Question about Carrier 44.9 cu. ft. Upright Freezer Beverage Air K Series KF48-1AS
Beverage Air E Series freezer not getting cold enough
Our 6yr old Beverage Air EF24-1AS FREEZER goes down only to 10F at night (should be 0F or below) and stays at 38F in the day (when the kitchen is being used + is warmer). we found a leak in the capillary tube, welded it, and also replaced the evaporator coil (originally thought that was also leaking, but not so). Freon has been recharged, & it is no longer leaking out. the fans inside the unit work fine. no excessive sweat or frost + all the components (compressor-evaporator-condenser) are kept clean, but the unit is not reaching 0F (after it initially did when recharged).
4 Suggested Answers
  • 340 Answers
SOURCE: Beverage-Air KF48-1AS not coooling, fans not running
some thing wrong with the evaporator fan motor. make sure the motor turns freely. your going to need service .
Posted on Jun 21, 2009
pride applia
  • 232 Answers
SOURCE: compressor start for a few second and cut off and
dirty condencer coils bad fan motor or compressor start relay on the side of compressor or turned off then back on without waiting 5 min.
Posted on Dec 09, 2009
  • 571 Answers
SOURCE: need conec of electrical system heather elemt,
http://www.beverage-air.com/Main.aspx?pid=50&tab=51 you will find the pdf files for specs & manuals here.
Posted on Aug 27, 2011
What does DA mean on the digital display on a Beverage air Freezer HS series
What does ( da ) mean on a beverage two fan single door reach in frezzer disply
Sep 08, 2014 | Beverage-Air Freezers
Ffbm 920w won't cool
It appears that your auto defrosting system (if you have one) is not working. So your evaporator coil is frozen up - all that ice serves as an insulator and not enough cold air is getting down into frig section. Until you replace either the freezer defrost element or the defrost timer all you need to do is unplug for a few hours till it fully defrosts then plug back in - will work fine for a few days at normal internal temps till the ice builds up again.
If your timer and defrost element are both working properly, THEN, you might want to check if you have enough refrigerant in the system - you may have a leak.
Mar 31, 2014 | Avanti FFBM921PS 9.2 cu. ft. Bottom...
How do i replace a wheel on a beverage air freezer
For Service Call (877) 866-1223 Beverage-Air Corporation Offices: 3779 Champion Blvd., Winston-Salem, PA 15825
_________ Manufacturing/Shipping/Receiving: Brookville, PA 15825
Contact with Model Number and Serial number for assistance
Beverage Air
Sea Breeze
Feb 26, 2013 | Freezers
We have a Jenn-Air Refrigerator/Freezer (Model #JRSD226) and the ice maker has stopped working.
Check for blockage in the water line in the freezer. If so, defrost it. Might need a new water valve. Maybe a bad ice maker too.
Another possibility is that it's not cold enough in the freezer. Should be below +10F.
Freezer repair in Corona Del Mar, CA
Appliance repair in Corona Del Mar and Orange County, CA
Jan 25, 2011 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
We have a Amana BR18 Easy Reach bottom freezer. The fridge is turned up all the way, barely keeping food cold. The freezer is not freezing anything (ice, etc.). The freezer is still blowing cool air, but...
Low refrigerant assuming the compressor is always running and not being shut down by the thermostat.
You can hook up an ammeter to the unit to see if the current consumption is below spec, another sign of low gas situation since the motor is not working as hard as under normal conditions.
Jun 10, 2017 | Freezers
Jun 19, 2009 | Carrier 44.9 cu. ft. Upright Freezer...
What do I do?
There is a thermostat control but your problem sounds like a system that is low on refrigerant charge. If it cools down to 55°F the compressor is working. If the system is low on refrigerant it has a leak which must be found and repaired before it is operated.
May 31, 2008 | Beverage-Air 74 cu. ft. / 2095 liter...
Beverage-Air Freezer Model KF-24
verify that condensers ain't clogged with dirt, condenser fan is running all the time and set the thermostat to the coldest setting. if temperature keeps rising suspect dirty condenser of deficient condenser fan. if compressor runs and no cooling after condenser cleaning. suspect a refrigerant charge problem. hope to be of assisit
Apr 26, 2008 | Beverage-Air 20.7 cu. ft. / 586 liter...
Beeping freezer??
Also check that there is plenty of room around the air vent to stop the freezer overheating.
Thanks J
Feb 08, 2008 | Beverage-Air Freezer K Series Reach in...
Carrier 44.9 cu. ft. Upright Freezer Beverage Air K Series KF48-1AS Logo
232 people viewed this question
Top Carrier Freezers Experts
Dennis Boxerman
AJMAL KHAN
Bill Boyd
Are you a Carrier Freezer Expert? Answer questions, earn points and help others
