Question about Home
Time zone adjustment for Tronic lcd wall clock
Version No. 10/2009
SOURCE: Centrios Atomic Desk Clock/Temperature
Here is how you adjust the time zone:
1.) push MODE till "AL" appears after the minute.
2.) tap "SET" (tap means push but do not hold) and time zone will advance.
3.) THE TRICK: The Time Zone can only be set in the Alarm Mode. Make sure you so not push and hold "SET" until the hour flashes as you would to set the alarm time. You just go into Alarm Mode and tap "SET" to advance the Time Zone by one zone per tap. When the Time Zone is where you want it, tap MODE to return to the clock and set the correct time.
Posted on Jan 28, 2008
informatica
  • 1114 Answers
SOURCE: Time zone
Hi - You can download the manual from the link underlined in blue below:
Chaney
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Posted on Aug 13, 2008
SOURCE: can't figure out how to set the time zone
I just pressed and held for about 3 to 5 seconds the button with the +/- on the bottom of the clock and until it showed the part of the US that I was in.
Posted on May 21, 2009
jyackle5
  • 8197 Answers
SOURCE: Have a Sharp Atomic Wall
  • 1 Insert the batteries into the clock and verify that the clock's display is functioning.
  • 2 Set the correct time-zone and Daylight Saving Time (DST) switches. The switches are on the back of the clock. Select EST if you are in Eastern Standard Time, CST if you are in Central Standard Time, MST if you are in Mountain Standard Time, or PST if you are in Pacific Standard Time. The DST selector should be set to "off" or "on" depending on the laws of your state.
  • 3 Wait 15 minutes. The clock should synchronize automatically.
  • 4 Set the clock manually using the buttons on the back panel if the clock does not catch the radio signal within the first 15 minutes. Push the correct button to advance the month/day/year on the calendar; use the MODE button to set the hour and minute.
  • 5 The clock should adjust itself within 48 hours to match the atomic signal. Verify that the clock is receiving the signal by checking the front display. You should see the image of a tower with circular lines at its top.
  • If that does not work try this.
    1) Pull the battery and wait a few minutes.
    2) Put battery back in - time will set to 8:00 (or possibly something different). 4, 8, or 12
    3) After it stops spinning, Press the "leverage button" (just above an to the left of the time zone buttons and battery) and the clock hands will spin. (It does not look like a button, its a lever)
    4) Release the leverage button when the correct time is reached.
    5) Supposedly, this new time will track correctly and keep accurate time.
    Posted on Jun 13, 2011
    • 52096 Answers
    SOURCE: adjusting time on a sterling noble regulator pendulum wall clock no buttons on back and cannot get cover off clock to get to hands
    electric or battery operated ? unplug or take battery out for 1 hr
    Posted on Nov 01, 2015
    How do i set a radio controlled clock seth thomas hd 1688
  • Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
  • 2
    Turn your attention to the small lithium battery-powered digital clock display on the back of your clock. With the correct time zone set, the digital display should accurately reflect the current local time.
  • 3
    Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment.
  • 4
    Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner.
  • Read more: How to Set a Seth Thomas Atomic Clock ' eHow.com http://www.ehow.com/how_6120534_set-seth-thomas-atomic-clock.html#ixzz1GyAcVHP2 hope this helps you
    Mar 17, 2011 | Seth Thomas Radio Controlled Wall Clock -...
    How do you set time zone model 3229-1
    Press the Mode button to display the alarm time then press the Adjust button till you get tot the corret time zone, press Mode again once have found the coreect timezone.
    Jun 22, 2010 | SkyScan 86742 Digital Atomic Wall Clock
    How do you reset the model 38229-1 clock time zones
    1. press "MODE" (it will show the alarm time) 2. press "ADJUST" (this will switch the time zones) 3. when it is on the desired time zone, press "MODE" to return to the clock.
    Apr 23, 2010 | SkyScan 86709 Atomic Wall Clock
    My solar clock needs setting. I set it back an
    1) Pull the batteries and replace them, or gently insert a straightened paper clip into the "reset" hole in the back of the clock. The clock will beep.
    2) Press the "receive" button" so the clock sets itself. The default time zone will be "EA".
    3) Press the "adjust" button untill the time zone is showing (rather than the day-of-the-week).
    4) Press and HOLD the "set" button down untill the hours digits start to flash2.gif.
    5) Now press the "set" button again six times. The time zone characters will flash.
    6) Press the "adjust" button untill your time zone appears.
    7) Press the "mode" button to return the clock to normal operation.
    8) Press the "adjust" button to display the day-of-week.
    Nov 09, 2009 | SkyScan 86742 Digital Atomic Wall Clock
    How do I set time zone
    My 86742 batteries took a dump after many years so I ended up with the same problem. It took me about an hour to figure it out, but here is the solution:
    4) Press and HOLD the "set" button down untill the hours digits start to flash.
    Do you think they could have made it any MORE complicated?
    May 18, 2009 | SkyScan 86742 Digital Atomic Wall Clock
    Cannot properly reset skyscan atomic clock
    press set button repeatedly -you get timezone mode and change your wished time zone and select your zone then press set button to normal mode and adjust the current time.
    thanking you.
    Nov 19, 2008 | SkyScan 86709 Atomic Wall Clock
    Atomic clock sky scan model 87801
    Press set button repeatedly -you get timezone mode and change your wished time zone and select your zone then press set button to normal mode and adjust the current time. kindly gave your rating after you read this.
    Nov 07, 2008 | SkyScan 86709 Atomic Wall Clock
    How do i set my clock
    Sep 02, 2008 | SkyScan 86709 Atomic Wall Clock
    Skyscan atomic clock
    and select your zone then press set button.
    Mar 08, 2008 | SkyScan 86709 Atomic Wall Clock
    Skyscan model 87800
    and change your wished time zone (for help go through time zone codeing list) and select your zone then press set button to normal mode and adjust the current time.
    Nov 06, 2007 | SkyScan 86709 Atomic Wall Clock
    Home Logo
    123 people viewed this question
    Top Home Experts
    john h
    Tom Chichester
    Are you a Home Expert? Answer questions, earn points and help others
