Question about Lands Phones
How can i get the location of this numbers 0833405440
    Top Expert:
  • Lands Phones Master
  • 43,051 Answers
Try a reverse lookup with a computer
Posted on Dec 05, 2016
Where is the engine no located
to many engines out there to give a good answer
try this for now
nonspecific downloadble document on engine number locations
[DOC]Engine Number Location Chart No 2. - RVCS rvcs-prodweb.dot.gov.au/vehicle%20identification%20and%20engine%20number%2...
VSS VEHICLE IDENTIFICATION AND ENGINE NUMBER LOCATION CHART SYSTEM. GRIDLOCATION CHARTS ... Chassis Number Location Chart No 9.
May 19, 2016 | Cars & Trucks
Where is the serial number located
Digital Imaging: How to find the serial number? : FAQ : Sony ...
https://sony-paa-pa-en-web--paa.custhelp.com/.../digital-imaging%3A-ho...
Jul 9, 2015 - If you have a Camcorder, Digital Still Camera or DSLR Camera, Theserial number can be found on the label located at the bottom of the ...
How to find your camera's serial number - Kodak
www.kodak.com/eknec/PageQuerier.jhtml?pq-path=5231
KodakThe serial number for KODAK Digital Cameras is located on the bottom of the camera, and is made up of both letters and numbers. There should be three to five ...
[PDF]A guide to locating Canon equipment serial numbers
Dec 08, 2015 | Cameras
Need to program new phone numbers
The manual is available here: www.uniden.com/pdf/CEZ260om.pdf. If you search google for "uniden cez260 corded phone manual" it is the first result.
You can find the instructions in the fourth column of text under "Storing a Name and Number in Memory"
Here is the text from that section, but I can't promise the copied text is accurate. Check the pdf at that address if anything doesn't work.
1. Press STORE. LOCATION? shows in the display.
2. Press the desired memory location (0 to 9 or quick call buttons A, B, or C.) NOTE: Press LEFT or RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C to select a location.
3. Press STORE again to con? rm the memory location. NOTE: Use Delete to erase existing memories or to correct errors.
4. Use the number keys to enter the telephone number (up to 32 digits) and then press STORE to save. (The unit will not dial a phone number in this mode.) The cursor automatically moves to the text line for name entry.
5. Use the number keys to enter the name of the person associated with the telephone number you just entered. More than one letter is stored in each of the number keys. Press the keys multiple times to scroll through the letters for that key. For example, to enter "B," press "2" twice. Press LEFT two times to create a space. NOTE: The ? ashing cursor automatically moves to the next position or you may press LEFT or RIGHT to move the cursor to the next position.
6. Press STORE to save the name.
7. To enter another name and number in a di erent memory location, return to step 1 and repeat this process.
Storing a Pause in Memory
The REDIAL/PAUSE button has dual functionality and becomes a pause button when pressed in sequence after the STORE button. It is valid only when storing a number into memory locations. Use the REDIAL/PAUSE button to insert a pause when a delay is needed in an automatic dialing sequence (for example, when you must dial a 9 to get an outside line or when you enter codes to access your long distance company).
NOTE: A pause is 3 seconds in length and you can store more than one if a longer pause is needed. Changing a Stored Number Repeat the storage sequence under Storing A Name and Number in Memory, and press DELETE to delete the old number before entering the new number.
Erasing a Stored Name & Number
1. Press STORE.
2. Press the memory location (0 to 9 or quick call buttons A, B, or C) to be erased.
3. Press DELETE.
Copying Caller ID Memories to User Memory
1. Press LEFT or RIGHT to view the caller number and name you want to copy.
2. PressSTORE.
3. Press the memory location (0 to 9 or quick call buttons A, B, or C). The number ? ashes if there is a number already stored in that memory location.
4. Press STORE to enter Edit mode, and then pressSTORE again to edit the name. NOTE: Select a di erent memory location by using LEFT and RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C.
5. Press STORE to con? rm and save. Wait three seconds to exit.
NOTE: If the name you want to enter is longer than 12 characters, only the ? rst 12 characters will be copied into memory.
