Question about HP LASERJET PRO MFP M225DN
What shall i do in "scanner error 13" in HP Laserjet Pro MFP M225dn ?
  • 1,381 Answers
Do a power reset to see if that will resolve the issue. With the printer still turned on, disconnect the power cable from the back of the printer. Then disconnect the power cable from the wall outlet. Wait 10 seconds and reconnect the power cable back to the wall outlet first, then the back of the printer and power it on again.
Make sure the printer is connected directly to wall outlet. (don't use a power hub or a surge protector)
Try and print a hardware self test. Disconnect any cables on the back of the printer except the power cable. Follow these steps:
  1. On the printer control panel, press the Setup button.
  2. Use the arrow buttons to select the Reports menu, and then press the OK button.
  3. Use the arrow buttons to select the Config report option, and then press the OK button.
Did the hardware self test print?
Now try and make a copy. Did it copy successfully?
Reconnect any other cables again to the back of the printer.
Now try and do a scan through the software.
Did it scan successfully?
If you are still having issues then please follow the steps below:
  • Go to the Start menu and select run.
  • Type services.msc and click OK.
  • Locate the 'Shell Hardware Detection' in the list. If it is not enabled/started, Make sure to enable/start the service. Also make sure the Startup Type set as Automatically from its properties.
  • Locate the 'Windows Image Acquisition (WIA)' in the list. If it is not enabled/started, Make sure to enable/start the service. Also make sure the Startup Type set as Automatically as well.
  • Locate the 'Remote Procedure Call (RPC)' in the list. If it is not enabled/started. Make sure to enable/start the service. Also make sure the Startup Type set to Automatically.
Posted on Dec 20, 2016
Testimonial: "thanks for your help. but a scan unite has been replaced and it working well right now ."
Scan Error code 13 in printer M225dn
Left the printer switched off for 6hrs atleast and it will start working again from Scanner Error 13.
Aug 10, 2016 | HP LaserJet Pro M225dn Wireless...
Hp leserjet pro 400 mfp scaner error 52
The scanner initialization did not pass it seems. Try cleaning the glass and white background.
If that doesn't work, the scanner bulb may be faulty - try replacing it.
Sep 09, 2014 | HP Laserjet Pro 400 Mfp M425dn...
Hp leserjet pro 400 scner error 52
The printing scanner (laser) has likely failed. HP has had some issues with the series of products and bad laser scanners so you may want to contact their customer service to see if you can get it fixed under warranty.
HP Laserjet M2727nf Mfp Printer Scanner Error 8
The HP M2727 has a known issue with the scanner error 8 and bad formatters. HP has extended the warranties on this product. I suggest you contact them directly and they will most likely exchange the unit.
Nov 08, 2011 | HP Laserjet M2727nf Multifunction Printer
Unable to resolve "scanner error
how can i resolve the error code 22 on my hp laserjet m1212nf MFP?
Jul 23, 2011 | HP LaserJet M1120 MFP All-In-One Printer
My HP Laserjet m1005 mfp is showing error 6, please provide support and help us in solving the error
Jan 24, 2011 | HP LaserJet M1005 Printer
SCANNER ERROR 20 of HP LASERJET M1120 MFP
PRINTER: HP DESKJET M1120 MFP DISPLAY SCREEN SAYS; "SCANNER ERROR 20"...
ANY IDEAS HOW TO FIX?
MANY THX!
Mar 10, 2010 | HP LaserJet M1120 MFP All-In-One Printer
Scanner error 6
Problem for HP LaserJet M1120 MFP All-In-One Printer Scanner error 6
Feb 22, 2009 | HP LaserJet M1120 MFP All-In-One Printer
HP LASERJET PRO MFP M225DN Logo
62 people viewed this question
Seeker5211
Seeker5211
