If I buy two rock crawlers for my kids will the signals from the remotes interfere with each other?
  • 2,559 Answers
If they are on the same channel then yes. Most rc cars have a sticker or some other marking on the box if they are available in different channels. Usual they use 27mhz and 49mhz bands. Some use one band but have a switch to change the coding used...but this is usually also indicated on the box.
Posted on Dec 05, 2016
What is the best Electric RC Rock Crawlers?
Electric RC Rock Crawlers models tend to be quieter and have less power, but are generally beginner friendly. These are good all-around models you can run just about anywhere. Good for beginners, no smoke and not a lot of engine noise to annoy people around you.
Ideal for Beginners
Some Models are Waterproof
All Around and Budget Friendly. These are best because of much more reasons for knowledge of that view on Best RC Rock Crawler.
Apr 29, 2017 | Televison & Video
What are the pros of Danchee Trail Hunter?
Danchee Trail Hunter rock crawler is an affordable and reliable unit, it's also one of the best rock crawler RC starter units that can get you into this hobby. It has many more pros because of which you should get it. To get more details you can refer Best RC crawler.
Apr 29, 2017 | The Optics
Are rocking horses safe to buy as toys?
Rocking horses have a bit of a reputation for being dangerous because of a few accidents involving the reins around the rocking horse. You do really have to be careful not to leave young children unattended.
And you can shorten the reins on the horse so that there's no danger of strangulation.
when kids go too fast on a rocking horse they can cause it to tip over but this is true of nearly all motion type toys.
i still think the rocking horse is a classic but you should be careful to supervise kids who are using it.
Jan 14, 2013 | Toys
Maisto Rock Crawler stopped working when drove thru puddle
Nothing Works? My guess is you might have fried the circuit board. if that is the case you can either junk the car or replace the board if you can find a replacement one. Also, you might want to check that the batteries are firmly in place and no obstructions to connection.
Nov 16, 2012 | Maisto Rock-crawler Remote Control 4wd...
Rocking horse replace band
I'm from Brazil, so a have a toda's kids rocking horse end a need those four rubber bands. How can I buy these replacement rubbers?
Feb 01, 2012 | Giddy Up Rocking Horse
Maisto rock crawler. How do you remove the rear wheels? Front wheels have a phillips screw - easy; back ones look to be riveted on?
I am fairly certain the rear wheels can be removed with a 7 mm socket, but not sure if I remember correctly. They can be removed easily though. I am sure of it. it is just a matter of finding the correct socket size.
Jan 26, 2011 | Maisto Rock-crawler Remote Control 4wd...
Just bought this truck this evening, got it home, put brand new batteries in it, and it wont go unless you have the controller right next to it, and then it will go 2 ft away and stop. Have tried all...
Sounds like you got what I call a defective one. I usually return for a replacement when possible. We got a couple of these trucks for the kids at Christmas. We ended up having to send one back (defective) b/c the wheel alignment tab was missing so the truck wouldn't go straight. The other one only started acting up after my son played in the water with it. But at first they both worked funny until we put the antenna, the one that's on the truck, into a plastic tube to hold it up straight. Don't know if yours has that or not, but our tube was in the bag with the instructions. Good luck!
Jan 04, 2011 | Maisto Rock-crawler Remote Control 4wd...
Took the truck out of box, installed brand new batteries, drove for about 10 seconds then truck just stopped with slight burning smell.
well probelly the batterys where to much voltage i have arounf 70 masito rock crawler and 2 of mine had the same problem
Dec 27, 2010 | Maisto Rock-crawler Remote Control 4wd...
Infared won't work unless room is brightly lit
Just to provide clarification regarding the IR remote control- unfortunately its the opposite. A brightly lit room can negatively affect the infrared signal the remote uses to transmit the signal from the remote to the receiver- additionally interference may also be caused by fluorescent lighting. Another recommendation regarding IR signal interference is to; power everything off but leave the receiver & your TV on. Then proceed by powering one component on at a time, then testing the remote after each component has successfully been turned on. This process will also help you determine if a component may be causing the interference. Hope this helps! -Kirstie DISH Network
Nov 01, 2010 | DISH Network IR Remote Control
Remote/Remote sensor
bad remote maby kids dropped it best bet buy new one
Jan 06, 2008 | Panasonic SC-HT680 System
Televison & Video Logo
Top Televison & Video Experts
