Question about Denon Audio Players & Recorders
Denon dht500sd surround system.we had sound but no picture its been fitted with a new laser and we still have sound but no picture. it is connected to the TV by component cables
fcollingwood
  • 58 Answers
SOURCE: Surround sound
Hi
Your receiver is capable of video conversion, so there should be no problem using your component cable.
Does your TV accept component, or only S-Video? If you can run component to your TV, the best quality signal path would be using a component cable from your Verizon box to your receiver, and component from your receiver to your TV.
Make sure you have set up the video input correctly, so that it is set to accept the incoming signal on the correct sockets.
Posted on Mar 21, 2008
  • 54 Answers
SOURCE: Best Way ti connect a Denon AVR-1602 Surround Sound system with a Bell Express View Satlite reciever and Plasma TV
lets see, 3100 has no digital out, so you need analog inputs for the audio. Best picture with the 3100, use S-video. Digital input for the DVD sound and S-video in for picture. OOPS....does your TV have a S-Video input ?. If not then you have to use the RCA standard video type connector, as this particular denon doesnt do up or down conversion to or from S-video to old style RCA.
Sorry for the late response.....Rob
PS.....the HD bell wont do you any good with this receiver nbecause it doesnt have component video inputs. Enjoy Bells' superior picture with regular TV . Its way better than cable. Rob
Posted on May 09, 2008
Xtremeroofin
  • 67 Answers
SOURCE: tv built-in dvd player wont play thru surround sound
use your t/v audio out with RCA cables to your reciever input like(vcr in, dvd in, dtv in)
Posted on Dec 20, 2008
  • 119 Answers
SOURCE: hi denon to cable box to samsung lcd
Unless you are having res. issues you can use component / optical / coaxial cables to connect all your devices to your denon and from your denon to your tv using component cables also
Posted on Feb 25, 2009
smarthome2
  • 1114 Answers
SOURCE: no picture with cable to denon AVR-589
Long and painful answer!!! However, in the end, you need to bypass HDMI thru your receiver and go direct to the TV. Connect Digital Coaxial or Optical for audio to your receiver. Your version of HDMI in your receiver is not compatable with today's HDMI version. Yours is 1.1a and the current version is 1.3b going to 1.4. If you want detailed info as to "why", just google "HDMI 1.1 problems" you can read for hours! Sorry for the bad news! However, it is what it is. Hope this helps. If you need further help with setup, post a comment and I can give you further help.
Posted on Feb 28, 2010
Denon dht500sd /when playing DVDs we get the sound but no picture,a new laser has been fitted but it is still the same
It's probably an electronic fault. You need to trace the path of the picture signals after it leaves the laser. You might need the circuit diagram for it. But suspect any major IC that deals with the picture.
Dec 03, 2016 | Denon DHT500SD System
No picture with cable to denon AVR-589
Feb 28, 2010 | Denon AVR-589 Receiver
"PROTECT" appears on my DENON DHT-500SD
Sounds like a speaker wire is shorting against either another speaker wire or something metallic. Check your speaker wires to make sure they're not shorting (touching). If that doesn't work, I'd take it to a repair facility. Good luck!
Feb 16, 2010 | Denon DHT500SD System
Schemat denon dht500sd
type in dht500sd schematic u should get excellent results
Aug 08, 2009 | Denon DHT500SD System
No picture on tv
This unit upconverts all video inputs to component output, so connect all your devices to your denon audio and video inputs and component video out of the denon to the tv component in and all should work fine
Feb 21, 2009 | Denon AVR-886 Receiver
You need to check your speaker wire connections at the speakers and at the amplifier. You must have a positve and negative speaker wires touching. If you check them and still same result you need to unhook all speakers from amp and speakers and hook up one speaker at a time to see if you get message for each speaker and when you finally do you will know which speaker wire and speaker is giving you a problem.
Nov 07, 2008 | Denon DHT500SD System
Speaker hiss with TV only
Hissing sound caused by input section RCA cables defected grounding maybe loosed or the RCA cables are defected already replaced it with new RCA cables so hissing sound is gone.
Hope it may help you;
Regards;
VOTIT
Oct 11, 2008 | Denon DHT500SD System
Denon DHT-500SD - DVDs wont load
the problem may be two fold
1 the optical pickup assembly's lens may be dirty and needs to be cleaned (donot use any liquid to clean the lens just a soft cotton swab will do)
2 the optical pickup assembly has failed and can no longer read discs (if the laser or sensors inside the optic fail it is "blind" and can not "see" the disc)
start with the cleaning.
May 25, 2008 | Denon DHT500SD System
Denon surround saying protect on display
Make sure none of your speaker wires are touching, this will cause it to shut down instantly.
Oct 15, 2007 | Denon DHT500SD System
27 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
