Question about Vehicle Parts & Accessories
What is requirements of charging cord for black n decker car jump starter
Volts? Amps? Polarity?
  • 52 Answers
SOURCE: I need to replace the 120 volt AC wall adaptor
Here is your link to buy it.
http://www.centurytool.net/5140044_04_Charger_W_Small_Jack_p/5140044-04.htm
Posted on Jan 11, 2009
  • 34 Answers
SOURCE: i lost my power cord for my seagate freeagent pro
  • Power Specifications:
  • Input: 100-240Vac, 50/60Hz, 0.55A Max. 50VA-80VA
  • Output: 12Vdc 2A
http://www.evertek.com/viewpart.asp?auto=41485&cpc=PPI
Good Luck and thank you for serving.
Posted on Jul 07, 2009
SOURCE: lost the 12-volt DC charging cord for my vector jump starter
google the name and model #. The home website should come up in search. Go to site, and look in support, or replacement parts.
Posted on Aug 23, 2009
  • 5 Answers
SOURCE: i have a power on board veco12pob 450 amp jump
I have the same problem: today I tried a 12 volt, 1500 milliamp (1.5 amp) power cord and it has charged mine halfway, so far. It fits the plug in, but not certain, yet, that it has enough power to fully charge.
Posted on Aug 28, 2010
SOURCE: Vec010bd AC charger part # 5140045-34 question . . .
barrel pin 12v 500Ma is correct. the only other required stat that you need to know is that the polarity is( ---------that's how the inside pin polarity is shown on the transformer. Go to any radio Shack, and they have this charger in stock. tell them you need a 120v. a/c input, 12v. DC 500 ma output, with the center (inside) pin positive( ).It should be less than $20.00
Posted on Oct 16, 2010
Testimonial: "Thanks RetiredRon, this was the first post I'd seen for the polarity of the plug."
What is the charger part for JNC300XL jump starter
you should have a red and yellow button on one side Right above it is a small AC adapter hole for a plug in charger.. IF you cant find the cord or you lost it, You still can charge it by hooking it up to a running car red to red and black to black for 10 mins and it should give it a good charge, IF fully dead leave it for 20 mins or hook it up to a battery charge low amp like 2 amps and leave it for 5 hours and do 1 hour each month unless used to start a car.
Aug 25, 2014 | JNC300XL Jump-n-carry Ultra-portable Jump...
Can you charge a sl1028 with a stander 120v AC cord
Asuming it is the right connection, you have to check the polarity and a page is correct, then yes
Oct 29, 2013 | Black & Decker Black And Decker 2 Million...
Manual
Just to play it safe I would NOT jump start while charging, It sounds like one would be putting out too much volts/amps ETC and could damage or the even kill the battery.
Jul 06, 2013 | Black & Decker 400 Watt Electromate With...
My interior lights turn on everything works its just my engine wont turn over it sounds like a clicking noise
Battery is weak or bad. The clicking noise is the starter solenoid and is a result of...not enough power in the battery.
Aug 22, 2011 | 1987 Cadillac DeVille
Situation: My battery has died. I would like to place my car in Neutral so that I can have another car give me a jump. Problem: I cannot place my car in neutral because my car will not allow me to...
You need a portable jump starter, may be a friend has one, or swap batteries with another car that has a battery similar to yours (I.E. top vs Side posts and size) a size that will fit same or a little smaller OK and polarity same so you don't cross connect or reverse the polarity remember the + red post goes to red+ and the - black goes to black- post. Then start move car to roomier area then swap battery back then jump start to get it home. and remember to charge your battery with a charger driving does not fully charge and a low battrey may start your car but it makes the starter get hotter from pulling higher amps for a longer time.
Patrick Mot
Feb 12, 2011 | 1994 Toyota Camry
I have a power on board veco12pob 450 amp jump starter unit and my question is what kind of adaptor do i need . I would like to know the volts and amps.
Jun 29, 2010 | JUMP START SYSTEM
I have the endurance jumpstart i need to know how to charge it so i may use it
a charger of the wright polarity and volts (12-14.5volts) that can charge at say 500ma and fits the charging scocket in the power pack will charge your power pack up ok
Mar 28, 2010 | Black & Decker Jump Start System 450 Amp...
Feb 20, 2010 | JUMP START SYSTEM
Need instructions on how to use black and decker jump start
Amazon.com: Customer Reviews: Black & Decker VEC010BD Start It 300 Amp ... Instructions note that units are already partially charged before ... Recent discussions in the Black & Decker VEC010BD Start It 300 Amp Jump Starter forum ...amazon.com/Black-Decker-VEC010BD-Start-Starter/.../B000E1HAIK - 235k - Cached
Feb 22, 2009 | Black & Decker Jump Start System 300 Amp...
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
