Question about Dishwashers
Tandy dishwasher - when switched on, all programme lights come on, it beeps. when you shut the door it humms as if to start, but nothing happens
SOURCE: Clean light on dishwasher won't stop flashing
yust reset press heated dry-normal-heated dry normal-and it will work 100% remember that code it is reset code for wirpool quiet partner and many other models
Posted on Feb 19, 2009
vickygomar
  • 460 Answers
SOURCE: Hotpoint BF1620 Integrated dishwasher not working
Lets try the following hope this works
1.- unplug the appliance, isolate it from the electric supply.
2.- Remove the kitchen unit plinth and check inside the inspection panels below the door to see if there is water in the base.
If there is, sponge it out and then try the machine again.
Was this helpful?
Posted on May 15, 2009
  • 43 Answers
SOURCE: GE profile PDW9880J00SS dishwasher just beeps
appears control is going bad,or problem with control circut
Posted on Oct 16, 2009
  • 16 Answers
SOURCE: wont go on to programme when switched on starts
Check that you have tuned on the inlet water tap(faucet usa).
Posted on Jan 24, 2010
sudel
  • 90 Answers
SOURCE: Hotpoint WMF540 will not start. Lights keep
Had this same problem myself. To get mine to start i have to push the door to until it starts.
Posted on Mar 07, 2010
Service number kuds301xbl2
I would find the electrical breaker for this unit and shut it off for a minute, then re set the breaker thus resetting your unit.
Apr 28, 2013 | Maytag MDBH975AWS Stainless Steel...
The programe wont stars
Dear Sir:
You must fit very well the door catch. The switch is the elements most important for to run the dishwasher. Otherwise you must waste your time.
See the diagram attached, and you will the switch door must be close for to close the starting relay for RUN the main motor.
sincerely. God bless you
May 04, 2012 | Baumatic 23 in. BDW13 Built-in Dishwasher
Classique dishwasher, 3 weeks old. turned it on and chose dishwashing programme. Started ok but then beeping sound and has gone to pots programme. Light jus flashes. Stopped. Cannot reset. tried turning it...
You have a warranty, call the seller and ask how to use the limited warranty you have on the machine. As long as you didn't do something to the machine, they will usually just give you a different one to save on service calls in the long run, just get an exchange, I don't see any reason they won't do it.
Sep 01, 2011 | Dishwashers
We have a Haier DW12-PFE2-U dishwasher thats 2 years old. The cycle stopped yesterday leaving an amount of water in the bottom and all of the program lights are illuminated with a recurring beeping sound...
Refer userr guide on page 21. It reads...
When all the programme indicators " J" blink.
Have you checked whether:
the door is closed properly.
The door switch could be the problem or the door seal is pushing the door open. May need replacement.
May 19, 2011 | Dishwashers
Set dishwasher to start - sounds as if it starts but then 5 mins later beeps. When door is opened nothing has happened and instead of the i.e. P4 programme displayed E1 is displayed? Can you help on what...
Possible that there are no outputs from the program controller unit and so you will need to check with a multimeter the voltage to the inlet valve/motor while the washer starts. If there is no supply then the controller is faulty , if not check the inlet valve and the pumps for fault.
Make sure that the door switch is working as unless the switch latches the program controller will not work- safety feature.
Feb 14, 2011 | Smeg DWI614 Built-in Dishwasher
I have a F&P dishwasher model DW60CDX1 (around 5 years old) which we cannot start a cycle. The dishwasher turns on (power button and all programme indicators light up) but when you press a programme...
The micro switch in the door which senses the door closing has probably failled. This is accessible once the inner door cover is removed. Switch should be under $10 from electrical store. Or buy through appliance manufacturer.
Jan 17, 2011 | Fisher and Paykel Dishwashers
Our dishwasher model eidw6105gs1 will not start. You push the start and nothing happens. The lights are steady.
Think you need to reset it, leave it turned on overnight and door shut firmly, sometimes the problem is programme can not be finished from before.
Dec 01, 2010 | Electrolux EIDW6105GB 24 in Builtin...
Zanussi FLE1416W Front Loader
Most possible reasons that the door switch or timer unit is defective. The dishwasher should heat the water to about 55 C as the heating cycle starts. In these cycle, the dishwasher pauses after has filled with water and wait for the water to reach the temperature. If the water isn't being heated (because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. if you think that a user manual may help you more, it can be downloaded ($8.95) at url: http://www.download-manual.com/shop/Zanussi-FLE1416W-User-Manual-pr-8261.html
Jan 22, 2008 | Zanussi FLE1416W Front Load Washer
Dishwashers Logo
Top Dishwashers Experts