Storing a Redial Number to Memory
1. Press STORE.
2. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If a number is already stored in the memory location, it will appear on the display. Use LEFT and RIGHT to select a di erent location.
3. PressSTORE again to con? rm.
4. Press REDIAL/PAUSE, and then press STORE again.
5. Enter the name, if necessary, and then press STORE to con? rm.
Copying a Redial Number to Memory
1. Press REDIAL/PAUSE while on-hook. Redial number will display along with PICKUP PHONE.
2. Press STORE.
3. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If there is a number already stored in the memory location, it will appear on the display. Use the RIGHT or LEFT buttons to select a di erent location.
4. Press STORE twice.
5. Enter name, if necessary, and then press STORE again to con? rm and save.
Dialing Numbers Stored in Memory
1. Press DIAL.
2. Press a memory location button or use LEFT or RIGHT to scroll through stored memory locations to ? nd the desired number. The number in that memory location displays.
3. Press SPEAKER or pick up the handset to dial the displayed number.
OR
1. Lift the handset or press SPEAKER.
3. Press DIAL again to dial the stored number.
Jun 11, 2015 | Uniden CEZ260 Corded Phone
How to check service tag on supermicro servers
AFAIK Supermicro is not using Service tags like Dell or Lenovo. Instead they go by serial numbers. The location of the serial number depends on the type of the server:
Blade serial number (SBI... or SBA...) is located on the side
Blade Enclosure serial number (SBE...) is located on the rear side
CMM (chassis management module) serial number (SBM...) is located next to the latch
Rack-mountable chassis serial number is located on side of chassis by the sliding rail
4U Tower Chassis serial number sticker is located on the bottom side
Rack-mountable Systems' Serial Number is located at the rear side by I/O panel
Embedded Systems' Serial Number is located on the I/O panel
Check this website for more:
http://www.supermicro.com/support/SNGuide.cfm?sn=ss
Feb 23, 2015 | SuperMicro Computers & Internet
Where is the model serial number on the Canon MX882
Issue: Where is the serial number located?
Solution: Locate the serial number MX882
Locate the Serial Number The serial number of the MX882 is located inside the printer, as shown below.
  1. With the printer powered on, open the Paper Output Tray (A).
    The above illustration shows a PIXMA MX870.
  2. Lift the Scanning Unit (Cover) (B) and fix it with the Scanning Unit Support (C).
  3. Wait until the print head carriage moves to the ink tank replacement position.
  4. To the right of the print head carriage, inside the printer, is a white sticker that is attached to a metal plate. The serial number is located on the white sticker. Please see the illustration below.
    The serial number starts with four letters and ends with five numbers, for example: ABCD01234.
May 09, 2011 | Canon Office Equipment & Supplies
How can i know mobile number location in india?
hi...
please go to this webiste and type the mobile no you wanna find the location...
http://www.indiatrace.com/trace-mobile-number-location/trace-mobile-number.php
this shows.
1.location
2.network
Jul 15, 2010 | Nokia N72 Cellular Phone
I am in the midst of having to move or possibly store my Wurlitzer 1015 and am wondering if there are insulated/protected covers for this expensive machine?
Have a look at this jukebox cover that is being auctioned on Ebay.
Here is the item listing number and location:- 220562227613 Stevenage Hertfordshire UK.
Regards
Alan Hood
ami-man
UK
Item number: 220562227513 Item location: stevenage, Hertfordshire, United Kingdom Post to: United Kingdom
Item number: 220562227513 Item location: stevenage, Hertfordshire, United Kingdom Post to: United Kingdom Item number: 220562227513 Item location: stevenage, Hertfordshire, United Kingdom Post to: United Kingdom
Mar 24, 2010 | Wurlitzer Jukebox 1015 One More Time...
Chassis number location
the number is located on the hood also it's located on the dash on driverside window lower corner and on trunk lid by the trunk latch, also inside door pannel driver side.
Jun 19, 2009 | 1994 Volvo 940
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
