SOURCE: Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
SOURCE: Trips out the mains fuse.
must be an earth fault within the machine. suspect a burned out wire or switch. possibly carbon dust within the motor. take the top off the machine & have a look at the wireing loom. SWITCH THE POWER OFF FIRST
SOURCE: LG WASHING MACHINE WM14225FD
My machine would not switch on this morning, no beeps or lights, I traced it to a small fuse on the main circuit board. you get to the board by disconecting from the mains, removing 2 crosshead screws at the back of the machine and lifting the top of the machine off ( once screws out, slide top of machine back about 1cm and then it just lifts off. You can now see the main circuit board, behind the control panel on front of machine. the fuse is hard to see and is solderd to the board on the lower left side, I solderd onto both ends of the fuseand replaced with a 10 amp HRC fuse, I still need to find the correct fuse rating, this worked for my machine.
However, and its a big however, If the 13amp fuse in youre plug blew and the trip on youre consumer unit, then I would imagine something big (pulling a large current) has gone down in youre machine to cause all these to blow, anyway hope this helps, Robin.
SOURCE: Fridge on Fridge freezer not working
Ok there is a drain pan under the evap. coil under the fan that may be clogged and full of ice there is a 3/4" hole the water drains out of that needs cleared if there is a puddle of ice over it , the ice will also effect the airflow traveling down the duct to the fresh food section of the unit.
If there is no ice puddle at the bottom of the refrigerator then make sure the unit is cooling well by making sure it has been running for 10 min. or so and checking the coil in the freezer , it should have a small layer of frost on it showing its getting cold the whole way through it. Let me know how this works.
Phil
