Question about Samsung Televison & Video
When i go to menu my tv speakers is in off mode, how do i turn it back on. it is a samsung 40 inch lcd tv. 2yrs i got help to turn it off cos i installed a philips home theater system.
My name is pat bruton and my tv is a samsung 40 inch lcd model la4oa550p1rxxa version ss03
    Master:
  • Samsung Master
  • 708 Answers
    Top Expert:
  • Samsung Master
  • 41,875 Answers
Return to the initial set up procedure and enable internal speakers.
Posted on Dec 05, 2016
May someone please send the service mode specifications for a Samsung LED 40 inch TV UA40EH5000R?
I don't have service mode specifications but I do have a Samsung and looked around for how to get it in service mode some time ago because the HDMI cables somehow disconnected themselves a lot. Thought it was an electronic problem but it turned out to be a parenting problem instead SO I have never used this information and can not vouch for it. I cut and paste it from a note I copied from a forum entry to use at your discretion:
First post:
To enter "Service Mode" Press the remote - control keys in this sequence :
From Standby Info-Menu-Mute-Power On
- The buttons are active in the service mode.
Remote - Control Key : Power, Arrow Up, Arrow Down, Arrow Left, Arrow Right, Menu, Enter, Number Key(0~9)
Careful though there are things you shouldn't touch in this menu.
avforums.com/forums/lcd-led-lc­d-tvs/601553-samsung-service-m­enu-research.html
Another post:
Method 1
Put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu.
Method 2
Turn the power off. On the remote, press Mute followed by 1, 8, 2, Power in sequence.
Method 3
With the TV in standby, press the {DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
Method 4
With the TV in standby, press the {SLEEP} {P.STD} {MUTE} {POWER} on the remote.
Method 5
With the TV in standby, press the {DISPLAY} {MENU} {MUTE} {POWER} on the remote.
Method 6
With the TV in standby. On the remote, press Mute followed by 1, 1, 9, Enter in sequence.
Samsung LCD Monitor Service Menu Instructions
End quote.
Good luck. Just a basic suggestion you probably don't need: keep track of any changes made by writing them down so you can put it all back if you have to.
Dec 20, 2014 | Samsung Televison & Video
How do I turn of the tv speakers on this model?
There should be option to stop the output from its internal speaker/s; provided there is "audio out" socket/s at the back of the TV. If there is no "Audio Out" sockets at the TV; this option will not be there at its audio menu.
Electro help
Dec 01, 2014 | Toshiba 40E200U 40-Inch 1080p LCD HDTV
RED COLOR NOT coming on TV, showing green all over place
I also have a samsung 40 inch. Try hitting the menu button on the remote the scrolling over to the right once and scroll down and hit pictures reset to see if that works. If it doesn't check your connections coming from the back of the source and the tv itself.
Sep 03, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
New samsung 40 inch LCD. When in the wide mode
if you are watching cable or satelite, you need to change the screen format output from the source to make sure it matches with the TV
Jun 14, 2009 | Samsung LN40A550 LCD TV
Samsung 40" Full HD LCD
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 22, 2008 | Samsung LN-S2651D 26 in. LCD Television
My samsung lcd 40 inch tv resets itslef after about 20 minutes back to DYNAMIC mode after changing it to STANDARD or MOVIE mode...?
i had the same problem. i accessed the engineer menu. while the samsung is powered off, you press info, then menu, then mute and then power on. you will get a new menu and from there you pick the option block. here, you have an option for 'shop' mode. disable that. Voila. worked for me. should work for you unless a different problem.
Aug 04, 2008 | Televison & Video
Sourondsound hook up
Hey jessyqadir,
If your home theater system's speakers still aren't functioning, you may want to make sure that your TV is correctly set to an external speaker mode. This can typically be done by accessing your TV's audio menu and choosing an option titled "Sound Select" or something similar. Many TV's will have a variety of speaker configurations they are able to support by default, but must be correctly set in order for audio playback to be heard through external speakers.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 20, 2008 | Samsung LN-S4041D 40 in. LCD HDTV
Sound Problem
ok paola! the problem is the headphone connector inside the TV.. maybe did not turn back the switch to speaker mode. check the headphone connector (at inside the tv). small problem goodluck paola!!!
Sep 14, 2007 | Samsung LN-S4051D 40 in. LCD Television
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
