Question about Garden
What is facility for hydrostatic transmission control in tractor ? And how it works?
  • 109 Answers
SOURCE: Hydrostatic Transmission Failure
There is a transmission bypass lever on the back of the mower, if the bypass is moved out of the drive position, it will not drive in either direction, and will be really easy to push.
Posted on May 03, 2009
wilsodfarm
  • 986 Answers
SOURCE: Hi I have a 16hp roper lawn tractor it is about a
hydrolic oil I use 46
Posted on Jul 29, 2009
  • 85 Answers
SOURCE: checking fluid level
most units of this size & quality have a factory sealed transmission. to check or change oil, the transmission would have to be removed.
Posted on Sep 12, 2009
wireguy212
  • 1627 Answers
SOURCE: What type of oil do I use for a hydrostatic
Use a lo viscosity hyrolic fluid for you tractor and you will be good to go.
Posted on Apr 07, 2010
SOURCE: Hi, I have a Noma Lawn tractor and the hydrostatic
this isn't a solution but a question...not sure what i should put in there...trany fluid or oil....i was cutting the grass and it stopped going forward or backwards
Posted on May 31, 2010
Hydrostatic transmission fluid needed for bowlens tractor
The Bolens or iseki G152 will take a "TDH" fluid. The local Tractor supplier told me that as long as it says "Transmission / Hydraulic" on the container I would be OK. Most of the newer (and some older, like ours) have a single sump for the Hydraulics, differential, and Transmission and this is the product most of them use. I've been putting that in on my G152 (tx1502).
Any local tractor supply will have it. Even NAPA auto parts carries a TDH fluid. Again, whatever brand you get make sure it says "transmission / hydraulic" on the label.
Flyer
May 26, 2016 | Garden
Heal lever won't press down to engage transmission on hydrostatic transmission
Hydrostatic Drive Problems?? - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
May 30, 2006 - Hydro-Gear Transaxle:218-3010L I got this tractor as part of the deal when I ... After spraying the heck out of it and pressing the brake pedal down several ... I pull on the handle in the back and it moves the lever but still won't move. ..... while in the air and turning the wheels with the transmission engaged? mtd lawn tractor wont pull hills
Oct 18, 2009
briggs trouble
Jul 5, 2008
Peerless transaxle repair, Husqvarna mower
Oct 13, 2006
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Missing: heal
HYDROSTATIC TRANSMISSIONS - Small Engine Information
smallengineinformation.com/?page_id=370
Jan 14, 2016 | Garden
Hydrostatic transmission in YTH2348 is very weak, pulls intermittently then stops. I changed the oil put 50wt in it, still doesn't work.
hydrostatics will not work with gear oil they take transmission fluid . or hydraulic fluid check with a dealer or read you manual
Sep 15, 2015 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Model 917.203900 22 HP lawn tractor. Shifts consistently into forward but frequently won't shift into reverse. What's wrong?
  1. Craftsman Hydrostatic Transmission Fluid Change - YouTube
    ? 40:15
    www.youtube.com/watch?v=vd1EqFtTYgk
    May 10, 2012 - Uploaded by Smokeasammie
    I change the gear oil and hydrostatic transmission fluid on my Craftsman Lawn Tractor. Fluid per Peerless ...
Jul 20, 2015 | Craftsman Garden
I got an agco tractor with a cvt transmission it starts but does not go forward or backwards
A cvt transmission is a real fancy hydrostatic transmission controlled by a computer and sensors acting on the controls I think you have a wiring or other electrical problem
May 27, 2015 | Garden
How to fill hydrostatic transmission fluid on Poulan Pro
How do I check the transmission
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Fill Hydrostatic Transmission in Lawn Tractor
http://husqvarna.custhelp.com/app/answers/detail/a_id/387/~/maintenance---what-type-of-oil-is-used-in-the-hydrostatic-transmissions%3F
Jul 28, 2012 | Poulan Garden
Linkage inside gear box does not engauge. Mechanics work to the bolt on top of the bottom gear (differential) box. Neither forward nor reverse work.
Most likely a hydrostatic transmission and most likely it is dead. Buy a new one or look around on google and craigslist for a used one. Maker and model number will be printed on top and possibly stamped on the bottom. New hydrostatic transmissions cost more than a new mower.
Mar 31, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
YTH200 TWIN HYDROSTATIC TANSMISSION OVERHEATING
call the manufacture for warrenty work if this is still new
Apr 04, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
John Deere LT190 Lawn Tractor transmission problem
is it hydrostatic drive? if so you probably need to change filter and fluid
Oct 01, 2008 | Garden
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
