Question about Coffee Makers & Espresso Machines
Can you turn a CWTF15-APS Airpot Coffee Brewer to a pour thru
Can you turn a CWTF15-APS Airpot Coffee Brewer into a pour thru instead of a direct water line
  • 22 Answers
Yes, most Bunn CW models have the ablilty to be used as a pour over. There should be a lid on top.
www.kaldi.com
Posted on Jul 21, 2009
Bunn CW Coffee Brewer not brewing enough coffee - amount is half
Have you cleaned lately, put in an empty filter and fill with cold water with a tablespoon of white/clear vinegar. Run the brew cycle, empty pot and while still worm fill with cold water again with out vinegar. Than check filter to see how much hard water chunks are in the filter. Repeat with and without vinegar tell filter is clean. One question though is there a lot of steam coming out of the top during the brewing cycle if so inside there is a tube that may be cracked, broken or came loose, have to look inside. requires opening or disassembling unit to check. REMEMBER when taking apart UNPLUG unit first.
Nov 17, 2015 | Bunn CW Aps Single Airpot Coffee Brewer,...
Coffee maker works fine but no green light telling me its ready. why the green light does not work ?
Probably just a LED burned out!. You can live with it but if possible, go to nearest authorized repair site to get it changed
Coffee maker works fine but no green light telling me its ready why the... Fixya com Customer Support Products Repair Manuals Troubleshooting on Any... Superstar Expert Achievement Badge Fixya Mister Danger Tablets eReaders PC Laptops Expert Fixya
Oct 05, 2015 | Bunn O-Matic 23001.0000 CW15-APS Airpot...
Brewer stops @ halfway thru airpot, will not let me adjust brew level
take front panel off and on timer board is a little switch. move it from on to 1 then hold breww switch till you hear 3 clicks
Mar 31, 2014 | Bunn CDBCF 15 Coffee Maker
Bunn coffee maker cwtf15 water is boiling over
if it's actually boiling, replace the high temp limit fuse on the top of the tank on the inside rear of the brewer. may be stuck shut. if it's just overflowing the container, recallibrate by using a 64 ounce measuring cup and the instruction on the inside of the front panel
Oct 02, 2013 | Bunn CWTF 15-APS Coffee Maker
How much coffee per hour does the Bunn VPR-APS Pourover Airpot Coffee Brewer brew??
Bunn's pourover airpot coffee brewer brews 3.8 gallons of coffee per hour.
May 09, 2013 | Home
No hot water pouring water into top not plumbed is that an issue? bunnctfw15-ts
If it is not connected to water then it has to be used as a pourover brewer by pouring water into the top for brewing, there will be no water from the faucet.
Apr 19, 2011 | Bunn CWTF15-TS 23000.0006
I obtained Bunn CWTF15-APS from a restaurant next door to my office. They were no longer using it and had left it outside over the winter. When I hooked it up there was water leaking as a result of a few...
Have you tried running vinigar or a cleaner throught with the water or running a wire up it .Sometimes they plug up withlime and will not allow the water to run.Be sure and rinse it well after the cleanser so everything runs clear and you may have to do this two or three times, depending on how pluged it is.
Oct 16, 2010 | Bunn CWT 15-APS Coffee Maker
I have a Bunn CWTF15. Water does not fill the coffee pot full anymore. Is there a float that needs to be adjusted? Would descaling help this problem? Thank you.
If u haven't cleaned it out using 3/4 vinegar to 1/4 water, some times this will happen. after running this thru ur coffee maker, (u won't believe the junk that comes out), then run full pots of water to rinse out (2x's). This should help it perform better.
Sep 12, 2010 | Bunn Automatic Coffee Brewer CWTF15 1
Bunn CWTF15 Airpot brewer
If the unit does this constantly, it's probably seeping past the solenoid valve. you can try taking it off and check for dirt or corrosion that is stopping it from closing properly, or replace it. the solenoid valve is located under the front panel, and is silver in colour with 2 wires & 2 copper tubes coming to it. as always, please be sure there is no power coming to the unit before servicing!!
Oct 25, 2008 | Bunn NHB Coffee Maker
Coffee Makers & Espresso Machines Logo
115 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
