Skycaddiebreeze breeze not charging via wall socket but does charge by syncing via sync express and plugging breeze into laptop. Tried other skycaddiebreeze wall plug but no success
  • 58 Answers
SOURCE: battery won't charge
sounds like the ac adapter isnt working.Test the adapter with a volt meter.The sticker on the adapter should tell the output voltage.
Posted on Mar 25, 2008
SOURCE: Sansa e280 will only charge when connected to my computer
I'v had problems with my Sansa 280r (I think)... everything was working fine for about two years and then I recently tried adding a new playlist and everything went funny.. WMP would only see it in MCS mode and not in MTP which is the wrong way around and when I sync everything appeared to work fine until I disconnected it and there was nothing on the player. So I hooked it back up, tried sysc again but it said that all the songs were already onn the device yet it was still empty when I unhooked it.
I tried everything from uninstalling it in Device Manager to reformatting it but nothing worked... Looked for drivers on San Disk but there are none.
Anyway, I had actually given up and was looking at new MP3's on the San Disk site and I noticed a link to download WMP 11... I kinda thought I had that version already but rather than even checking, I hit the download button... My sansa has been 100% ever since... I reckon I must have lost or damaged some files or components and it was affecting how WMP was interacting with the SANSA.
If your having any problems with your Sansa, these are the steps I would try.
1) Put the device iin MCS mode (Settings/USB Mode/MCS)
2) Hook it up to your computer and double click 'My Computer'
3) The player should show up here as a drive... Right click and select 'Format' (Personally I used the long format... not sure why but it doesnt take long)
4) Disconnect the player
5) Download WMP11 and restart your PC
6) Change your USB mode on the player to MTP
7) Open WMP and connect the MP3... You should see it straight away as a new device and it will ask you to name it (Delete any old references in WMP that you used to use as this is a new "partnership" your setting up... Just right click the old name and select 'End Sync Partnership)
Hope this helps... If not you someone else somewhere... Pain teaches well !!!!!
Shay Murray
Posted on Aug 02, 2008
SOURCE: not charging
I found out how to solve this problem...first power down your computer. Then take out the battery, remove the power supply, and then hold down the power button for 30 secs. Put the power supply in only (not the battery). Start your computer after everything is done loading up put the battery back in. Give it a min. and then you should be able to roll your cursor over the battery life indicator in the lower right corner of you computer and is should say charging. I have found that other people have had this problem and it has worked for myself and for them.
Posted on Apr 07, 2009
SOURCE: my device won't charge
This situation sometimes occurs when the batteries get overcharged. Use the phone for a day and then attempt to charge. If it still won't charge, remove the battery for about a minute. Then re-install the battery and attempt to charge. If that doesn't clear the problem, you may need to get a new battery.
Posted on Mar 03, 2012
SOURCE: Problem with htc sync
Try to uninstall HTC Sync (restart) then re-install application again and restart again. Before you start HTC Sync first time, plug your phone and make sure driver are successfully installed then start HTC Sync.
Posted on Aug 28, 2012
My PRS-300 is not holding a charge nor syncing to my computer. Help please!
To charge a PRS-300, you need an AC-Adapter (wall plug) from a PSP console.
As for the syncing problem, you may need a new USB cord.
Feb 09, 2012 | Sony Reader Pocket PRS-300
My HTC phone will not sync with the laptop
Hello, have you downloaded the most recent version of HTC Sync from their website?
Does your laptop recognise your phone when you plug it in?
Does the charging light indicator light up on your phone when you plug it into the laptop?
When you get the connection menu on the phone (IF you get it) are you selecting 'HTC Sync'?
Does HTC Sync start on the laptop?
Are you selecting each category and telling it to sync, say, your pictures, music etc, then clicking Sync Now?
Jul 26, 2011 | HTC Desire Cell Phone
How can i open it and where to find the charger ?
  1. Connect the power cable to the jack on the sync cable adapter
  2. Connect the 26-pin device plug of the sync cable to the 26-pin connector to the bottom of the device.
  3. Connect the power plug to the grounded wall socket.
The LED indecator will start to flash green as soon as it begins to charge.
Jan 15, 2011 | ASUS Mypal A730W Windows Mobile 2003
My iphone 2g is not charging and its not even syncing.
the place where you plug the wire might be messed up.. do a diagnosis on it with apple
Apr 27, 2010 | Apple iPhone Smartphone
How do you charge the battery on a fuji finepix z digital camera
The battery does not charge via USB.
Place the battery into the charger, then plug the charger into a wall socket.
Refer to the section titled "Charging the Battery" in the manual.
Jan 02, 2010 | Cameras
There is probably something wrong with the wall socket charger. Try a different charger on your phone and a different phone on your charger and see which ones work.
Dec 27, 2009 | Cell Phones
How to charge a new ipod nano?
Put the power adapter in the ipod nano and plug the other end into the power socket in the wall. If you don't have a charger, plug it into your computer like you would when you sync it, and it will charge.
Dec 25, 2009 | Apple Audio Players & Recorders
Wireless controller issue
The fact that the controller is not syncing to your console even when connected via the Play and Charge cable leads me to believe that your controller is more or less "a goner". The wireless controllers should automatically sync with the console when plugged in via the cable, so since yours doesn't sync I would guess there is something wrong with the IC chip inside and somehow something got corrupted.
Out of curiosity, when you plug in the cable how can you tell the controller is on if it doesn't sync? Do the lights continuously spin around in a circle? Do they just flash? Does quadrant 1 light up like normal but pressing buttons on the controller doesn't do anything?
Apr 13, 2008 | Microsoft Xbox 360 Controller
80 gig ipod
You need a new battery (
Mar 31, 2008 | Apple iPod MA446LL/A MP3 Player
27 people viewed this question
