL8300N Sewing Machine
Machine does not feed properly. It sewed fine for
Here are a few solutions to check.
* Check your fabric to make sure it isn't caught on something.
* Check your pressure foot to make sure it's screwed tightly in place.
* Adjust the pressure of your pressure foot as it may be too light or too heavy for your fabric.
* Check your feed dogs for lint. If your feed dogs are clogged with lint, they're not gripping your fabric properly. Remove your pressure foot and clean out any lint with an old toothbrush.
* Raise your feed dogs if your machine has this function. They may have been inadvertently lowered.
* Check your stitch length regulator, If its set at “0” or a very small number, try switching to a longer stitch length.
* Change your needle, it may be damaged.
* Check your needle plate and make sure it's securely in place.
* Use a “Jean-a-ma-jig” or a “Hump-jumper”. If you've been trying to sew over a bump of fabric, such as a thick jean hem, try using this tool (your local fabric store should carry it). It keeps your pressure foot level as you sew over the bump and gives your feed dogs something to grip.
I hope this helps
Mar 13, 2010 | New Home L-372 Mechanical Sewing Machine
Will not feed the fabric
* Check your fabric to make sure it isn’t caught on something.
* Check your pressure foot to make sure it’s screwed tightly in place.
* Check your stitch length regulator, If it’s set at “0” or a very small number, try switching to a longer stitch length.
* Check your needle plate and make sure it’s securely in place.
* Use a “Jean-a-ma-jig” or a “Hump-jumper”. If you’ve been trying to sew over a bump of fabric, such as a thick jean hem, try using this tool (your local fabric store should carry it). It keeps your pressure foot level as you sew over the bump and gives your feed dogs something to grip.
I hope this helps
Dec 26, 2009 | Sewing Machines
Sewing Machines Logo
29 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
