Door locked button is lit and will not turn off. Door will open and close but light will not clear and washer will not start.
    Top Expert:
  • Washing Mach... Master
  • 52,097 Answers
Sadly we can not help you as you did not include enough information . too many makes through out the world .try unplugging it
Posted on Dec 05, 2016
Wont start machine error come up
Door open error code can also be displayed as "dOE" On non-display panel models this fault code is denoted by the light for the door lock being lit or flashing.
  • Check door is closed correctly and latched
  • Check door handle for damage or wear
  • Check door safety lock if inoperative replace door lock
  • Check door lock wiring
  • If there is a clicking sound once or twice when the Start/Pause button is pressed the main control board may be faulty
Apr 08, 2014 | LG WD-1280FHD Front Load Washer
Bosch Nexxt 100 series washer wfmc1001uc
According to the manual, you have to:
1. Turn program selector to "off"
2. Turn selector to Drain or Spin
3. Press the start / pause
Wait until program ends.
Open door.
or
Press "start / pause" until the start / pause light flashes.
Jan 10, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
He3 washer will not start. The lights on the
you probably broke the door switch and the machine thinks the door is open. little piece on top of the lock catch. need to change the door switch
Feb 05, 2010 | Kenmore Elite 45986 Front Load Washer
Front Load washer won't start , door lock light on, not locked
needs new door interlock,( sits behind where the door catches on to) easy to fit normally, make sure you un unplug the washer before starting.
Sep 29, 2009 | Washing Machines
Remote key will not open door
hi, gareth hear
i think this mite work 4 u
get in your car and put key in ignition turn 1 turn then wait approx 15 20 secs for light in clock to go red then take key out light should stay lit, next get out of your car close door then lock it and open it, when u open car light in clock should flash 3 times, next get out of car hold lock button on your remote down and push open button 3 times (keeping lock button down and remote pointed at reciver) next lose go of both buttons and red light on key should flash 3 times at the same time as clock inside the car.
next get in your car with key! then start her up and turn off get out of car close door and push button to lock (it should lock) if not get back in start her up again and turn off, then push the door locks inside the car then open get out and your car will lock this time!!!!!!!
this will work 4 u!!!
good luck
Dec 14, 2008 | Code-Alarm Code Alarm Transponder
The door is locked, no light on, washer won't run
Is the power cord plugged into a grounded 3 prong outlet?
Plug power cord into a grounded 3 prong outlet.
Are you using an extension cord?
Do not use an extension cord.
Has a household fuse blown, or has a circuit breaker tripped?
Check to see if a household circuit breaker or Ground Fault Circuit Interrupter (GFCI) outlet has tripped. If so, reset the circuit breaker or Ground Fault Circuit Interrupter. If the washer is on a fuse box, check to see if a fuse has blown and replace it, if necessary. If the problem continues to occur, call an electrician.
Are both the hot and cold water faucets turned on?
Turn on the water. Check the household faucets to see if the hot and cold water faucets are turned on. Make sure to open both faucets completely for proper fill.
NOTE: Both hot and cold water must be connected to the washer and turned on. The washer will not operate properly with only one incoming source of water.
Is the water inlet hose kinked?
Straighten the water inlet hoses.
Are the water inlet valve screens on the washer clogged?
Turn off the water and remove the inlet hoses from the washer. Remove any accumulated film or particles. Reinstall hoses, turn on water and check for leaks.
Is the washer in a normal pause in the cycle?
The washer pauses for about 2 minutes during certain cycles. Allow the cycle to continue. Some cycles feature periods of tumbling and soaking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look closed, but may not be latched. Open the door and close firmly.
Are the shipping bolts removed?
All four shipping bolts must be removed from the rear of the washer before you operate the washer. Each unit is shipped from the factory with four bolts, which are designed to protect the washer during shipping. Failure to remove all of the shipping bolts, and the four plastic spacers that are with them, can result in noise, vibration, error codes and possible machine damage.
Has a cycle been selected, but Start has not been selected and held for 1 second?
Press and hold Start for 1 second.
Is the Control Locked status light on?
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Is the Delay Wash status light on?
Your washer will start after the selected hours of delay are completed.
Was the door left closed after the last cycle?
The washer door must be opened and closed again to start a new cycle. If the door is not opened between cycles, the washer may not start.
Dec 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
WASHER WON'T START
possible door latch or even the strike on door itself may be broke
Sep 04, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
