Question about Hitachi Office Equipment & Supplies
Finding reset button for a Hitachi - Hitachi Office Equipment & Supplies
HITACHI SJ300 Problem
The only thing I found is the complete service manual which may help you repair individual units---finding parts may be another issue.
http://www.hitachi-america.us/supportingdocs/forbus/inverters/UserManuals/hitachi-sj300-and-l300p-series-inverters-service-manual.pdf
Jun 10, 2012 | Televison & Video
Hitachi 51s500 screen is flashing, but no real picture or sound, where is the master reset button?
this set has no reset button at all. If the screen is flashing is it red,green, blue, 3d or what? This may be a clue to what is wrong.
May 05, 2012 | Hitachi 51S500 51" Rear Projection...
Replaced main bulb in front but lamp button on front of tv is still blinking and tv won't show picture
The lamp timer on the Hitachi projector must be reset whenever the lamp has been replaced. The "Lamp" indicator on the display will light red or the "Change the Lamp" message will display when the lamp timer needs to be reset. Hitachi recommends that the lamp timer never be reset without replacing the lamp and to always reset the timer when the lamp is replaced. The message functions of the projector will not function properly if the lamp timer is not correctly reset.
  • Turn the power on. Press the "Reset" button for three seconds until the "Lamp xxxx hr" message appears on the lamp timer on the bottom of the screen.
  • 2
    Press the "Menu" button on the remote control while the lamp timer is displayed.
  • 3
    Press the left arrow button. Select "0" and wait until the timer display clears.
  • If this was helpful a vote on the thumbs up for the free advoce would be greatly appreciated. Thanks
    Apr 04, 2011 | Hitachi 60V500 60" Rear Projection...
    How to reset the filter timer of HITACHI CP-RS55 ?
    (1) While the projector running, press the MENU button to open the menu.
    (2) Choose "OPTION" , then press ENTER button.
    (3) Choose "FILTER TIME", then press and hold the RESET button for 3 seconds.
    (4) Choose "RESET" .
    Feb 25, 2011 | Hitachi Performa CP-RS55 Multimedia...
    How do I reset lamp time & filter time on Hitachi pj-tx100
    Hitachi
    • Turn on the projector.
    • Press the "RESET" button on the remote control for approximately 3 seconds until a dialog box is displayed.
    • Select the "RESET" using the up-arrow.png button.
    • Your lamp counter will now be reset.
    Jul 05, 2009 | Hitachi PJTX100 Multimedia Projector
    Can't reset lamp timer
    Turn on the projector, and reset the lamp timer.
    (2) Choose the “OPTION” on the menu using the / button, then press the
    button or ENTER button.
    (3) Choose the “LAMP TIME” using the / button, then press and hold the
    (4) Choose the “RESET” using the button.
    memo When the lamp has been replaced after
    Dec 11, 2008 | Hitachi CP-X1200 Multimedia Projector
    Resetting the air filter timer
    If you do not have a remote here is how to reset the filter time. Use the "Menu" bottun to get the "easy menu" to display. Push the down arrow until you get to "Filter Time," then push and hold the RIGHT arrow to reset the filter time. DO NOT try to reset using the "Reset" option on the easy menu, it will not work.
    Apr 22, 2008 | Hitachi CP-S335 Multimedia Projector
    Resetting Air Filter Timer once cleaned.
    Menu, options, filter time. When the filter time is displayed, press the reset button for at least 3 seconds. The reset menu will appear and you can select RESET.
    Feb 01, 2008 | Hitachi CP-X385 Multimedia Projector
    Hitachi 61UWX10B 61 in | TV will not turn on after reset | any reset button inside the TV ?
    My Hitachi was doing the same thing. The culprit is a bad or intermittent 5V relay on the power supply board.
    Jan 30, 2008 | Hitachi 61UWX10B 61" Rear Projection...
    49 people viewed this question
    Top Hitachi Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
