Question about Cell Phones
I have no ringtone. it is switched off and cannot get it back on
Turned volume to max no ringtone sound will notify me of text or calls how to fix
depending on which phone you have you might have to assign a ringtone ? click on the phone icon,click on menu button,select ring tone ( you can have a different ringtone for each person if you want ) also when volume is tuned up you will notice on some phones theres a cog icon at the end of the slider ? click on that as other volume options will show ( they could be turned down ) sometimes our volume will stay down if you have had your phone on silent and switched back...or if we plug head phones in the volume turns down automatically.try scroll silent on /off or plug head phones in and out
Apr 26, 2015 | Cell Phones
How to change from ringtone to vibrate and back
Press and hold the * key to switch to turn "Vibrating mode on." Press and hold * again to turn "Vibrating mode off."
Dec 23, 2009 | LG CU515 Cellular Phone
Change ring tone
Here's how to choose your phone's tones, alerts, vibration etc: 1. On the main standby screen, press the white menu button.
2. Select "Settings".
3. Select "Personal".
4. Select "Profiles".
5. Double-click on the profile you normally use (this will usually be "General").
6. Select "Personalise".
7. Click on whatever you want to alter (for example "Ringing Tone" to change the call ringtone). Note that there are different ringtones for ordinary and video calls, and different settings for keypads and touchscreens.
8. When you've finished altering the settings, press the red button to go back to the main standby screen.
To switch to a different profile, tap the standby screen's date and choose the profile you want.
How to choose a ringtone from the music player You can also select a ringtone from the 5800's music player, just go to the track you want to use and select "Options". One of the options will be "Use Tone", giving you the choice of using it as the ringtone for the current profile, or as the tone for a specific person.
Jun 24, 2009 | Nokia 5800 XpressMusic Smartphone
Cant switch ringtones
you probably havent download the right type of ringtone file and your phone cant "read" that file. Make sure it is a wav or mp3 ringtone when you download it and make sure you download it to the MEMORY CARD. After you do that you will be able to go to documents and click the folder you saved the ringtones under...hit options and you will see the options. select foward....then to user profiles...hopes this helps...
Feb 14, 2009 | Dual Electronics CECT P168 Cellular Phone
Ringtone
Place the downloaded ringtone to \My Documents\My Ringtones..
Now goto Start->Settings->Personal->Sounds & Notifications -> Click on "Notifications" tab.
Select the downloaded file from the dropdown menu..
(U can also play the file for preview by clicking the play button)
Click ok...
Now ur new file will be set as ringtone...
Hope this helps...
Thanks,
Jegan..
Dec 27, 2008 | HTC Touch Diamond Smartphone
Ringtones
Most like your telcom switched from polyphonic ringtones to mp3 or real-tone ringtones only.
The Katana 6600 only plays polyphonics(QCB) ringtones. And they're impossible to find. So you have to make your own.
Aug 20, 2008 | Sanyo Katana SCP-6600 Cellular Phone
Nokia 1200 ringtone problem
don't waste your money. it is silent from your contacts.....if you remove silent mode in contacts option then you will have ringtone..........like any name contact and then go to its option then you will activate the ringtone rather of silent.........then you will hear ringtone.......if any one has any problem....then don't go.......to ........shop ...........
Dec 24, 2007 | Cell Phones
Vibration
The small switch on the top of the left edge of the iPhone turns on/off the vibrate function. Ringtones are affected by pressing the longer switch just below the vibrate switch.
Jul 25, 2007 | Apple iPhone Smartphone
Incoming calls
Try to reset the unit with the phone again.
Feb 25, 2007 | Motorola Mobility H500 Wireless Headset
Cell Phones Logo
23 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
