When switched on, water came gushing from the front. After a while tried again and it seems to be working ok at this moment. Any ideas what went wrong please?
Jimster
  • 240 Answers
SOURCE: Kenmore 80 series washer model #11092587210
Almost sounds like a timer or timer motor problem.  Could also be a loose wiring harness around the timer.  When you said it when into spin, but the next day, did the timer move at all during the "break".  Usually, a lid switch will give off that "tell-tale" clicking sound when lifting the lid.  See if it makes this noise, but it really doesnt sound like a lid switch issue.  Really sounds like a dead spot, or spots, in the timer.  Let me know.  Jim
Posted on Oct 18, 2007
dazmaraz
  • 67 Answers
SOURCE: Hotpoint Ultima WT965 - Water gushing out from door and soap drawer
you have a blocked filter, unplug from mains, take off back panel you will see a black sump hose coming from the tub to the pump, tilt the machine forward and put a dish or bowl under sump unscrew clamp and pull off slowly to release any water in the drum. You will find a blockage, also what appears to be a ping pong ball dont throw away it is meant to be there.
Posted on Mar 07, 2008
  • 417 Answers
SOURCE: Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Posted on Nov 04, 2008
  • 99 Answers
SOURCE: kenmore f l washingmachine 110.46472501 leak from dispenser
This is joyce
is dispenser in properly, remove and put back in. sometimes the peice that is seperating the solid from liquid is in the way and causes water to come out top.
also water pressure has a lot to do with this. has this changed. have you removed filter?
thanks
joyce
Posted on Feb 06, 2009
  • 20 Answers
SOURCE: error code Ox8007065D
http://mb.music.yahoo.com/music/Support/threadview?m=te&bn=mus-ymefeedback&tid=2440&mid=-1&tof=8&rt=2&frt=2&off=1
Posted on Apr 02, 2009
When I start the washer, it fills just fine with no problems but once it starts the cycle, it gushes water from the bottom of the door
Check the bottom of the plastic inner door. If there is a crack or a gouge, have it replaced. Also check the rubber door boot for holes above the water line
May 09, 2014 | Maytag Neptune MAH5500B Front Load Washer
When machine spins after wash water gushes out of detergent drawer. Checked black hose from drum and found a blockage of colour catcher sheet thought this was the problem but water is still gushing out the...
Hi.
The problem can be a defective pressure switch. The pressure switch detects water level. Pressure switch not working correctly may result in overfill. Try cleaning the rubber hose connected to the pressure switch. Check also pressure from inlet hose and look for blockage in detergent drawer.
Aug 18, 2011 | Hotpoint Ultima WF860 Front Load Washer
My ignition barrel broke for my vauxhall corsa,been fixed but my sony gt200 cd/radio will not come on . will not play.usually when you clip the front face unit into place the system lights up.at the moment...
your cd switch wire is not recieving any power. when you turn on your key it turns on the switch wire. the wire/contact on the ignition barrel may not have been connected properly. check the wiring and the barrel again
if this doesn't work connect the yellow and red wire at the back of the radio.it will work without the keys now
Sep 23, 2009 | Sony XPLOD CDX-GT200 CD Player
Front panel to motherboard, ASRock P4i65G, connections
the power switch is on the 3 and 4 pins....the 7 and 8 pin are the reset pins. Trying it on wrong pins just won't startup the board but won't short circuit anything.
Jul 28, 2009 | Computers & Internet
in this case i would remove the pump (bottom, back, right hand side)
this is easy cleaned.... then remove dispenser and dropdown pipe and clean out clogs
Jul 29, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Mar 06, 2008 | Hotpoint Ultima WD72 Front Load...
Oct 05, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
