I paid 9.99 cbs all access it wont let me put the code in from my tv
I need to cancel my Free Trial subscription with CBS All Access
hi Frane.
How do I cancel my CBS All Access Account? To cancel your CBS All Access subscription started through www.showtime.com, follow the steps below:
  1. Go to showtime.com and sign in to your SHOWTIME account.
  2. Go to Settings > Your Account and click the 'Cancel Subscription' link.
  3. Select 'Cancel only CBS All Access' and click 'Update Subscription.
How do cancel my CBS All Access subscription that started through SHOWTIME...
Dec 17, 2017 | Computers & Internet
Need cbs all access on my samsung smart tv (2015) what do you suggest
Look for the settings in the smart TV section and look for something that indicates "Software Update". If you find there is one install it and CBS All Access might be on there. If you can't find a way to look for a software update you can go online with your TV brand and model number and do a search for software update. If you find one it will give you instructions to see if you need it and what you have to do to install it.
Dec 15, 2017 | Samsung Televison & Video
Why can I only access my CBS AllAccess account on my iPad and not thru Roku?
Hope this solves the problem.
Add channel via your remote
1. Go to the Roku home screen by clicking the "Home" button on your remote.
2. Navigate to the Roku Channel Store by selecting "Streaming Channels" from the menu.
3. Navigate to the "Movies & TV" category, then find and select the "CBS All Access" channel. 4. Once on the CBS All Access screen, select "Add channel".
Oct 05, 2017 | Televison & Video
IF I SUBSCRIBE TO CBS ALL ACCESS ON MY APPLETV, CAN I USE THAT SUBSCRIPTION ON MY AMAZON FIRETV?”
If the CBS app on your Apple TV requires a username and password then yes you will be able to use the same account on your Amazon Fire TV.
Nov 21, 2016 | Computers & Internet
How do I cancel my cbs account it is automatically taken out every month
You would need to call them to do that we have no connection with CBS
Aug 19, 2016 | Televison & Video
I had cable took off and now i want just basic tv the regular channels abc, nbc, cbs and fox but when i try to scan the channels its asking me for a 5 digits access code for the westinghouse
you can go online and get the code. for some reason you have to go to westinghouse website and put in your model serial number abd it will give you a code allowing your tv to pick up local tv channels i dont know the reasong behind this
Dec 18, 2012 | Westinghouse " 40"" Class - LCD - 1080p -...
TV guide abruptly stopped receiving information
Off-Air reception (Antenna) of TV Guide comes from a supplier called Rovi (formally known as Macrovision, Gemstar). They have supplied your local CBS affiliate with a TV Guide application known as SCTE 127 or VBI in MPEG. Follow these steps until you have found a solution to the TV Guide - No Information Available.
1. Check to see if your local CBS station is coming in clearly not tiling.
2. Reset your TV Guide through your TV Guide Menu, for more information copy and paste the link below. (What usually works for me is setting up the guide by putting in 99999 for the zip code then answer all other questions. After it says your TV will receive the guide in 24 hours then setup the guide as you normally would with your zip code).
http://www.rovicorp.com/support/13094.htm?link_id=topnav
3. Contact your local CBS affiliate engineer and see if they are having problems with the TV Guide transport stream i.e. SCTE 127 or VBI in MPEG
FYI if you get your service from a Cable TV company they will have to pass this information through their system commonly referred to as Passing PIDS.
Feb 08, 2010 | LG 50PB4D 50 in. Plasma HDTV
Jvc remote control
"i already paid for the tv so why pay for something that should be readely available to me in the first place I should have access to all the features on the tv ".. WRONG!!!!!!!!!You should have a warranty for this TV but it's old , anyway. First,receive a reference image (let's say CNN).Second:press "Sleep Timer" key and set the value to "0". Then press "Display" and "Video Status" keys at the same time. Third: use "Vol +/-" and " Channel +/-" to select "2.DEF(D)".Go to "D03: V.SIZE" and modify step by step the value for best fitting. There is also switch " SW401" on the main board for centering the image . Finally, press "EXIT" key till you exit the "Service Menu". Don't try to modify anything else!!!!!!!!!!!!!!!!!
Oct 31, 2007 | JVC AV-27230 27" TV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
